It's been a long time, but I'm back & could use a huge favor
Discussion in '2.5 Gen Tundras (2014-2021)' started by Luckie Stiff, Apr 27, 2022.
  1. Apr 27, 2022 at 5:06 PM
    Luckie Stiff
    Luckie Stiff [OP] New Member
    Scott
    Austin Texas
    2021 Black Limited Nightshade Crewmax 4WD
    So out of an abundance of caution I installed the CCM cat shields. It wasn't until I was done that I realized I'd have to pull if off to get to the oil pan drain plug. Would anyone be willing to measure from the centerline of the front cross member to the drain plug? I'm going to put a 4" hole saw through the shield for access.
    2021 Tundra 4X4 w/5.7 gas engine
    Thank you
  2. Apr 27, 2022 at 5:32 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Man, I’d probably just take it off and not saw on it while it’s on the truck. I know it sucks.
  3. Apr 27, 2022 at 5:34 PM
    Luckie Stiff
    Scott
    Austin Texas
    I think you're right, the more I thought about it the more I could envision the pilot bit going right into the pan.
    Looks like I've got something to do tomorrow
    Thanks for the reply
  4. Apr 27, 2022 at 5:38 PM
    Terndrerrr
    Music City
    6UR-FE
    Yep, that’s what I was thinking. Those pilot bits stick out too far for that. It’s far from fun, but I still take the plates off regularly to clean all the mud and sticks and leaves off of em. I get so much stuff up in there from off-roading.
    Wahayes likes this.
  5. Apr 27, 2022 at 5:39 PM
    Wahayes
    Will
    2017 tundra limited *sold*
    X2 when i read this
  6. Apr 27, 2022 at 5:39 PM
    The CCM blocks access to the oil drain plug?
  7. Apr 27, 2022 at 5:48 PM
    shackleford rusty
    shackleford rusty New Member
    TEXAS!
    NO, NO, NO... hit the pause button.
    i have the ccm cat security shield installed and changed my oil on saturday. no removal required. standby while i snag some pics.
    Taco-Spike likes this.
  8. Apr 27, 2022 at 5:50 PM
    I was trying to figure that out myself. The oil drain should be forward of the cat plates. I'm wondering if he was accidentally referring to the transmission pan drain plug.
    Terndrerrr and Taco-Spike like this.
  9. Apr 27, 2022 at 5:54 PM
    shackleford rusty
    TEXAS!
    had the same thought as i was taking pics.
    you WILL need to remove and/or modify the shield for transmission service.
    you WILL NOT need to remove the shield for engine oil change.
    pics incoming.
  10. Apr 27, 2022 at 5:58 PM
    shackleford rusty
    TEXAS!
  11. Apr 27, 2022 at 5:59 PM
    Patch999
    Kyle
    2017 Bad@$$ TRD Pro
    Not sure what shield you went with but mine has access
  12. Apr 27, 2022 at 6:01 PM
    shackleford rusty
    TEXAS!
    additionally, drilling a hole to access the transmission drain plug will be of no use if you cannot access the fill plug.
    best to remove shield to service the transmission. i do it every 40k miles for my drain/fill.
    Patch999 likes this.
  13. Apr 28, 2022 at 5:39 AM
    Luckie Stiff
    Scott
    Austin Texas
    Y'all are awesome! Thank you for the pics, like someone else said, I confused the trans plug for the oil plug. Thank you guys again, I wasn't looking forward to taking the shield off & reinstalling it on my back in the driveway.
    Terndrerrr likes this.
