Breather mod problem
Discussion in '1st Gen Tundras (2000-2006)' started by a4passata6, Apr 30, 2022.
  1. Apr 30, 2022 at 12:11 PM
    a4passata6
    a4passata6 [OP] New Member
    So removed the tail light ran the hose and clamped the breather and then ran the other end of hose down to the differential. Took off the old breather went to screw in the new breather I bought on Amazon and the threads are slightly different. Now off to Toyota to order the correct coupler. Below is what I received from Amazon. Almost correct threads. Be careful ordering this part.
  2. Apr 30, 2022 at 7:06 PM
    shifty` Ten EV 12's so you know I raise hell
    Yeah, if this was supposed to be an OEM part and you got from scAmazon, I'm not surprised. scAmazon has become a haven for counterfeits and knockoffs, especially with auto parts. I think it actually may be worse than what fleaBay had been for the longest time.
  3. Apr 30, 2022 at 7:45 PM
    a4passata6
    I should have known better…
