Instead of 2 inch wheel spacers
Discussion in '2.5 Gen Tundras (2014-2021)' started by Chankins34, Apr 20, 2022.
  1. Apr 20, 2022 at 6:49 AM
    Chankins34
    Chankins34 [OP] New Member
    Cory
    2014 blk sr5 crewmax
    10 series exhaust Chrome delete Toolbox Full led upgrade Aftermarket taillights 2020 trd pro grille Bulge lights bed lights
    So I'm looking to buy rims, my tundra came with fender flares and I've been told hell no on spacers and I know a 2 inch spacer would be what I need to make my tires stick out from the truck and not be tucked under the truck i hate it looks like that haha, I'm wonder if yall know what off set I need on rims to get the wheels untucked thanks in advance!
  2. Apr 20, 2022 at 6:52 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    so to get away from the parade float look, you need to first let us see or know what size flares you have to know how much they stick out from the body of the truck. stock offset is +60. if you have flares that stick out 2", you'll want to get something around +10 to maybe -10 offset. that opens up the issues of tire sizes and rubbing as well. assuming you're stock suspension and stock tires
    MadMaxCanon likes this.
  3. Apr 20, 2022 at 6:52 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Well 2 inches is about 51mm, so if you have stock wheels right now, which are +60mm, then you would need to get aftermarket wheels with +10 offset for exactly 2 inches of stick out. I dont really think there are any wheels with that offset, closest ones would be 0 offset, there are alot in that size. 0 offset would stick your rims out about 2.3"
    Chankins34[OP] likes this.
  4. Apr 20, 2022 at 6:55 AM
    I have a 0 offset and Bushwacker flares. My tires (285/70/18 Ridge Grapplers) are flush with the outer edge of the flares.
    Booney and Chankins34[OP] like this.
  5. Apr 20, 2022 at 7:45 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Remove the flares, then you’ll be 2” closer to a poke.
  6. Apr 20, 2022 at 9:17 AM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    I think you'd be happy with the 9" +25, 35x13 setup I have. Each side sticks out ~2" more than stock.
    Tundras look way better with taller and wider tires. You'll want to lift the front a little, do the BMC, and play with the plastic while you are at it...
  7. Apr 20, 2022 at 3:34 PM
    Chankins34
    Cory
    285/55/r20 stock suspension but also have a rough country leveling kit to be put on in the near future
  8. Apr 20, 2022 at 3:41 PM
    Chankins34
    Cory
    Yeah I could but then I have to get the paint redone which is Yeats off but in the works plus I like the flares
  9. Apr 21, 2022 at 4:45 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I have Level8 MK6 wheels and love them. I believe they're +18. Plus they're very affordable, they made them specifically for the Toyota crowd.
  10. Apr 21, 2022 at 4:56 AM
  11. Apr 21, 2022 at 4:58 AM
    Chankins34
    Cory
    2mchfun likes this.
  12. Apr 21, 2022 at 4:58 AM
    :hattip:
  13. Apr 21, 2022 at 5:32 AM
    2mchfun
    Change the flares to EAG flares with a low profile (about 5/8"). They finish the wheel wells quite nicely. Then go with a +25 or +30 rim offset. Note: These flares are textured matte black. The more wide the stance, the greater the load on the wheel bearings.
  14. Apr 21, 2022 at 7:01 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    My Fuel Shok wheels are +1 and were right at flush with my pocket flares. I've pulled the flares to enjoy more poke.
    Booney likes this.
  15. Apr 21, 2022 at 7:21 AM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    I have 0 offset. You should be good with around 0 to +1. Here are some pics to give you an idea where the tires sit with fender flares on. Something you might look at is how far out your project from actual fenders. Mine project out 1 3/4 inches. It looks like yours might stick out more than that which, even with the 0 offset, would not sit out flush with the tread of your tires.
  16. Apr 21, 2022 at 7:38 AM
    rruff
    rruff New Member
    Tire size?
  17. Apr 21, 2022 at 7:46 AM
    Booney
    Booney New Member
    LT315/70R17 Falken Wildpeak A/T3W
    Pretty close to 35X12.50.
    rruff[QUOTED] likes this.
  18. Apr 21, 2022 at 8:35 AM
    rruff
    rruff New Member
    What mods did you make for clearance?
  19. Apr 21, 2022 at 8:47 AM
    Booney
    Booney New Member
    Fox 2.5 Factory Race Series coilover remote reservoir shocks on front and back. Coachbuilder 3" shackles (1.5 inch lift) on the back. Diff Drop Spacers. Specialty Products UCA.
  20. Apr 21, 2022 at 9:04 AM
    rruff
    rruff New Member
    No wheelwell mods? Plastic, bumper, pinchweld, BMC, etc...
    Does it rub at any time, like when you hit a large bump when turning?
  21. Apr 21, 2022 at 10:49 AM
    Booney
    Booney New Member
    Just removed the front wheel well liners inside. They could probably have been modified to fit with a heat gun but I am getting a new bumper and the front wheel well liner will go away anyway so I figured I would go ahead and just remove it. Didn't' have to do a BMC. Nothing touches or rubs.
  22. Apr 21, 2022 at 2:50 PM
    rruff
    rruff New Member
    That's good info. Your tires are just a hair smaller than mine, but the 25mm of extra outward offset will make the rubbing issues worse. I debated the BMC. I was pretty sure I wouldn't need it if I used the LCA cams to move the wheel forward (more caster), but then the front would have rubbed. I did heatgun the liner and moved it forward, but it was still damn close. I could have spaced the bumper out though, that would have been easy. Anyway, I chopped off the offending part of the body mount, and didn't bother to weld a new piece on it... it was kinda fun taking an angle grinder to my brand new truck...
    With a lift on stock UCAs you lose caster, and camber goes up (top of tire sticks out). Aftermarket UCAs will move the upper balljoint in and rearward to compensate for this, so your alignment will be close with alignment cams in the stock position. This also moves your wheel rearward a bit in the well... which is not good for BMC avoidance! But you also have adjustable UCAs so you can move that balljoint forward some and crank the rear LCA pivot out and the front one in to give you lots of caster; then the wheel would be forward in the well. Then you can more easily avoid the BMC and have plenty of room! Hope that makes sense...
    I just got a lift recently; 2" and stock UCAs. I moved the rear LCA pivot out all the way out, with the front left in the stock (centered) position; this puts the camber back at ~0 where it needs to be, and caster is less than at stock height, but it's whatever it is. This should give me a bit better BM clearance under compression relative to no lift, and that's where you need it.
    I guess the moral of the story is that I bet you are really close to BM rub at the extreme (turning + full compression), but I think you'll be able to fix it with your adjustable UCAs if that is the case. :thumbsup:
  23. Apr 21, 2022 at 5:16 PM
    Booney
    Booney New Member
    I have no problems. Everything works great. :thumbsup:
