2000 TUNDRA TURBO
Discussion in '1st Gen Tundras (2000-2006)' started by LITTLE DOG, Apr 25, 2022.
  1. Apr 25, 2022 at 11:48 AM
    LITTLE DOG
    LITTLE DOG [OP] New Member
    mark
    2000 tundra 4.7
    turbo 1 BIG T4
    THEIR ARE 2 TURBO KITS FOR TUNDRA. NO NAME AND JDM GET JDM. IS BASE KIT YOU WILL NEED A LOT OF OTHER PARTS AND TIME IT TOOK 1 MONTH TO COMPLETE. TOU CAN TAP INTO THE DRIVERS SIDE REAR VALVE COVER AND RUN A HOSE TO TURBO FOR TURBO OIL DRAIN. WILL NEED A BASE 2.5 PIPE KIT AND 4 JDM TURBO 2.5 ELBOWS.
    Sirfive likes this.
  2. Apr 25, 2022 at 12:07 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    Calm down, buddy. I know you’re excited, but no need to yell.
    get a t4? Gt35? Gt28?
  3. Apr 25, 2022 at 12:10 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
  4. Apr 25, 2022 at 12:22 PM
  5. Apr 25, 2022 at 12:26 PM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    Hahaha I was just thinking that.
  6. Apr 25, 2022 at 12:35 PM
    IN SOVIET RUSSIA, TURBO BOOSTS YOU.
    Seriously though, I'm guessing this is T4 kit Summit and others sell?
    How much are you boosting, just curious, and what's your BOV set at? Did you beef up the motor at all? I've read in more than one place anything over 8psi on these 2UZ is asking for failure.
  7. Apr 25, 2022 at 12:45 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Yea, t4 is too beaucoup for extra power at a useful rpm. I couldnt get the turbo size calculator to work, or id have been a little more specific in my suggestions, but i’d like something that can hit max boost at 2500 and carry it to 4k. Peak tq on the non vvti engines is 3400rpm, and the last guy that came in talking about the turbo kit said it didnt really wake up until 4krpm.
    Saltyhero13 likes this.
  8. Apr 25, 2022 at 12:57 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    But will it have wastegate issues?
  9. Apr 25, 2022 at 1:00 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I still havent figured how to play engine noises over the speakers.
  10. Apr 25, 2022 at 8:38 PM
    Is this your public service announcement or do you have a question?
    Siebler, e30cabrio, bmf4069 and 2 others like this.
  11. Apr 25, 2022 at 8:45 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    It has been well documented that adding a turbo will cause your mirrors to fail, your tow hooks to fall off, your trans cooler to hide, and your friends will call your truck a "turd gen".
  12. Apr 25, 2022 at 9:26 PM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
  13. Apr 25, 2022 at 9:32 PM
    Booney
    Booney New Member
    YEAHHHH, I can relate!!!!!!!!!!!!!!!!
  14. Apr 26, 2022 at 4:24 AM
    EXCELLENT WRITE UP 10/10 WOULD RECOMMEND NOW I KNOW HOW TO TURBO IRONMAN WILL DO SOON
  15. Apr 26, 2022 at 6:13 AM
    LITTLE DOG
    mark
    2000 tundra 4.7
    turbo 1 BIG T4
    THE TURBOW ON MY TRUCK KICKS ANY TIME YOU LOAD THE ENGINE REGARDLESS OF RPM.
    Mogo Gogo likes this.
  16. Apr 26, 2022 at 6:34 AM
    Turbo pics to confirm legit? :rolleyes:
  17. Apr 26, 2022 at 6:44 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
  18. Apr 26, 2022 at 7:25 AM
    BRO DO YOU HAVE LINKS TO A KIT I WANT ONE NOW IF IT KICKS HARD
  19. Apr 26, 2022 at 7:28 AM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    Wait you’re draining the oil into the valve cover? Is the turbo even high enough to properly drain like that? Unless it’s sticking out of the hood I don’t see a way to have a proper gravity feed from the bottom of the turbo into the valve cover, unless you’re draining it sideways. What are you using to add fuel? How much boost are you pushing? I really want this post to be real but the lack of any info makes it hard to believe
    Darkness, Mogo Gogo, bmf4069 and 2 others like this.
  20. Apr 26, 2022 at 7:36 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
  21. Apr 26, 2022 at 7:36 AM
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    Mogo Gogo and bmf4069 like this.
  22. Apr 26, 2022 at 7:37 AM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    Yeah before I took care of the massive exhaust leaks I was having and rerouting the intercooler piping it didn’t wake up until the top of the power band, but now it spools at about 3k. Smaller is definitely the route.
  23. Apr 26, 2022 at 7:38 AM
    5N0W808, Mogo Gogo and Sirfive like this.
  24. Apr 26, 2022 at 7:38 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
  25. Apr 26, 2022 at 7:40 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
  26. Apr 26, 2022 at 7:44 AM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    It still drives great. I’ve still been figuring out the tuning, it’s got a few spots where it goes a bit lean or rich here and there, but no motor issues. I did break the front driveshaft when doing a 4wd pull, but after seeing how small it is I’m not really surprised. Also my torque converter isn’t happy after downshifting on a long 9% grade at 100mph. Thing slipped and I lost power :(. Might have to look into a th400 swap if I don’t put a manual in it
    Sirfive[QUOTED] likes this.
  27. Apr 26, 2022 at 7:51 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Yessir, stock trans, i’d be apt to roll into the power gently. But surprised it spun the splines off the shaft instead of grenading the front diff.
    I’ll eventually crawl under snowbobs truck and see if the 8” front diff could be swapped easierlyish.
  28. Apr 26, 2022 at 8:10 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I’m really enjoying this.
    des2mtn, Saltyhero13, bmf4069 and 4 others like this.
  29. Apr 26, 2022 at 9:31 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    NO CAPS, NOT SIRIUS !
  30. Apr 26, 2022 at 9:33 AM
    Darkness, bmf4069 and BubbaW[QUOTED] like this.
