Weeping Rear Diff
Discussion in '2.5 Gen Tundras (2014-2021)' started by NCSU Fundra, Apr 26, 2022.
  1. Apr 26, 2022 at 10:00 AM
    NCSU Fundra
    NCSU Fundra [OP] New Member
    21 Tundra Limited
    Hello all,
    Long time lurker. I hope you all can help me here. I noticed some leaking around the differential. It has never dripped or pooled, so it’s not a fast leak.
    Is this normal? I tried searching this forum and Google, but couldn’t find much on the subject.
    I have 15k miles and an appointment scheduled later this week.
    51262CE9-4C0F-4A7C-BCDF-AB33F4769D2C.jpg 45630E00-2675-4B35-8E62-A4CF8B2CC627.jpg
  2. Apr 26, 2022 at 10:01 AM
    Mr Badwrench
    Mr Badwrench New Member
    This was a pretty common problem, even with the Tacomas. Take it back to the dealership and let them sort it out.
    Tundrastruck91 and Rocko9999 like this.
  3. Apr 26, 2022 at 10:06 AM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Please let us know how the dealer resolved? Experiencing the same on my 2019 Tundra, noticed when I serviced my rear diff last weekend.
  4. Apr 26, 2022 at 10:07 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    My 2016 doesn't do it.
    Tundrastruck91 likes this.
  5. Apr 26, 2022 at 10:10 AM
    AZEric
    AZEric New Member
    Eric
    2010 Rock Warrior
    Bilstein 6112’s & 5160’s
    hmmmm I doubt an active leak will come from it. But definitely take it to the dealership while it's in warranty to have this documented. They may re-seal it.
  6. Apr 26, 2022 at 10:15 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I had fluid film applied to the truck last fall so if it's weeping I would never know.
  7. Apr 26, 2022 at 10:17 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    why is your truck so clean?
  8. Apr 26, 2022 at 10:31 AM
    nopsFU
    nopsFU New Member
    2019 Tundra TRD Pro
    Check your breather, could be clogged? It's that little nubby thinger-mabob sticking out the top of the driver's side axle tube (your second picture).
  9. Apr 26, 2022 at 6:19 PM
    NCSU Fundra
    21 Tundra Limited
    Thank you all for the comments! I will certainly check out my breather and report back on what Toyota finds. I suspect they will clean the area and torque the bolts to start. I previously had a Tacoma that was bone dry so this was a little weird to see. I will also be doing some towing in the coming weeks so this is impeccable timing.
    Well, it is garage kept and I cleaned the undercarriage a few months back to rid it of road salt. I also happened to clean the inside of the rims during a rotation because why not.
  10. Apr 30, 2022 at 8:12 AM
    NCSU Fundra
    21 Tundra Limited
    Update: Dealer wants to replace the seal. Considering my truck is still low miles and how intrusive this repair seems I may bypass it for now. I plan to clean the area and see how quickly it weeps from here on out.
  11. Apr 30, 2022 at 8:30 AM
    blanchard7684
    blanchard7684 New Member
    2019 with 18000 miles. Looks the same as yours. no issues. It is an assembly issue not necessarily an incipient leak.
  12. Apr 30, 2022 at 11:12 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    I would get it done now. The repair is not difficult. You don't want to run that diff low on fluid plus you can evaluate the fix and make sure it is not continuing to leak while still under warranty.
  13. Apr 30, 2022 at 1:37 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    A sealant is used not a gasket. Its good shit, surprised to see any "weeping". on flip side I doubt all the lube you see is equivalent to 1 drop. I wouldn't touch it.....
  14. Apr 30, 2022 at 5:34 PM
    socaltundra951
    socaltundra951 Gentlemen Prefer Black Tundras
    Southern California
    Black CrewMax 5.7
    My truck has 67k on it and has always looked like that. Never left a single drip.
  15. May 24, 2023 at 9:44 PM
    vman82
    vman82 New Member
    2021 Toyota Tundra Crewmax Limited
    Bump...
    I notice this on my '21 as well...just hit 10k. Any updates from the dealer?
  16. May 24, 2023 at 11:00 PM
    AZBoatHauler
    So.Arizona
    I noticed this around 30k miles on my truck. Sprayed some brake cleaner to clean it and it hasn’t ever come back.
  17. May 25, 2023 at 2:55 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I don’t have this issue on mine but in previous trucks / SUV’s I started using a product called lube locker. It’s a differential gasket. I refuse to go back to using the sealant after using these…….the sealant is messy and too much trouble comparatively. Once the lube locker is placed and tightened down it’s awesome.
  18. May 25, 2023 at 7:48 AM
    vman82
    vman82 New Member
    So my question is, should I take this to the Dealer to get it fixed or is it normal and just not worry about it?
  19. May 28, 2023 at 7:26 AM
    NCSU Fundra
    21 Tundra Limited
    I cleaned the area with Dawn dish soap and it hasn't shown anymore signs of leaking. It is bone dry now. The dealer wanted to disassemble the entire propeller shaft, pumpkin, etc. to re-seal it. I did not want that kind of work done on the assembly considering how low mileage the truck was and I am glad I didn't. I suggest cleaning the area and monitor for the next month or so. Mine never actually dripped.
  20. Jun 18, 2023 at 7:47 AM
    vman82
    vman82 New Member
    So I cleaned mine a couple weeks ago... after a few hundred miles of driving, the weeping had come back. Should I take it in or am I over thinking it?
  21. Jun 18, 2023 at 8:00 AM
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    Get it done while the dealership has acknowledged the problem and is willing to fix it. That window can close in seconds and the circus can start. Use your warranty, look closely at their work when it's done.
    Take some pictures before you give it to them. When you hand them the keys tell them you're 'very particular' about your truck, which might help too.
    Rarely have I left a dealership service adventure without something special like a new scratch, double washers, things too tight or too loose, a differential not topped up after warranty work, new light on the dashboard, dealerships............
  22. Jun 18, 2023 at 8:34 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    The person you hand your keys to at the dealer doesnt actually work on the vehicle and has very minor knowledge of actually mechanical work, I'm sure there are exceptions but most have never done an oil change. They are just there as a talking head since mechanics are not typically customer service type people and this way they can keep the mechanics working while the "service advisor" deals with you. Its just one of the reasons I hate dealers, at least when you go to a local mechanic, you're talking to the guy covered in grease who actually knows what he's talking about and is the one thats doing the work.
    coldcanuk[QUOTED] likes this.
  23. Jun 18, 2023 at 8:44 AM
    vman82
    vman82 New Member
    I hate dealerships as well but this may be something I need to get done before my warranty expires. I just hope they don't cause more issues that may appear down the line later. I just cross the 10k mark and am pretty annoyed that I have this issue (just recently found out this is common).
  24. Jun 20, 2023 at 10:51 AM
    Lug Nut
    Lug Nut New Member
    2021 Limited TRD
    Bone Stock
    Mine looks the same.
    2021 with 8,000 miles on it
  25. Jun 20, 2023 at 12:46 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Definitely let them do it. The 108# 3rd member will need to be pulled in order to replace the gasket, which means brake lines, parking brake cables, and axle shafts come out. This should not be a "smear some RTV on it" type of repair. Ask the dealer to explain the procedure in detail...
  26. Jun 20, 2023 at 2:01 PM
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    My 21 started doing this at around 12k. Washed it off with SimpleGreen/water and a tire brush. Gave the breather a few twists and it has not came back. Almost to 15k now. Gonna monitor it for a few more thousand miles, but so far so good
  27. Jun 20, 2023 at 11:19 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    Regarding the breather being the answer, I’m skeptical.
    The breather on older Toyotas was nothing more than a little metal disc with a spring under it, contained in that cap deal on the axle housing. I ain’t saying that this can’t fail, but I’d bet you lunch that an axle seal would burp out excess pressure well before a properly sealed and assembled third member would let thick oil piss out.
    I still say let the manufacturer foot the bill for this repair!
  28. Jun 22, 2023 at 11:12 AM
    chingyeunglo
    chingyeunglo New Member
    Does the rear differential breather relocation kit help?
  29. Jul 3, 2023 at 10:05 AM
    chingyeunglo
    I had the same issue and the drive side axle end had it too. I thought because of the differential breather problem. Therefore, I did the breather relocation. I could feel and hear the pressure of the differential was release and escape when i unscrewed the factory differential breather, it just sounds like when you open a can of Cola. It should not happen because i did not move my truck for more than a day.
    Lug Nut likes this.
  30. Aug 1, 2023 at 8:05 PM
    drew.c.114
    drew.c.114 New Member
    Andrew
    Gilbert, AZ
    2021 Trail Edition
    So I have a very similar situation as some of you here. Cleaned the seepage I had coming from the lower rung of bolts (lower semicircle) with dawn dish soap right before a road trip from Phoenix to San Diego. Pumpkin was clean before I left and I just got back and noticed the seepage is back. I also checked the diff breather (I installed a relocation kit) and it was clear. I am approaching 34k miles and am weighing the options (as previously mentioned) on whether or not to open the can of worms with the dealer.
