2016 Tundra CrewMax 4x4 strange trailer braking issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by the4esweb, Apr 27, 2022.
  1. Apr 27, 2022 at 12:45 PM
    the4esweb
    the4esweb [OP] New Member
    Well I am just wondering if anyone has this same issue. When I tow my 4200# deck over trailer my Tundra will not engage the trailer brakes with the first step of the brake pedal about 99% of the time. Usually I have to pump the pedal a second time for them to engage. Any ideas?
  2. Apr 27, 2022 at 1:07 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Wasn't there some kind of software update for the brake controller in trucks from around that time or something like that?
  3. Apr 27, 2022 at 1:11 PM
    the4esweb
    There is but it pertains to a condition of brakes having a non normal feel. This is different than mine. Mine simply don't work unless you slightly lift foot off of pedal then step down again.Kind of like pumping them.
  4. Apr 27, 2022 at 2:18 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Have you used the truck to pull another trailer with brakes? Same issue? Could be something with the trailer.
    Stock controller is marginal at best. Many remove it and use a tekonsha p3. There are install kits available to put the P3 in the stock location and it is an excellent brake controller.
    the4esweb[OP] likes this.
  5. Apr 27, 2022 at 7:01 PM
    the4esweb
    Yes, a 25 ft travel trailer same issue
