Looking like I skipped every single leg day...
Discussion in '2.5 Gen Tundras (2014-2021)' started by ikka, Apr 22, 2022.
  1. Apr 22, 2022 at 5:44 PM
    ikka
    ikka [OP] New Member
    Can I fit Falken Wildpeaks 295/70r18s with my TRD Offroads and 3/2 readylift?
    Spacers necessary?
  2. Apr 22, 2022 at 5:45 PM
    Taco-Spike
    Two Trucks
    Nah, looks good. Looks like a it’s waiting for an upgrade though
  3. Apr 22, 2022 at 7:03 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Is say yep. Likely need mudflat removal or trimming and roll the sides of the skid plate up.
    pvn.beluga likes this.
  4. Apr 22, 2022 at 7:05 PM
    ikka
    I can handle that. Thanks.
  5. Apr 22, 2022 at 7:09 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Definitely nothing major trying to fit 295s with stock TRD wheels.
  6. Apr 23, 2022 at 4:22 AM
    ikka
    OK that's great news. Tires ordered. Should I order spacers just in case?
  7. Apr 23, 2022 at 4:40 AM
    1794TX
    Steven
    N.TX
    '20 1794
    This thread will do you some good.
    As mentioned above, you may rub on the front bumper. You can adjust the plastic and remove the spats (front mudflaps), or you can shim out the front bumper. Some folks like the look of no spats, so personal choice may play into whether to shim or trim. I shimmed, and I like the look of it.
    Welcome to the forum. Hide your wallet as you browse around...
    KatoK, panicman and TRDFerguson like this.
  8. Apr 23, 2022 at 4:46 AM
    ikka
    Thanks for the link. My concerns come from this user post about the 295/70r18 on stock TRD Offroad rims hitting the UCA. He appears to have the bilstein 5100 on middle setting however... is that much different than a 3 inch spacer lift?
    Post that gives me doubts: https://www.tundras.com/threads/295-70-18-tire-thread.73944/page-3
  9. Apr 23, 2022 at 4:59 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Those wheels are a +60 offset, which is tucked in quite a bit. 295's are probably going to rub on the UCAs, and will definitely rub on that stock piece of foil Toyota calls a skid plate. If you're dead set on keeping those wheels (and why wouldn't you be - they're handsome), it'll probably do to have good spacers on hand. Hub-centric, specific to your truck; and my research (before I decided on the setup I have) made me believe that Spidertrax were the best. Lots of other folks' experience to be gained on the forum for sure - but that's why you're here.
    Good luck, and great looking truck.
  10. Apr 23, 2022 at 5:05 AM
    ikka
    Thanks but spacers scare me. If I was to look for new wheels, what offset should I be looking for?
  11. Apr 23, 2022 at 5:25 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Nothing wrong with spacers if you install them properly and ensure they’re torqued to spec.
    I’ve got 2 pairs if you’re looking to purchase some.
    If you’re looking for wheels, then anything around the 18-25 offset are the sweet spot.
    1794TX likes this.
  12. Apr 23, 2022 at 5:31 AM
    NoRcptn
    NorCal
    2017 Platinum
  13. Apr 23, 2022 at 6:36 AM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    1794TX and ikka[OP] like this.
  14. Apr 23, 2022 at 7:06 AM
    ikka
    Great link. You are right there are a number of TRD pro posts in that link with 295/70r18s with no spacers and little modifications. I'm assuming my limited with 3/2 kit is about the same clearances as a TRD Pro?
  15. Apr 23, 2022 at 7:10 AM
    I don’t see the problem here….looks great to me!
  16. Apr 23, 2022 at 7:11 AM
    ikka
    Those skinny little ankles. Lmao
  17. Apr 23, 2022 at 7:12 AM
    You making fun of my manly ankles?
  18. Apr 23, 2022 at 7:14 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    What steps are those?
    Thanks..
  19. Apr 23, 2022 at 7:30 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    yes, that can work. 285/70-18 and 285/75-18 are good options as well.
  20. Apr 23, 2022 at 9:26 AM
    NoRcptn
    NorCal
    2017 Platinum
    :rofl::rofl::rofl::rofl:
  21. Apr 23, 2022 at 11:48 AM
    FISHN43
    FISHN43 New Member
    Ohio
    A stock Pro is about 2” higher in the front (leveled) than other Tundra models. So your 1” higher than that in the front and 2” higher in the rear. You’ll have plenty of room.
    ikka[QUOTED][OP] likes this.
  22. Apr 23, 2022 at 4:28 PM
    ikka
    Go Rhino RB20. Cheapest I found was on Amazon. Make sure you order the ones that come with the mounting brackets. They sell just the boards but that won't do you any good. I like them.
    1lowlife[QUOTED] likes this.
  23. Apr 23, 2022 at 5:51 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    I like them.
    I'm thinking about pulling and selling my Amp power steps.
    I had a lot fewer parking lot door dents with the OEM stationary tube steps.
    May not help, I'm running 275/60/20 33" tires with a 2.5 lift/level.
    I think it looks fine.
    Just having an AT tire, with an aggressive tread and sidewall, will look better than a street tire..
    86BB3E0F-7B35-440A-A7EB-73DE0AC53289_zps_052b7c82351916097889b54aec3badbbc4d76c49.jpg
    I like these DT Goodyears, happy with them for over a year.
    Goodyear Wrangler UltraTerrain AT | Discount Tire
    Your truck looks great......
  24. Apr 23, 2022 at 8:12 PM
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    37s and don’t look back
  25. Apr 23, 2022 at 8:17 PM
    TaquitoBandito
    Joel (AKA Bif)
    When did he check his legs out of the hospital?
  26. Apr 24, 2022 at 3:51 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    :sawzall::sawzall::sawzall:
    HulkSmurf14 likes this.
