10k vs 12k winch
Discussion in 'Recovery & Gear' started by Tundra18overland, Apr 22, 2022.
  1. Apr 22, 2022 at 12:54 PM
    Tundra18overland
    Tundra18overland [OP] Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    seen a few threads on this so I’ll keep it short and sweet…
    my buddy is selling his modded tundra and is willing to swap winches with me before the sale
    my winch: warn vr evo 12k steel cable ($700)
    his winch: warn zeon 10-S platinum ($2700 and extremely nice winch with lots of remote control features to include clutch engage/disengage from the remote, 20% faster line speed, etc)
    I know I can increase the winches effectiveness with snatch blocks and different line pulls, but my concern is I still lose 2,000 lbs of pulling capacity.
    GVWR of my truck: 7200 lbs
    2018 SR5 CM 4x4
    I read warn recommends to multiply your gvwr by 1.5 to get your ideal winch lb rating. 7200 x 1.5 = 10,800 lbs which means I’m already over the 10k lb rating of the winch out of the gate before my current mods that are on my truck (bumper, skids, sliders etc)
    what would you do?
  2. Apr 22, 2022 at 1:04 PM
    badmotofing3r
    badmotofing3r To be so civilized, one must tell civil lies
    Zach
    Wyoming
    Hot Tamale
    Toytec lift and the works
    I was in the same boat winch capacity wise when looking to buy a winch this summer. I honestly ended up with the 10k Smittybilt X20 Synthetic. I couldn't pass up on the deal that I got. I deeply/secretly wanted the 12k but life is such. In this situation when you're comparing two totally different class of winches I'd give up the 2k lbs for the convenience and quality of the Zeon.
    Now if we were on a Cummins or Duramax forum I'd have a different answer.
    Tundra18overland[OP] likes this.
  3. Apr 22, 2022 at 1:05 PM
    badmotofing3r
    Zach
    Wyoming
    Hot Tamale
    Is he cool with an even swap? If so, that's a generous friend of yours.
  4. Apr 22, 2022 at 1:13 PM
    Tundra18overland
    Jesse
    GA
    Thanks for the input. I feel the same way. He knows the swap is uneven lol he’s a very close friend.
  5. Apr 22, 2022 at 2:30 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Id jump on it, better unit and you an use a snatch if you need extra pull power. But I bet you won't need the extra pull.
  6. Apr 22, 2022 at 10:08 PM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    Sounds like a good deal from a good friend. Go for it.
  7. Apr 22, 2022 at 10:40 PM
    Do it.
    Only situation I would say no would be long pulls in mud.
  8. Apr 23, 2022 at 12:58 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Get the Zeon. Those are still US made from what i recall, much nicer unit. Lots of people on here run 10k winches. Knowledge of proper winching technique and snatch blocks are important though.
