Just joined, looking for some advice
Discussion in 'New Member Introductions' started by -PUG LIFE-, Apr 13, 2022.
  1. Apr 13, 2022 at 1:39 PM
    -PUG LIFE-
    -PUG LIFE- [OP] New Member
    Dillon
    Huntsville, AL
    2021 Cement CM SR5 Trail Edition
    Hello, new member here so excuse me if I’m not sure how all this works just yet, but do have a few questions if anyone could help out or point me in the right direction.
    Just bought a 2018 Tundra SR5 TRD Off-Road recently. It already had what “looks” to be the Procomp stage 1 7” lift installed. ( I assume stage one because of the spacers on top in the front) Also has some Procomp 20”wheels with Procomp 37” tires.
    After reading on here for a couple months about different mods, I’m starting to get the itch to change a few things up and make it my own.
    In no particular order some of my thoughts below:
    1. What I’m looking at doing is completely change out the lift kit (if I’m able to do that) and was looking at the BDS 4.5 coilover. Would be getting everything available with that kit including traction bars in the next few months. (looking to SC in the near future as well) . One question I had about swapping lifts is that I currently still have my factory UCAs with the current set up. Would it benefit me now to change my UCAs now or wait until I get my new lift. If so which brand, I’ve read everything from cam burgs, spc, total chaos and a few others.
    2. Also with dropping in lift size from Procomp 7” to the BDS 4.5, I was also going to drop down to 35s as well. I’m dropping in both to try and fit in my garage and keep out of the elements here in MS.
    3. It is my daily driver and I never tow anything as of right now. Possibly in the future I will have a bass boat but that would be about the most towing I would ever do.
    4. I have also read how much happier our trucks are with the Regearing and will definitely be looking to Regear with the 5.29s after everything I’ve read on here. But I was hoping with dropping in tire size I could hold off a little longer before the Regear.
    5. Like I said before it is my daily driver so I’m mostly on the highway, but will go off-road when I get the time. Nothing too serious just some muddy spots here and there, nothing to consider “serious” off-road.
    Sorry for the long post but hopefully some insight and suggestions would be welcome as I will continue to read as much as I can on here as well,
    Thanks in advance!
    Here are a few pics of the truck:
    upload_2022-4-13_15-39-4.jpgupload_2022-4-13_15-39-4.jpgupload_2022-4-13_15-39-4.jpgupload_2022-4-13_15-39-4.jpgupload_2022-4-13_15-39-4.jpgupload_2022-4-13_15-39-4.jpgupload_2022-4-13_15-39-4.jpg
  2. Apr 13, 2022 at 1:42 PM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  3. Apr 13, 2022 at 3:11 PM
    -PUG LIFE-
    Dillon
    Huntsville, AL
    Thank you, glad to be here
  4. Apr 13, 2022 at 3:13 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  5. Apr 13, 2022 at 3:17 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Welcome from TX and welcome to the MGM Crüe!
    Unless you have alignment issues right now, I don't see a point in upgrading UCAs until you put the new lift on.
    As for re-gearing, I'd personally opt for 5.29s as that leaves you room to up your tires back to 37s should you want and the price point is no different from 4.88s.
  6. Apr 13, 2022 at 3:21 PM
    Welcome from Ohio.
  7. Apr 13, 2022 at 3:28 PM
    RoadtripJim
    RoadtripJim New Member
    Cedar, MN
    2021 Silver SR5 - TRD Double Cab
    Welcome and greetings from Minnesota. Nice looking truck.
  8. Apr 13, 2022 at 3:43 PM
    -PUG LIFE-
    Dillon
    Huntsville, AL
    Thanks everyone.
    @texasrho83 it seems as though the out edge of my tires are wearing just a little faster then the inside as of right now. It does drive straight down the road and doesn’t pull to either side as of right now. Just didn’t know if I would benefit from goin ahead and doin that now, but makes since to do it when I replace the lift and everything together.
    But for sure I’m leaning towards the 5.29s after everything I’ve been reading on here.
    Thanks for the reply.
  9. Apr 13, 2022 at 4:08 PM
    Welcome aboard sir! The Procomp 7” lift is what’s called a cradle or drop bracket lift. Some require permanent modifications to the frame and suspension mounting points. If the original mounting points are still intact, and nothing has been cut away, you may be able to revert to stock, or a non-bracket lift at great cost. It’s the cutting required for these kits that may make this expensive or a no go.
    TheBeast likes this.
  10. Apr 13, 2022 at 4:13 PM
    -PUG LIFE-
    Dillon
    Huntsville, AL
    @KNABORES I believe mine has been cut, I’ll have to take some pics once this storm passes tomorrow. But I believe I do have the procomp that had the crossmember cut for the drop bracket. I know once it’s been cut that you’re for the most part stuck with that unless you’re willing to drop serious money. That’s why I was mentioning just going with the BDS 4.5 lift with it being a drop bracket as well. Or would this not work with it being 2 different brands??
  11. Apr 13, 2022 at 4:28 PM
    Take some pics of the front suspension when you get a chance and share them here. May shed some light on your options
  12. Apr 13, 2022 at 4:33 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If you don't have to replace tires right away and you aren't fighting the wheel driving down the road, I'd say leave it be. Then again, it isn't hard to replace uppers yourself, just be sure to get it aligned afterwards.
  13. Apr 13, 2022 at 4:37 PM
    -PUG LIFE-
    Dillon
    Huntsville, AL
    @KNABORES will do when the weather is better. Prolly won’t be till tomorrow afternoon after work though.
    @texasrho83 no not at all at the moment. I just know that I would most likely have to drop down to 35s whenever I do the lift cause I don’t believe I have the BMC to keep the 37s if they would even work with the 4.5 BDS
  14. Apr 13, 2022 at 6:07 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    Welcome from Pa.
  15. Apr 13, 2022 at 7:12 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  16. Apr 13, 2022 at 8:44 PM
    Welcome from NY.
  17. Apr 15, 2022 at 5:35 PM
    -PUG LIFE-
    Dillon
    Huntsville, AL
    Thanks everyone for the welcome, and @KNABORES here are the pics of the front. Sorry for the late response. I also made another post in 2.5 gen forum today for recommendations also.
    upload_2022-4-15_19-35-4.jpgupload_2022-4-15_19-35-4.jpgupload_2022-4-15_19-35-4.jpgupload_2022-4-15_19-35-4.jpgupload_2022-4-15_19-35-4.jpgupload_2022-4-15_19-35-4.jpgupload_2022-4-15_19-35-4.jpg
  18. Apr 15, 2022 at 9:00 PM
    Don’t have experience with these lifts, but could you take the rubber spacer or the metal spacer off and lower the front 3” or so? The A arms seem to have plenty range of motion to come down a little
  19. Apr 16, 2022 at 5:52 AM
    Also, your tie rod end boots look destroyed
  20. Apr 16, 2022 at 6:23 AM
    -PUG LIFE-
    Dillon
    Huntsville, AL
    @KNABORES yes I noticed that also, I’m bout to be placing and order for the Coachbuilder steering kit here in the next couple days. I know I’ve read that would also help with the steering as well with the oversized tires. Would that solve this problem as well?
  21. Apr 18, 2022 at 11:44 PM
    kogswell21
    kogswell21 New Member
    So.Cal and da 808!!
    2019 MGM 4x4 crew cab
    Welcome from SoCal..
  22. Apr 18, 2022 at 11:44 PM
    kogswell21
    So.Cal and da 808!!
    Love that color!!
  23. Apr 21, 2022 at 7:03 AM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Welcome!
