  1. Apr 26, 2022 at 7:01 PM
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    Love that front bumper. :thumbsup:
    chrisb and alb1k like this.
  2. Apr 26, 2022 at 7:28 PM
    POR-15 is fine but WEAR DAMN GLOVES. The stuff will stick to your hands like superglue, harden almost instantly, and you'll be stuck with it for days.
    It's good stuff, just follow the directions, and be sure to remove all rust. If surface rust, Naval jelly works great, again, follow instructions, 10-15 mins to treat, although I've known people in bad situations (deep rust) who've applied and wrapped with cling wrap overnight to clear heavy stuff. Even if you choose to use mechanical methods of removing, use Naval jelly on the areas you cleared afterward to clear the microscopic crap.
    NUDRAT, 805Tundra, oscardog86 and 2 others like this.
  3. Apr 26, 2022 at 8:43 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Started by hand with ratchet, the 2 that didn't move I then soaked again tried again then hit with 1/2" DeWalt battery impact. No budging so then heated and things loosened.
  4. Apr 26, 2022 at 8:51 PM
    Hi06silver
    2006 DC 4x4 Waltrip
    Looks damn good! Never used POR. I've read that it sounds like a coating so basically everything needs to be clean and dry as can be before or it will trap moisture?
    Thanks, wouldn't ospho do basically the same as naval jelly? I have ospho already. They all smell like death, so I assume they do basically the same thing.ive used naval jelly on cast parts for an old factory cart turned table years ago but it's not exposed to the elements. That shit was stankonia!
  5. Apr 26, 2022 at 9:16 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    Ospho is holding my novas subframes together.
  6. Apr 26, 2022 at 9:54 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    1. Yes. Remove brake lines, I would cap them off with 1/4" vacuum caps. Also just unclip the brake cables so you can pull the axles with the drums as one.
    2. OEM gasket
    3. Bulkhead? Not sure what you mean.
    4. Open diff use any synthetic. Clutch type LSD (OEM or aftermarket) Motul 90 pa or Lucas 75w90 + friction modifier. (Motul has it already.)
    No need for 140 oil unless you've got a ton of HP and are getting it hot. Or you plan to tow over capacity.
  7. Apr 27, 2022 at 2:12 AM
    tacoguybill
    tacoguybill The Burrito Bandido
    Saaaan Diaaago
    06 DC SR5 4x4 174k, 04 Sequoia SR5 4x4 105k
    Well it’s been a super frustrating couple of days. Problems started with upper ball joints and a bearing press that’s just awkward, when pulling passenger side I notice that the hub had some pretty intense friction to turn so for 4th time (2 driver 2 passenger)I thought I was going to need to press out yet another hub bearing. No more screwing around this time and went to Toyota for OEM bearing…the package was labeled @mazon online sales…also labeled koyo which I found online for half the price…color me surprised. Currently drivers side is reassembled upper ball joint, lower ball joint, outer tie rod end and sway bar end links replaced. Hopefully I can get that bearing pressed back in and have the passenger side reassembled in short order. Then center support bearing, PCV valve and maybe take a gander at some spark plugs….then I can finally detail the interior and exterior of the truck which I’m sure will bring me to the end of my “vacation” :rofl:
  8. Apr 27, 2022 at 6:21 AM
    I have it stuck in my head water is an activator for POR-15, but my memory is fuzzy on things like that. I think that's why it hardens rapidly on your skin when it makes contact, same as super glue.
    I think Ospho is a rust converter? I've never used it.
    Naval jelly is straight-up acid gel. Mostly phosphoric acid (~25%) with a tinge of sulfuric acid (~2%). Most of the rest is straight-up water and thickeners/stabilizers to keep it in gel format. No-frills acid etch king.
    Anyway, here's teh POR-15 instruction sheet courtesy of Summit Racing, if it's interesting: https://static.summitracing.com/global/images/instructions/por-15 application info.pdf
    chrisb, NUDRAT and Hi06silver[QUOTED] like this.
  9. Apr 27, 2022 at 6:25 AM
    Never order auto parts from scAmazon or fleaBay, and if you didn't, never order from wheover you did again, they must be doing fulfillment using scAmazon warehouses. Stick with big, established names like Summit Racing and Rock Auto. You never know what you're going to get w/scAmazon or fleaBay, both are a constant source of counterfeits, open-box swaps, etc. Neither have any viable path to keep counterfeits out of their inventory because they warehouse bulk inventory for anyone and everyone and can't or won't scan incoming inventory to their warehouses, that would cost tens of thousands of bucks out of Bezos' tens of millons of salary each year and he ain't having that when it only causes problems for commoners like us.
    chrisb, KK6PD and sn_85 like this.
  10. Apr 27, 2022 at 7:31 AM
    sn_85
    sn_85 New Member
    Boise
    2006 DC Tundra 4WD, 2013 Land Cruiser, 2022 RAM 2500 Bighorn
    Yep, there are just some things to never buy off Amazon. I ordered a Yeti cup with Amazon as the retailer and it was a counterfeit. Never buy car parts off Amazon and absolutely never buy any type of food product off there either, not even for your dog. All the stuff is fake, expired or bad. About the only thing I buy off Amazon nowadays are cheap phone cases and screen protectors.
    KNABORES likes this.
  11. Apr 27, 2022 at 2:04 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    I love this truck!
    Darkness and alb1k[QUOTED] like this.
  12. Apr 27, 2022 at 2:12 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Thanks, brother. Just implementing some of the things I've learned here. Great community. :cheers:
    abcinv[QUOTED], chrisb and 805Tundra like this.
  13. Apr 27, 2022 at 2:20 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    @alb1k you live next to the beach, do you use anything for rust prevention on all the aftermarket suspension?
  14. Apr 27, 2022 at 2:37 PM
    alb1k
    Left Coast
    It's good
    I'm 1/2 mile away so not as much salt as if I was on the beach. I've been touching and wiping and pulling it so much I't can't really rust at the moment. I did test Fluid Film a while back. I like it but not so much on shiny parts like coils. Only because the rattle can is hard to spray uniform. I may try that Blaster stuff. This stuff is pretty cool for a look good but not last as long application to the frame and wheel wells, probably books good on suspension as well.
    https://www.amazon.com/gp/product/B001XSJI38?ie=UTF8
    Once I get done messing with parts for a while I'm going to try to nail down what's best. Probably FF or Blaster for frame and wheel wells, leafs, etc.
    I'm not sure what coilovers or pretty parts like the best. Probably something not terribly long lasting if it looks great. But I am sick of road grime getting them dirty. Same with the rear shocks. Brushed aluminum sucks up dirt.
    oscardog86 and 805Tundra[QUOTED] like this.
  15. Apr 27, 2022 at 2:48 PM
    805Tundra
    Ben
    Central Coast
    Thanks for the input, let me know if you find something you like. I am not terribly close either but I am at the beach every weekend and close enough where the onshores blow salt water into the air. Nothing is worse then those shiny coilovers getting rusty. I used MavSteel on the billies but it was a little tacky and left a slight blue tint and im not sure yet if i want to spray the front coilovers/ucas with it yet.
  16. Apr 27, 2022 at 3:17 PM
    alb1k
    Left Coast
    It's good
    Ya for sure. It also blows harder more often by you. The boy went out on a ridiculous blown out day at the rock because we were there. Someone called 911 because it looked like an emergency. lol. I didn't get out of the truck to talk to Harbor Patrol - it was freezing!
  17. Apr 27, 2022 at 3:26 PM
    805Tundra
    Ben
    Central Coast
    haha i know those days all to well! Damn he is trooper, it looks freezing lol. I am not going out on days like that anymore. What lense were you shooting with? 300?
  18. Apr 27, 2022 at 3:29 PM
    alb1k
    Left Coast
    It's good
    That one's cropped, but may have been a 400 on a 1.6X extender. He was out there a bit.
    Darkness and oscardog86 like this.
  19. Apr 27, 2022 at 3:46 PM
    805Tundra
    Ben
    Central Coast
    I was going to say it breaks kind of far out especially shooting from the lot. pretty crispy clear photo
    alb1k[QUOTED] likes this.
  20. Apr 27, 2022 at 3:50 PM
    daveeasa
    Tell the kid it’s the green room not the white room :)
    805Tundra and alb1k like this.
  21. Apr 27, 2022 at 3:57 PM
    805Tundra
    Ben
    Central Coast
    Love hanging out in the green room!
    alb1k likes this.
  22. Apr 27, 2022 at 4:04 PM
    typhoon
    typhoon New Member
    2003 Tundra AC Limited
    I used Chassis Saver, because I didn't have to use the whole POR15 kit. First I got rid of any scale, using a needle scaler. Degreased, washed, and let dry over night. Then just brushed the Chassis Saver.
    chrisb, oscardog86, bmf4069 and 4 others like this.
  23. Apr 27, 2022 at 5:56 PM
    Post 1337. We so badass.
    bmf4069, artsr2002 and tacoguybill like this.
  24. Apr 27, 2022 at 7:29 PM
    tacoguybill
    Saaaan Diaaago
    @shifty` this is what I was talking about bought from the dealership but labeled for scamazon online sales, definitely kind of curious.
    Everything went back together swimmingly today, precisely the opposite of Monday and Tuesday. Alignment appointment in the morning, carrier bearing will be saved for next week before heading back to VA.
    des2mtn likes this.
  25. Apr 27, 2022 at 8:17 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    We are First Gen. We are 1337.
    bmf4069 and tacoguybill like this.
  26. Apr 27, 2022 at 8:53 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I take that as that part was originally intended to be sold on their online scamazon store shipped from that dealership. That dealership probably lists their products on there and ships locally. If it isn't shipping from Amazon you're more likely to be in the clear.
  27. Apr 27, 2022 at 9:00 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I need to get around to cleaning up the rust that has started on the truck
    chrisb and bmf4069 like this.
  28. Apr 28, 2022 at 4:49 AM
    For anyone considering on using POR-15, I would recommend semi-gloss black if you want to match it to the color of the original frame.
    Also two coats to be thorough and always use a degreaser and metal etch (for non-rusty or exposed ground off metal areas) so it will bind. Found that out the hard way originally. The metal etch is optional, but not the degreaser.
    Be thorough in removing the rust mechanically though (wire brush or die grinder with wire wheel/cup)
    oscardog86 likes this.
  29. Apr 28, 2022 at 6:02 AM
    I had a weird situation this morning. I went to lock my truck at the gym and the alarm went off. No combination of button pushing on the key fob would turn it off. I had to open the door with the key, press the lock/unlock button on the door a few times, close the door, and eventually it went off.
    Now the key fob doesn't work at all. It's a new-ish one too so I doubt it's the battery. Anyone experience this before?
  30. Apr 28, 2022 at 6:47 AM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Gotcha. Was hoping we could get away without having to disconnect the brake lines lol.
    I was using bulkhead referring to the 3rd member…
    This 3rd has an ARB locker in it so hopefully can chime in what gear oil they’re using. I think I’ll be going 85w140 per other recommendations.
    thanks!
