More power for Tundra - Quantum solenoid replacement, thoughts?
Discussion in '2nd Gen Tundras (2007-2013)' started by Cg13055, Apr 11, 2022.
  1. Apr 11, 2022 at 8:57 PM
    Cg13055
    Cg13055 [OP] @yota.parts.distributor
    South Florida
    Mcfly Tundra @yota.parts.distributor
    2012’4.0 Tundra-2004’4.7 crewcab-2021 2.7 Tacoma
    I'm gonna drop the link but I wanted to see if anyone else has seen this. It is a first for me and I'm interested but curious as always. I'm all for increasing efficiency but I'd love to hear any stories first. Supposedly is a better solenoid that increases power and efficiency within our engines, they even have one for my 4.0 which I did not expect.
    https://www.qspwr.com/
    This is the company who makes the product, recently saw it on the Gram after a follower @escotundra did an install. He said that it felt like it did what they claimed.
  2. Apr 11, 2022 at 9:01 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Wtf is it? A OBDII module? Sounds like vaporware between all the amazing claims, no actual explanation, and the fancy name.
  3. Apr 11, 2022 at 9:05 PM
    Cg13055
    South Florida
    From what I saw it is a replacement solenoid for the vvt systems. Physically there is some differences that they claim here is the explanation available. I don't want to doubt something I don't know much about but I am curious.
    https://www.qspwr.com/pages/quantum-solenoid-what-how-why
  4. Apr 11, 2022 at 9:07 PM
    Cg13055
    South Florida
    I looked into the technical and it doesn't seem crazy. I am interested in seeing Dyno numbers though
  5. Apr 11, 2022 at 9:12 PM
    snivilous
    SW UT
    Reads like some good bullshit to me. "There is a 10hp gain, which is so small it's hard to notice, but customers say the vehicle is so much better to drive." Yea sure it is. "Aerospace aluminum and higher and tighter tolerances." Wow, so impressed with that unspecified "aerospace aluminum", and are the tolerances higher or tighter? Those aren't synonyms. Etc. Etc. $600-800 is a lot of money to try and make your VVTI apparently react faster, save that money for some gears or buy a tune.
    Cg13055[OP] and Notarobot like this.
  6. Apr 11, 2022 at 9:15 PM
    Cg13055
    South Florida
    I'd love to buy a tune if my truck was supported by a software LOL. Hoping that someone who has bought from them can comment on their experience. I think it's possible that it can change the driving feel but price is steep for what it is considering a stock one is $150
  7. Apr 12, 2022 at 12:28 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I don’t see how this accomplished any Gains.. the vvti angles are fixed by the cam phaser in the engine… unless it’s allowing more pressure in at the same % opening… but that can be done with a tune on the ecm..
    Cg13055[OP] likes this.
  8. Apr 12, 2022 at 3:07 AM
    Adam New Member
  9. Apr 12, 2022 at 6:33 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    The formulation of Snake Oil seems to be constantly changing.
    I foresee a resurgence in (stronger/better) fuel line magnets with the next up tick in fuel prices.
    ...I would wait till the magnates drop. Probably the same "gains" at 5% the cost of these fancy solenoids.
    If Toyota could achieve even a 2% increase in efficiency with "better" solenoids, they would.
  10. Apr 24, 2022 at 2:46 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    A Tune would be better.
    Even if it can increase the pressure through valving to hit VVTI sooner "why?"
    The VVTI is made to come on when the power band becomes inefficient and needs the next to come into place, that would be the equivalent to starting out in 3rd gear instead of letting 1st and 2nd gear do its thing. Sure you can wrap out 80mphs in 3rd and only up to in 45mphs in 2nd but does that mean you want to go into 3rd right away?
    a Tune would allow you all around to control the aspects of how the engine is fueled and where the power band sits and what parts of timing needs to change.
