Gun Pics..whatcha got?
Discussion in 'Guns & Hunting' started by R0CKETMAN, May 22, 2017.
  1. Apr 7, 2022 at 5:17 AM
    #3901
    0.S.T.
    0.S.T. New Member
    EAST COAST
    2007 BLACK TUNDRA 4X4 CREWMAX LIMITED 5.7 LITER
    Newest member of the 9mm family. Nice to have another carbine that eats brass out of a Glock mags.
    O.S.T.
  2. Apr 7, 2022 at 6:09 AM
    #3902
    GayFish
    GayFish Member
    2016 Super White SR5 CM 5.7L 4X4
    I think you have more $$$ in optics there than guns.
    Toyotoholic likes this.
  3. Apr 7, 2022 at 1:01 PM
    #3903
    Orracle
    Orracle New Member
    Canton, GA
    Stock up on a little ammo
  4. Apr 7, 2022 at 4:29 PM
    #3904
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Went shooting this weekend, I forgot how much fun the Roni was with my G19X.
  5. Apr 7, 2022 at 5:11 PM
    #3905
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Shhhhhh!!! You better hide that; someone will call it an SBR!
    Ely010606[QUOTED] likes this.
  6. Apr 8, 2022 at 3:08 PM
    #3906
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    I have had this 16 inch Grendel laying around,, only been to the range to check function. Bought two new AGM Rattler Thermals, this one is 35mm. These are amazingly lite and the clarity is awesome!!!:) This is going to be a great hog rifle!!:) will be putting the 60mm on an AR Creedmoor for a friend. 7A9AF7C8-2326-4F3D-B040-75D092B72C32.jpg
  7. Apr 8, 2022 at 4:06 PM
    #3907
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Wife's turn to pick, and we ended up with our first B&T item! Thinking SBR it, get their foregrip and folding stock, EOTech, and their suppressor. Also need to find a better charging handle, and the trigger is absolute ass so relying on finding a way to improve that :D
  8. Apr 10, 2022 at 9:19 PM
    #3908
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I made it a week...well, that's how long the Legion decocker took to show up. Did some minor filing on the grip where the front of the slide release is just to give it a touch more operating room too.
    I also swapped some parts out in my P220.
    It was originally a mix of new and old parts kits, and I discovered there were some incompatibilities that, while still functional, caused it to not run as smooth and clean as it should.
    So, I picked up a proper P220 hammer strut (the one in the gun appears to actually be one for a P226/P229) and swapped that out, along with an aluminum Matrix Precision main spring seat.
    Then, the hammer reset spring/hammer stop pin was also not the correct P220 version (the P220 version is smaller diameter in the center where the reset spring sits), so I swapped that out.
    And the hammer reset spring itself was a bit screwed up (probably from the incorrect pin) and mis-shapen, so I replaced that as well. And finally, the hammer stop itself had been buggered up a bit so I also switched it out.
    I still want to swap out the grip screws - never been a fan of slotted grip screws. And kicking around finding a newer nitron slide instead of the folded carbon one. But really, I just need to get out and shoot it.
  9. Apr 10, 2022 at 9:36 PM
    #3909
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Been eyebaing a micro roni thing for my taurus G3.
    Anyways, just finished a P80 build.
    20220408_110340.jpg 20220408_120804.jpg 20220408_120817.jpg 20220408_121408.jpg
    It was fun as hell getting the guts in the lower.
  10. Apr 10, 2022 at 9:46 PM
    #3910
    RainMan_PNW
    Casey
    Clark County, WA
    Building them is so much fun. Really helps you understand how they function. It’s crazy how simple the Glock is after having built all of the classic Sigs.
  11. Apr 16, 2022 at 9:15 AM
    #3911
    azimuth
    azimuth New Member
    2010 double cab SR5
    New optics on my Grendel build.
    Nightforce 12-42x56 I harvested from my Sako TRG. Moving to a 34mm tube ATACR on the Sako.
  12. Apr 16, 2022 at 5:09 PM
    #3912
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    Built in 2014 when BCM actually had a sale. Geissele MK2 mod 1 rail with BCM BCG and UR. ‘Blem’ PSA LR. DD lpk with Geissele SD3G. HS WML. Unfortunately have sold my aimpoint pro and eotech XPS2. She’s fast
  13. Apr 21, 2022 at 10:11 AM
    #3913
    Orracle
    Orracle New Member
    Canton, GA
  14. Apr 21, 2022 at 10:12 AM
    #3914
    Orracle
    Orracle New Member
    Canton, GA
  15. Apr 22, 2022 at 6:12 PM
    #3915
    Ely010606
    SPARKS, NV
    90D91933-8F67-400E-A7F0-E1DAE2321B29.jpg Just finished another P80 build.
    TNTundra16, equin, Cjames17 and 7 others like this.
  16. Apr 23, 2022 at 12:34 PM
    #3916
    ChattanoogaPhil
    ChattanoogaPhil New Member
    2000 4.7 AC SR5 4wd
  17. Apr 23, 2022 at 12:39 PM
    #3917
    ChattanoogaPhil
    2000 4.7 AC SR5 4wd
  18. Apr 23, 2022 at 8:17 PM
    #3918
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I concur...
    G21
    P226
  19. Apr 23, 2022 at 9:02 PM
    #3919
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Alright dammit, this forum/thread has cost me money again, and you guys are a bad influence.............
    Went to the gun show today, mostly just to walk and get some exercise.
    It doesn't matter I took a handful of cash just in case.
    I was also looking for a 38sp j-frame, I sold a 642 years ago and kinda missed having it around.
    Just happened to take my Kahr CW380, which has been sitting in the safe for years, along for the ride.
    I prefer my LCP for pocket carry, so I have no need for another 380auto pocket pistol.
    Had the original box/paperwork, 2 mags, a Pachmyer glove, and a High Noon Pocket grabber holster.
    104C169B-7B6D-4215-8C4A-43555FC7B22F_zps_382b1f57d47d943141c94ad56dea8f40e8303ffa.jpg
    254087BC-889E-4782-8726-9656ED2B3D0D_zps_da40df2368c506ca63ec83e58aa5c69ee99a6299.jpg
    Sold the Kahr in the first 10 minutes, got that out of the way.
    Now I've been a die-hard Glock guy for several years.
    Owned many/several a Sig in the early 2000s, and sold them all off, except my 2 WG Sigs, P228 and P226.
    My last Glock purchase was a 43X, it never really fit well in my hand, my Glock double stacks fit fine.
    Bought 3 Shield 15 rd mags and Sheild's metal mag catch for it, but it's been sitting in the safe for a while.
    Almost took to it to sell at the show today, but figured I'd hold on to it and eventually give it to my daughter.
    Some of you have been ranting and raving about the Sig P365 and P365XL.
    I figured nah, I've got the 43X even though it really doesn't excite me.
    I love Glocks, I'll never buy another Sig pistol.
    I'd never held a P365XL, until today, wow was it nice.
    Held it side by side to a 43X and the P365XL really felt good in the hand.
    Shook it off, I don't need it and kept walking.
    Every table I walked up to I held another P365XL, kinda taking notice of the price.
    Damn, it's nice and it has a red dot sight on it, kinda always wanted one of those.
    Found another table that had both, P365XL and S&W 442.
    I asked if he'd knock off $60 if I bought them both and he hesitantly agreed.
    So thanks to the peer pressure of this forum, I own another Sig.
    In all my pistols I've never had a flat trigger and I think I like it.
    BTW, the daughter still ends up with the gun, eventually.
    Hopefully it will be awhile..:D
    Looks like the 43x is possibly going up for local sale to fund the P365 purchase..
    My God, I hope I don't get caught up in the Signess again, I'd have way too my Glocks to replace...
    3e00e19a-2a06-4dd4-860e-3811b3bcacae_zps_6d7deee6fb0ac83a3b0c4b3239802001c40d116f.jpg
    WVI, Fiesta346, jewsNbrews and 10 others like this.
  20. Apr 23, 2022 at 9:09 PM
    #3920
    Tripleconpanna
    Forum didn't cost you money; going to the gun show cost you money!!!!
  21. Apr 23, 2022 at 9:10 PM
    #3921
    Ely010606
    SPARKS, NV
    Congrats on the purchase’s. The 365XL is a great shooter,
    1lowlife[QUOTED] likes this.
  22. Apr 23, 2022 at 9:17 PM
    #3922
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    SH!t, this forum last influenced me to spend over $20K on my 2014.
    I would haven't even picked up and held another Sig if for not seeing others cooing about it here..
    How dare you hold me responsible for my actions?
    We don't live in that world anymore...:eek2::mad::cool:
  23. Apr 23, 2022 at 9:26 PM
    #3923
    Tripleconpanna
    :cheers:
  24. Apr 23, 2022 at 9:30 PM
    #3924
    Grumpy74
    Grumpy74 New Member
    2005 White Tundra SR5
    I added a Rock River Arms A2 carry handle to my S&W Sport II AR-15. It came with a flip up sight, but I'm a traditional kinda guy.
  25. Apr 29, 2022 at 9:36 PM
    #3925
    Hotwire
    Hotwire New Member
    Montana
    2008 Tundra SR5 double cab
    A few of my favorites. Unfortunately they were all lost in a boating accident a few months back.
  26. Apr 29, 2022 at 10:18 PM
    #3926
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Hope that carpet went down with them..:eek2:
    Tundra14Platinum likes this.
  27. Apr 29, 2022 at 10:41 PM
    #3927
    rmvcard0303
    rmvcard0303 New Member
    Ray
    San Gabriel Valley, CA
    2019 White Tundra TRD Sport CM
    I’d rather not list. My wife might see it.
  28. Apr 30, 2022 at 2:09 AM
    #3928
    TundraPatriot
    TundraPatriot New Member
    Glenn
    The Great State of Texas
    2022 Black Tundra Platinum 4X4 i-Force Max Hybrid
    Say hello to my little friend.
  29. Apr 30, 2022 at 4:39 PM
    #3929
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    I just dropped an Apex Duty/Carry Spring Kit in my 442.
    Install video in this link.
    Duty/Carry Spring Kit for J-Frame Revolvers (apextactical.com)
    The trigger feels much better, the wife even likes it now.
    She felt the trigger pull was too heavy when stock..
    Took about 20 minutes and that was with me moving slowly to avoid idiot marks on my screws.
    I used a SMITHMASTER™ - TRIGGER SPRING TOOL FOR S&W® REVOLVERS
    Made removal and installation of the trigger spring easy.
    SmithMaster™ - trigger spring tool for S&W® Revolvers (gunsmithertools.com)
    Now if I can just get to the range...
  30. Apr 30, 2022 at 5:07 PM
    #3930
    snivilous
    SW UT
    I've been wanting a Virtus or Rattler in 300 for awhile, looks awesome!
