Adding heated seats to SR5 2021
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bradyboyy88, Apr 20, 2022.
  1. Apr 20, 2022 at 3:41 PM
    Bradyboyy88
    Bradyboyy88 [OP] New Member
    Shaun
    The 2021 sr5 trd off road has the dual climate control panel. Is there anyway to add heated seats and use the oem seat heater switches in the limited? Not a fan of the aftermarket switches and like the look of how the limited is setup.
    thanks
  2. Apr 20, 2022 at 7:39 PM
    SwitchThrottle
    2021 Barcelona CrewMax
    I was looking to do the same, but my guess is it will probably be cost prohibitive unless you are lucky enough to find a late model limited, platinum or 1794 part out.
    As far as I can tell the switches are part of the HVAC controls (even though it looks like a separate lower bezel with switches). I am thinking you may have to order something like toyota-temp-control-559000c190 or whatever the equivalent is with switches. None of the outline graphics for the various HVAC controls show the switches though so...:notsure:
  3. Apr 20, 2022 at 7:40 PM
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    nope, you will have to go with aftermarket seat covers unfortunately.
