Running boards
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ernie68, Apr 19, 2022.
  1. Apr 19, 2022 at 3:37 PM
    Ernie68
    Ernie68 [OP] New Member
    Ernie
    2019 SR5 white 4x4
    Added retractable bed cover Interior carbon fiber trim
    What running boards is everyone using? I had got a set of Oedro 6.5 running boards last week. Today I hit a tree stump and the brackets folded (don’t ask lol). If I was off-roading the same thing would’ve happened. What running boards have better brackets? I called their customer service and they’re sending me a new set but I will get something sturdier so this won’t happen again.
    Let me see your brackets and running boards if you can. Thanks
  2. Apr 19, 2022 at 4:37 PM
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    I WONT recommend iboards if you are off road or running over stumps. Mine look and function nice, but theyr no slider
    Booney, Saltyhero13 and Ernie68[OP] like this.
  3. Apr 20, 2022 at 11:43 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    All of the running boards mount very similar and will bend/break hitting things when off road. So if you off road a lot, skip the running boards, remove them when you go wheeling or get frame mounted sliders instead.
    FlyingWolfe and Ernie68[OP] like this.
  4. Apr 20, 2022 at 12:22 PM
    Ernie68
    Ernie
    2019 SR5 white 4x4
    From what I've seen in differences between the two, you're right! I don't go offroading at all just a mishap on my part with the tree stump. Luckily the manufacturer is sending me new brackets.
    tundratoofun likes this.
  5. Apr 20, 2022 at 12:26 PM
    tundratoofun
    Glendale
    Beast
    Thats a win!!
    Ernie68[OP] likes this.
  6. Apr 21, 2022 at 8:17 AM
    EricD
    EricD And so it begins.
    Eric
    North Carolina
    2021 Toyota Tundra
    LR23 likes this.
  7. Apr 21, 2022 at 8:23 AM
    LR23
    LR23 New Member
    NC
    2021 TRD Pro
    Another vote for the RB20s. Just put them on my 21 and I really like the look and function coming from drop steps. May or may not be any sturdier than what you have now, but definitely good for every day use.
    I'm also in NC - Piedmont area now, but originally from the 828 and had the Tundra up there last weekend.
    EricD[QUOTED] likes this.
  8. Apr 21, 2022 at 9:43 AM
    2mchfun
    I have angle iron under my step tubes and mounted to the frame and each other with channel iron. So, basically steps, sliders, side impact protection, and cat/transmission, trans case protection all in one.
  9. Apr 21, 2022 at 9:47 AM
    tundratoofun
    Glendale
    Beast
    Nerf bar skid sliders? Thats fuckin awesome!!
    2mchfun[QUOTED] likes this.
  10. Apr 21, 2022 at 9:48 AM
    EricD
    Eric
    North Carolina
    2021 Toyota Tundra
    You should share some pictures.
  11. Apr 21, 2022 at 9:51 AM
    2mchfun
  12. Apr 21, 2022 at 9:56 AM
    2mchfun
