Siri & Alexa integration (Remotely Start/Stop & Lock/Unlock) via Voice Commands
Discussion in '3rd Gen Tundras (2022+)' started by memphis2k, Apr 24, 2022.
  1. Apr 24, 2022 at 12:49 PM
    memphis2k
    memphis2k [OP] New Member
    Aaron
    2022 Toyota Tundra Platinum, MGM, Adv Pkg, 6.5ft Bed
    Hey all,
    Thought I would post this. I'm a geek so I figured I would play around with these options and see how it goes. You will need the remote connect service that Toyota provides for $80/year.
    Alexa (Amazon Echo)
    You can setup Alexa voice command (remotely start/stop engine & unlock/lock the doors. Go into the Alexa app on your mobile device and search for the skill "Toyota". Add your Toyota account password and create a 4 digit PIN. Anytime you ask Alexa for remote command, she will ask you for your pin. You can't customize the phrases but here are some:
    Alexa, ask toyota to start the engine
    Alexa, ask toyota to stop the engine
    Alexa, ask toyota to start my truck
    Alexa, ask toyota to stop my truck
    Alexa, ask toyota to lock the truck
    Alexa, ask toyota to unlock the truck
    Siri
    Once you have the Toyota app installed and setup. You can search for an apple app called Shortcuts. Click the plus sign and search for Toyota. You should see 4 commands. Remote Start, Remote Stop, Remote UnLock & Remote Lock. There's a LOT of things to play around with. Essentially, you'll want to add all 4 of those shortcuts. Then rename them to fit your needs. Be sure to turn off "Show when run"
    "Hey Siri, start my truck." Works with my Apple Watch & iPhone 13 Pro Max flawlessly.
    I'm sure Google / Android has something similar with Google Assistant but to lazy to setup my Galaxy S10e to do so.
  2. Apr 24, 2022 at 2:05 PM
    mdre
    mdre New Member
    Matthew
    Livermore, CA
    2022 Tundra Limited Crew Max TRD OR 4x4
    Nice, I just finished setting mine up!
  3. Apr 24, 2022 at 3:08 PM
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Bridgestone Dueller Ascent tires
    This seems like a great shortcut - Tks OP
  4. Apr 25, 2022 at 5:58 AM
    capt_beard
    capt_beard New Member
    Ben
    Pittsburgh, PA
    2022 Platinum MGM
    I want to add to this for the Siri Shortcuts functionality.
    If you have other Siri devices, like HomePods, it will work from there as well.
    I can shout in my house "Hey Siri, lock my truck" and she responds with "That's done." and the truck locks within a few seconds.
  5. Apr 25, 2022 at 7:15 AM
    roboots21
    roboots21 New Member
    2022 MGM Tundra Limited DC
    For some reason, the Toyota app is no longer able to be linked with Google to create this set up with the Google Assistance. While a slight annoyance, I just really wanted to tell google to start my truck haha. I'm not going to lose any sleep, but no, currently Google Assistance cannot do this. Perhaps it'll be re-enabled in the future.
  6. Apr 26, 2022 at 1:52 AM
    articdesert
    articdesert Will work for truck parts
    23 1794 MGM
    I saved the start my Toyota as a home button and sometimes when I try to go to use it or the Toyota app it doesn’t open. Like it automatically kicks me out of the app. Not sure why. Maybe my keys need to be closer? :monocle:
  7. Dec 17, 2023 at 9:02 PM
    Hoody
    Hoody Member
    Kommiefornia
    '23 Platinum 6.5 bed
    I know this is an old thread but I have been trying to set up the Toyota account connection on the alexa app and there is no Toyota skill coming up to choose.
    Does anyone know if this still works to remote start via alexa voice command?
  8. Jan 12, 2024 at 3:30 PM
    rhinoj
    rhinoj New Member
    Joe
    2024 Tundra 1794 4X4
    Mud flaps, Truxedo X15 Tonneau cover, AVS hood shield, AVS Vent Visors
    Toyota discontinued the Alexa integration on October 23, 2023.
  9. Jan 12, 2024 at 3:46 PM
    bonestock
    bonestock New Member
    You didn't want the Alexa integration anyway. It was slow and clunky, especially with Amazon requiring a pin every time you wanted to use the commands. If you have Siri, use that instead. Much quicker and you can customize the command
    PikesPeakTRD and Gray Hawk like this.
  10. Jan 12, 2024 at 5:05 PM
    Hoody
    Hoody Member
    Kommiefornia
    We use Samsung phones so no siri. Is there another option for Android phones or maybe through Google?
  11. Jan 12, 2024 at 9:13 PM
    rhinoj
    rhinoj New Member
    Joe
    Agreed, I also have a Samsung phone.
    Hoody likes this.
  12. Jan 13, 2024 at 7:31 AM
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
    I have the Samsung S23 Ultra with the Samsung Watch 6, you can do it on the watch which is quicker than messing with phone.
  13. Jan 13, 2024 at 8:54 AM
    Hoody
    Hoody Member
    Kommiefornia
    Hmm what app or how do you start with the watch? I don't have have a full smart watch just a garmin gps smart watch. It's not like it's really hard to just use the phone app, first world prollems. But the app is kinda buggy and my wife's always logs her out every time so she has to login then it's slow to load and mine logs out often too. Might be cuz we both use the same login as that's the only way I've found we can both have remote access. Just thought it would be easier for her to tell alexa or siri's sister for Google/samsung to start the truck.
  14. Jan 13, 2024 at 9:39 AM
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    I set this up on mine a while back. It was more of a “hey, look what I can do” sort of things. Still pretty fun though.
  15. Jan 13, 2024 at 11:14 AM
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    Yep I have this set up, I feel like knight rider now. For those even old enough to kmow what that is.
    BabyMoose and Maharisc like this.
  16. Jan 13, 2024 at 1:41 PM
    jayluv76
    jayluv76 New Member
    2022 1794 Edition
    ReadyLift 2” Mickey Thompson 275/65/r20
    If we could only rename Siri to Kit ... OMG HOW AWESOME
    BabyMoose likes this.
  17. Jan 14, 2024 at 10:43 PM
    boblc123
    boblc123 New Member
    2024 Tundra Limited 4x4
    I have 2 Toyota's so both are loaded into my app. It looks like this will only work for whatever vehicle you have set as "default" in the Toyota app. I wish I could say "Hey Siri, Start my Van" and "Hey Siri, Start my truck".
