Obd Fusion trans temp pid problems
Discussion in '2.5 Gen Tundras (2014-2021)' started by Knuckled62, Apr 30, 2022.
  1. Apr 30, 2022 at 6:29 AM
    Knuckled62
    Knuckled62 [OP] New Member
    Denis
    2018 Tundra Double cab TRD 4x4
    roll lock cover, rino side boards, curt 5th wheel hitch, sumo springs,
    HI everyone i am new to the forum and am having trouble setting up obd fusion app to monitor torque converter and trans pan temp.
    I am planning on quite a few trips in the mountains towing a fifth wheel trailer and would like to keep an eye on temps.
    I have followed the equations on the forum see below.
    I Have a 2018 tundra TRD pro, every time I try this equation and hit test, it say invalid equation.
    I believe this is for a second generation tundra and mine is 2.5 generation, don't know if this is the problem.
    any help would be appreciated.
    thanks
  2. Apr 30, 2022 at 7:04 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
  3. Apr 30, 2022 at 11:21 AM
    737fixer
    737fixer New Member
    I'm by no means literate on this type of subject but when I installed the OBD Fusion on my phone I bought the extended PID for Toyota from the app which then gives a million more readings. It was an extra $10 or so and that immediately had the two trans temps working without having to do anything. I did not have to set up anything. Did you purchase the extra PID or is this something different all together?
    TTund16 and panicman like this.
  4. Apr 30, 2022 at 3:40 PM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    Pay for the extra PID. Also, consider upgrading your head unit. I went with pioneer and have set up a custom dashboard with trailer view and trans temp:
  5. May 1, 2022 at 6:38 AM
    Knuckled62
    Denis
    I have purchased the extra add on's for the tundra.
    I have looked at numerous threads on these custom pids and just can't get it to work.
    I did find that there are two transmission temps listed in the additional engine control management section called "a/t oil temp 1" and "a/t oil temp 2".
    I am not sure if these are the same as the custom pids and if they are which one is pan and which one is convertor.
    I also saw some where in this rabbit hole of information that some one had a gauge that showed gear number and torque converter lock up in one.
    I would love to see how that was done.
    thanks
  6. May 1, 2022 at 6:45 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    You sure you have a 18 TRD Pro? :monocle:
