Bilstein 5100 on front only
Discussion in 'Suspension' started by spyshot, Apr 16, 2022.
  1. Apr 16, 2022 at 5:16 PM
    spyshot
    spyshot [OP] 1Cor 15:55-57
    Ohio
    2019 Tundra Platinum
    Platinum pretending to be Pro
    Looking to level my truck and I don't think I like the idea of a spacer so I'm looking at using 5100's in the front only. I have a truck cap so my rake is only 1-5/8" right now. So I'm thinking the middle setting on the 5100's will be just right if I leave the rear alone.
    1- Specs show the middle setting is a 1.57" lift. Is that realistic, or will it actually be less?
    2- Any reason only replacing the front shocks would be a bad idea? I don't want to lift the truck any more, just level the front.
    3-Thinking of going to a 285/70-18 tire. Sounds like there will not be rubbing from what I've read, or maybe I should go 275/70-18 to be sure.
    4-Is a diff drop recommended?
    2019 Platinum with tow pkg and rear sway bar. 35k miles
    Thanks folks!
  2. Apr 16, 2022 at 5:29 PM
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    I put 5100’s on my front, lowest setting for just under 1” of lift. The expected lift according to Bilstein was .9” iirc, so they were spot on. I reused the stock springs. I do light towing occasionally, so this left some rake, a little over an inch, but you have to look real close to notice it's not level. 275/70’s rubbed after the lift at full lock, a RCI skid plate eliminated that. It rubbed on the outside edge of the factory front skid plate. Could have modified the plate, but had the beefier RCI on order.
  3. Apr 16, 2022 at 5:32 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Pics! We likey Pixs here. Thanks.
  4. Apr 16, 2022 at 5:42 PM
    Infernotundra17
    Infernotundra17 2017 Inferno SR5 Crew Max
    Martin
    Las Vegas, Nevada
    2017 Tundra Inferno orange
    Black Rhino 20" Go Rhino RB20 steps Magnaflow muffler
    I have a 2017 SR5 crew max 2wdIMG_5021.jpg with the 5100 in the middle setting and works great and nice ride.I have 305/65 18" Nitto Ridge grapplers .Mud flaps cut to clear
    mattyd170 likes this.
  5. Apr 16, 2022 at 5:44 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    1. It’ll all depend, but I’m sure you’ll get close to the middle setting measurements. Best bet is to just measure BEFORE you lift and after you lift.
    2. I ran 5100s front only for about a week and that leveled look wasn’t for me. You mentioned that you have a cap; that’s added weight to your bed. I’d suggest running shackles too, so that way your Tundra wouldn’t look like it’s squatting when you have some weight on your bed.
    3. 285/70 will probably rub slightly. Most times it’ll be your mud flaps or OEM skid plate. It won’t be anything major.
    4. No, not unless if you’re going 3”+.
  6. Apr 16, 2022 at 6:43 PM
    Dantdodge
    Dantdodge New Member
    Danny
    Tampa
    2018 tundra sr5 crewmax trd 4x4
    Stock trd off road
    Just recently did what you are looking to do.
    275 70 r18 +25 offset had to remove front mud flaps.
    ATV25, mattyd170 and AGSport like this.
  7. Apr 16, 2022 at 7:48 PM
    mattyd170
    mattyd170 New Member
    Albuquerque, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    TRD Front Suspension, Bilstein Rear, TRD rear sway bar kit, 35" tires, working on stereo.
    Do the 5100s on the middle setting with a coachbuilder shim, 1 on the passenger side and 2 on the driver side. I did exactly this on my platinum before and put on 275/60r20 Falken tires. Looked and rode amazingly. I am struggling right now with what to do to my new truck in the front. But you will LOVE the 5100s on the middle setting. I did the shims, just cause I wanted to, but not necessary.
    Dantdodge likes this.
  8. Apr 16, 2022 at 8:06 PM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    KIMG0260.jpg5100s middle clip, 275/70/18, +25 offset, no diff drop, no rubbing. Bilstein specs on height are spot on, love the way it turned out.
  9. Apr 16, 2022 at 9:22 PM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    5100s middle setting. Measured 37.5” from ground to fender on both driver and passenger fronts and then 39” from ground to fender on both driver and passenger rears
    MER likes this.
  10. Apr 21, 2022 at 12:46 PM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    5100 middle setting 1/4 maybe rake
    mattyd170 and clarkritchie like this.
  11. Apr 22, 2022 at 4:44 AM
    spyshot
    Ohio
    Thanks for the replies on this. Very helpful!
  12. May 18, 2022 at 4:24 PM
    spyshot
    Ohio
    Do you suppose this will hold true even though I have stock TRD wheels with +60 (I think) offset?
