Headlight assembly replacement
Discussion in '1st Gen Tundras (2000-2006)' started by wandering_boy, Apr 29, 2020.
  1. Apr 29, 2020 at 10:30 PM
    wandering_boy
    wandering_boy [OP] Junior Tech Wizard
    California
    2005 AC SR5 TRD
    Don't let a kid out smart you.
    I just thought I'd make this thread to help people who are trying to change their headlight assemblies. I did it just the other day and I thought I'd share the tricks I found to getting the job done.
    first a step by step:
    1. remove the 10mm bolt by the grille the body clip and phillips screw(you can also use a 10mm for the screw)
    2. disconnect the three prong and two prong plugs to the lights. the main bulb may take a little persuading and the daytime light has a clip on it.
    3. either grab a plastic body trim remover or I used a plastic bike tire iron to try and pry out the corner lights a little bit.
    4. grab either a shoe lace or a piece of thick string/thin rope and thread it behind the light making sure the shoe lace on the inside goes under the tab connecting it to the main lamp.
    5. as scary as it may seem you have to pull on the string straight forward until the corner light pops out.
    6. remove the last 10 mm that was hidden by the corner light
    7. under where you pulled the 10mm screw is an orange clip that can be pinched with pliers and then the whole headlight assembly can be freed by pulling up then pulling it out
    7.5 if your new assembly did not come with the orange body clip you can thread the screw in a bit and the tap it out and put it back on the truck.
    8. take your new light assembly and put it on the truck
    9. start with the 10mm screw than than do the two 10mm nuts
    10. reconnect the plugs
    11. put the corner light back in and install the black body clip.
    12. rinse and repeat for the other side
    I'll also put a link to the video I used.
    https://www.youtube.com/watch?v=JimNNGXnuCc
    feel free to add any tips parts or ask question.
  2. Apr 30, 2020 at 4:10 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Good write-up. Only thing I'd add is to measure the adjusters on your original headlights, and replicate that adjustment on the new ones. That way they'll at least be close. Mine required no further adjustment.
  3. May 2, 2020 at 5:22 PM
    Professional Hand Model
    Fred
    Hand Protectors
    SAE has some protocols on headlight adjustment/settings. I used their website specs for settings after installing new lights assys. Pretty simple stuff.
    SouthPaw likes this.
  4. May 2, 2020 at 6:42 PM
    wandering_boy
    California
    2005 AC SR5 TRD
    feel free to drop the link.
  5. May 3, 2020 at 5:08 AM
    Fred
    Hand Protectors
    Can’t find it. From memory, measure up to the little circle on your lens.
    Park vehicle 25 feet back from wall.
    Measure up on wall using the measurement taken to the circle.
    Adjust activated lights horizontal line to/no higher than the circle measurement height.
    Drivers assy lens should point straight ahead or slightly cocked inward.(Keeps from blinding). Passenger can cock slightly outward. (Light ditches and curbs).
    Toyota has a different criteria using a shorter feet from wall measurement (think its 8 feet?). Same idea as SAE and the little circle.
  6. May 3, 2020 at 5:20 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    It's an easy job, I sampled two different aftermarket housings before spending a little more for OEM Toyota housings to replace my originals.
  7. May 3, 2020 at 5:36 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    Sounds easy if you live down South. Well it is easy, unless those nuts are rusted on. Rock Auto sells headlight assemblies, comes with bulbs.
    tvpierce likes this.
  8. May 5, 2020 at 10:40 AM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
  9. May 5, 2020 at 3:42 PM
    bmf4069 Captain wtf
  10. May 5, 2020 at 4:03 PM
    Fred
    Hand Protectors
    Nice! I was hoping someone would put that FSM up.
    2 years ago, I stupidly used two 10mm open box wrenches to adjust that dial nut when all that needed to be done was dropping a long phillips down the chute. Someone posted this same FSM and I was ‘Like duh, you stupid hand model’.
    You even posted the low beam adjustment spec. which Toyota uses 3 meters from the wall and SAE is 25 feet.
    @bmf4069 good job. I’ll save this one for future reference.
    two2cal and bmf4069[QUOTED] like this.
  11. May 6, 2020 at 3:10 AM
    tvpierce
    Maine
    Great point. One of the studs broke when I was replacing mine. For anyone in a rust-prone climate, douse those nuts with penetrating fluid well in advance.
  12. Oct 5, 2020 at 8:29 AM
    pock
    pock New Member
    USA
    2005 Access Cab 4.7L V8 4x4 SR5
    Guys, I'm looking to do a head lamb assembly swap soon. My 2005 could use some love.
    Of course I've looked at aftermarket and OEM. OEM runs roughly $436 at Toyota of Cool springs. Aftermarket is about $150.
    Would like to know how your headlamps are holding up and what you personally used.
  13. Oct 5, 2020 at 8:33 AM
    wandering_boy
    California
    2005 AC SR5 TRD
  14. Oct 7, 2020 at 9:55 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Excellent write up OP! You did forget the most important item though, the headlight adjustment tools!
    :rofl: Capture.jpg
    bmf4069 likes this.
  15. Oct 7, 2020 at 9:58 PM
    wandering_boy
    California
    2005 AC SR5 TRD
    Jesus those are some long ass screw drivers
  16. Oct 9, 2020 at 5:36 PM
    pock
    pock New Member
    USA
    Got my new head lamps installed. Felt like the lamps are pointed a lil too far down! I did some serious adjusting but really want to get it precise.
    damn hurricane in Louisiana made me postpone finding a flat wall.
    bmf4069 likes this.
  17. Oct 10, 2020 at 7:21 AM
    pock
    pock New Member
    USA
    Anybody want an old set of OEM headlight assemblies? You would need to pay the shipping from Louisiana
  18. Oct 10, 2020 at 7:23 AM
    shifty` You can call 1 (800) PP5-1-DooDoo
    FTFY: Jesus those are some long ass kebab skewers
  19. Oct 10, 2020 at 7:26 AM
    Depends, what year and cab type, and are they DRL or non-DRL? DC uses difference headlights than AC and RC. Later model trucks have DRL in the corner closest to the grille, that little bubble.
    I'd like to replace my OEMs by restoring a pair of OEM. Mine has stress cracks through the lens (pics here)
  20. Apr 10, 2022 at 7:31 AM
    mbcpurple
    mbcpurple New Member
    2003 Tundra SR5 Access Cab V8
    Greetings, new to the forum, replaced 2003 sr5 front right headlamp successfully, could not hand pry left, unfortunately used screw driver and scratched things up pretty good and cracked cover on marker light. Need recommendation on good plastic pry tool so I can get this thing done, eventually some touch up paint I reckon by using vin number, positive input?
  21. Apr 10, 2022 at 7:42 AM
    You cracked it when prying the blinker housing out? You shouldn't need to pry anything. Just stand next to your front wheel and slap-push the blinker housing forward.
    BubbaW likes this.
  22. Apr 10, 2022 at 7:51 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    While you're absolutely correct, short funny story....
    When I did driver side couple years back using that procedure, I was able to get a new one after approx 16 years because I applied somewhat too much palm forward pressure and slung it across the garage :facepalm::)
  23. Apr 10, 2022 at 1:41 PM
    artsr2002
    'Yonder
    You did remove the screw at the top of the headlight that holds in the corner light right?
  24. Apr 10, 2022 at 9:09 PM
    artsr2002
    'Yonder
    Hehe. Speed holes.
  25. Apr 26, 2022 at 5:40 PM
    TheFixer
    TheFixer New Member
    Martin
    Alabama
    2003 Limited AC 4X4
    None.
    Hosed everything down with penetrating oil yesterday. Still snapped off a stud. Are these replaceable press in studs? I can’t find a part number for them on the web.
  26. Apr 26, 2022 at 5:50 PM
    artsr2002
    'Yonder
    Which stud did you break off? Post a pic. It may be easiest to drill it out and replace with a bolt/nut.
  27. Apr 26, 2022 at 6:29 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Blah-Blah-Blah . . . . . "F" all your Gen-1 headlight mods . . . burn in hell, you Sods.
    des2mtn likes this.
  28. Apr 26, 2022 at 7:05 PM
    artsr2002
    'Yonder
    What the hell did we do?
    des2mtn, HBTundra and FirstGenVol like this.
  29. Apr 26, 2022 at 8:25 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    I'd rather wipe my tail w/ rusty barbed wire coated in acid, then try to make my 2006 headlights brighter . . . .
    bmf4069 likes this.
  30. Apr 26, 2022 at 8:29 PM
    artsr2002
    'Yonder
    Well alrighty then.
