Cleaning the air ducts 06 Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Emcn77, Apr 30, 2022.
  1. Apr 30, 2022 at 7:40 AM
    Emcn77
    Emcn77 [OP] New Member
    Hello everyone. New here. I just bought a 2006 Tundra Limited. It’s in incredible shape. An older gentleman owned it and took excellent care of it. Long story short, I’ve come to realize I have an allergy to, what I think, is Fabreze...or the scent in it? Regardless, this truck seems to have been treated with it. Each time I drive it I get worse...swollen eyes and lips, lungs feel tight etc. I didn’t notice it on the test drive sadly. I’ve extracted the carpet, put down baking soda, wiped down the leather seats, dash etc. That helped a lot, but still have some issues. My main concern is that when I use the fan, it’s a lot worse. Can I clean the ventilation system? Do I need to take it apart? I don’t want to mask the scent as it’s an allergic reaction, not a dislike of a smell. There is no in-cabin filter in the 2006 Tundra. Sorry to be long-winded. Any help is appreciated.
  2. Apr 30, 2022 at 8:11 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Ozone generator. Run it as long as it takes to remove odors, can run truck fan on recirculate while running the generator. I would try that before disassembling the dash and interior to try and clean in the HVAC vents.
  3. Apr 30, 2022 at 8:51 AM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    ^^^ This is a great idea. Before doing that I would also give the vents a good disinfectant blast like in the vid I have posted below. The only thing I would do differently though is to leave the windows open while cleaning. Good luck.
    https://www.youtube.com/watch?v=ynY5HKMMBuo
  4. Apr 30, 2022 at 9:13 AM
    FrenchToasty and DarkMint like this.
  5. Apr 30, 2022 at 10:10 AM
    Emcn77
    Thanks for the advise so far.
    Mogo Gogo likes this.
  6. Apr 30, 2022 at 2:38 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    bmf4069, des2mtn and Mogo Gogo like this.
  7. May 3, 2022 at 11:33 AM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    Guys, I had a "old people smell" when I bought my XSP a few years ago.
    Passenger side lower dash. Pull out the blower fan.
    Make DAMN sure your condenser drain is
    Working.
    Get some condenser foaming spray from a home improvement store. With the blower remover, good visual to the evaporator.
    Suds that sucker down. Flush with garden hose.
    All junk flows out the condenser drain.
    While fan is out scrub up the rotor.
    Add a drop of oil to your fan, reassemble.
    Enjoy clean fresh air
    bmf4069 likes this.
  8. May 3, 2022 at 2:40 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    “old people smell”….I resemble that remark :eek2::annoyed:
    abcinv, Darkness, Tundra2 and 3 others like this.
  9. May 4, 2022 at 11:13 AM
    Emcn77
    Well guys, gonna start dealing with it tomorrow. I’ll keep you posted. Thanks for all the help!
  10. May 4, 2022 at 6:31 PM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    I wonder if an auto detailer has a way to de-smell the air ducts and vents? Might be worth an inquiry.
  11. May 4, 2022 at 8:29 PM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    FrenchToasty and Mogo Gogo like this.
  12. May 5, 2022 at 7:54 AM
    weadjust
    weadjust New Member
    Tupelo, MS
  13. May 5, 2022 at 4:46 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Caveat Emptor! The prior owner of my truck used some sort of perfumey smelly shit to clean the vents, causing me teary eyes and migraine headaches every time I turned on the heat (yes, I'm chemically sensitive). It smelled worse than a NYC Taxi with one of those crown air fresheners! It's been two years now and it's still noticeable.
  14. May 9, 2022 at 7:35 PM
    Emcn77
    Ok guys, time for an update. Turns out it’s in the cleaner they used to detail the truck. I cleaned the vents...which I will update regarding, and although they smell fine (no smell) I’ve since removed the seats, cleaned the headliner and power washed the carpet. We’ll see tomorrow if it’s dry abs if the smell dissipates. I’ve used an ozone generator, tuff stuff on the headliner, and baking soda dissolved in water to wash things. The baking soda is the only help so far. However, it seems it’s “in” the seats (leather skins). Not sure what do do about that.
    For the air vents, I used a product off Amazon called CleanSmart Disinfectant
    and followed the directions in the above video by spraying it down the fresh air inlet. It’s all natural and no scent, but kills bacteria as much as Lysol. Pretty happy with the results of that part!
    w666, shifty`, tpope and 1 other person like this.
