Teannu w/ bed Rack , Molle, and Overland
Discussion in 'Recovery & Gear' started by Wakekid686, Apr 18, 2022.
  1. Apr 18, 2022 at 8:10 PM
    Wakekid686
    Wakekid686 [OP] New Member
    Trying to see if anyone is running a "retrax" style sliding HARD teannu cover with a "usable" bed-rack system?
    I've seen some bed racka that have the rail extenders (if you will) but I'm curious how sturdy those actually are?
    End goal - I would like to have a retractable HARD teannu cover with a bed rack system that can support enough weight for 2 adults camping. So I'm guessing up to 500-600 static lbs on the rack?
    What is everyone using?
  2. Apr 18, 2022 at 8:14 PM
    BayRunner
    BayRunner I’m here, except when I’m not
    2017 Tundra Platinum
    This is the Retrax Pro with a fully loaded KB Voodoo rack.
  3. Apr 18, 2022 at 8:16 PM
    Wakekid686
    That's awesome set up.
    Do u have any closer photos of your bed rack system along with teannu cover?
    How much weight does that rack support?
  4. Apr 18, 2022 at 8:25 PM
    BayRunner
    This is about as close as I have. This is the Retrax Pro RX tonneau that has the T-track side rails. KB Voodoo makes a mounting bracket that directly attaches to the T-track slots. It’s a very good fit and not like those tonneau adapters that poke out and up a couple of inches.
    I believe the documented static weight is 750 but truthfully it can hold considerably more.
  5. Apr 19, 2022 at 7:03 AM
    KB Voodoo
    KB Voodoo New Member
    Chad
    2017 Tundra Pro Crewmax, Cement
    Many KB Voodoo Fabrications accessories!!
  6. Apr 19, 2022 at 4:12 PM
    Wakekid686
  7. Apr 19, 2022 at 4:18 PM
    KB Voodoo
    Chad
    Yes, yes, and yes.
    PM'd
