  1. Apr 17, 2022 at 11:29 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    They do. I prefer to gain caster from the lower rather than upper. Honestly with these numbers it drives perfect. The camber just bugs me. But it’s not going to kill the tires.
    oscardog86 likes this.
  2. Apr 17, 2022 at 11:49 AM
    Casper421
    In the woods
    06 DC
    Hey hey hey, it’s only a healthy half ton! ;) Nothing a Ridgeline can’t handle!
    Darkness, 5N0W808, alb1k and 2 others like this.
  3. Apr 17, 2022 at 12:58 PM
    FlightSimGuy
    FlightSimGuy New Member
    2006 Tundra SR5 V8 DC
    ICON 2.5 shocks with King 14" 700lb coils, Camburg UCAs, ICON V2.0 rear shocks.
    (Note to self)
    IF YOU ADD BIGGER TIRES AND DECIDE TO REMOVE THE INNER FENDERS AS A RESULT, REMEMBER THAT'S WHERE THE AIR INTAKE IS!!!
    oscardog86, bmf4069, Darkness and 7 others like this.
  4. Apr 17, 2022 at 1:03 PM
    18" TRD Off Road Wheels
    :eek:
    Seeing that picture reminds be of the smell of a vacuum bag tossed in the trash, or a really dirty, dusty rug getting beat clean.
    bmf4069, Darkness, chrisb and 3 others like this.
  5. Apr 17, 2022 at 2:10 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I'll just leave this here.
    bmf4069, Darkness, chrisb and 5 others like this.
  6. Apr 17, 2022 at 2:11 PM
    alb1k
    Left Coast
    It's good
    Did that throw a code or check engine light?
    FlightSimGuy[QUOTED] likes this.
  7. Apr 17, 2022 at 3:13 PM
    Casper421
    In the woods
    06 DC
    I know she isn’t fast so I drive like a grandpa. When I get the rest of the 4.88’s, maybe things will change. ;)
    oscardog86, Darkness, chrisb and 2 others like this.
  8. Apr 17, 2022 at 3:36 PM
    FlightSimGuy
    My check engine light was coming on intermittently recently, so possibly.
    alb1k[QUOTED] likes this.
  9. Apr 17, 2022 at 4:00 PM
    alb1k
    Left Coast
    It's good
    Yeah I was just laughing, we added about the same weight. You started heavier, but gears go a long way...
    Casper421[QUOTED] and des2mtn like this.
  10. Apr 17, 2022 at 6:01 PM
    0h6SR5
    0h6SR5 New Member
    2006 Phantom Grey Tundra
    3 inch OME with AAL wheels and tires. 285 70 17
    I added some help to the back for heavy loads or towing.
    C2157747-9784-4701-8BEE-71D23BBE5156.jpg ECB66718-8096-49B3-B1AA-EB768C3AAA18.jpg F72EF49C-F60D-4AFC-8FA8-1A05FDC7CD61.jpg
    Voss, oscardog86, bmf4069 and 4 others like this.
  11. Apr 17, 2022 at 6:16 PM
    Curious, how'd you decide on the position of the bag, was it in the instructions?
  12. Apr 17, 2022 at 6:43 PM
    0h6SR5
    0h6SR5 New Member
    It was in the instructions. The 2wd and the 4wd differ a little. The bump stops I have changed it a bit plus I had to adjust a little to avoid hitting the actual bag on the frame. I’m rambling. Long story short I adjusted to fit the best way I saw it fit. But the base is where it’s suppose to be.
  13. Apr 17, 2022 at 6:53 PM
    daveeasa
    I thought we all just overpay for those fancy fenders?
  14. Apr 17, 2022 at 7:07 PM
    0h6SR5
    0h6SR5 New Member
    lol useful def if you can figure them out
    chrisb and 5N0W808[QUOTED] like this.
  15. Apr 17, 2022 at 7:12 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    There's a youtube for that.
  16. Apr 17, 2022 at 7:43 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
  17. Apr 18, 2022 at 4:31 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I spent a large portion of the weekend building another new exhaust for the 911. I'd put LTs on the truck. NBD.
  18. Apr 18, 2022 at 8:02 AM
    BabyYoda4President
    BabyYoda4President New Member
    Central California
    Passenger side window was having issues and not rolling up. Did a little research and the plastic tabs that hold the window to the window track are held by silicon. Cleaned up the window and plastic tab then applied some epoxy for the fix.
    Voss, bmf4069, NUDRAT and 2 others like this.
  19. Apr 18, 2022 at 8:45 AM
    tb1982
    tb1982 New Member
    NW Oregon
    06 Phantom gray Tundra DC TRD 4x4 SR5
    Bought a new discontinued bakflip cover from real trucks eBay page, half price, and got a front end level.
  20. Apr 18, 2022 at 9:01 AM
    How much the bakflip set you back, and is it the FiberMax? It looks good, I like how flush and cleanly inset it is. I ended up going with the TonnoPro, it's not ugly by any stretch, it was inexpensive, but I definitely prefer yours.
    Also, nothing to the rear on your truck? Fender gap looks about an inch higher in the rear and 2-3" in the front after your level. You just toss on some 5100s at level 2 or spacers up front?
    5N0W808 likes this.
  21. Apr 18, 2022 at 9:10 AM
    tb1982
    tb1982 New Member
    NW Oregon
    I only spent $441.75 on the cover. Here is the eBay link. It’s the fibermax so it’s glossy but I think it looks great.
    https://www.ebay.com/itm/165264831474
    I had les Schwab do just 2” spacers in the front. It went up about 2.5” but will probably settle I’m guessing. The back is stock but I do have airbags that were put on by the previous owner. I had Schwab’s check them to make sure they were still good and they set them to about 40 so that’s why the back is higher now too.
  22. Apr 18, 2022 at 9:12 AM
    Truck looks great! Nice OEM+ appearance. Welcome to the forum!
    Appreciate the links. I think I paid around $220 shipped for my TonnoPro. I'm going to be eyeballing that FiberMax. I like their new MX4 or whatever also. It's not quite as glossy.
    tb1982[QUOTED] likes this.
  23. Apr 18, 2022 at 10:04 AM
    FlightSimGuy
    Yep, it never ends.
    5N0W808[QUOTED] likes this.
  24. Apr 18, 2022 at 11:52 AM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    Welcome from (not for long) SE Portland! Nice clean rig, be careful with these idiots on our roads. Never had an accident before moving here and now have been hit 3 times since. Crazy considering I was commuting an hour each way in San Diego and a whopping 5 miles just down pretty much a single street here.
    oscardog86 and tb1982[QUOTED] like this.
  25. Apr 18, 2022 at 12:12 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    :fistbump:
    You will drive like a teenager when that Spintech gets installed.
  26. Apr 18, 2022 at 12:57 PM
    I mean, I've heard my whole life that statistic about how your likelihood of getting in an accident within x miles of your house is overwhelming but never looked into the validity of it. I mean, I'm assuming most drivers typically do the nonsensical "autopilot" driving when closest to home in familiar territory and the volume of that driving for "regular" folks is super high, and that contributed to it, but I dunno.
    I will say, both accidents I've been in since moving to ATL that weren't parking lot incidents were less than 10 miles from home. In one, Young Thug rear ended the pickup behind me at a high rate of speed while at a stop light 6-7 miles from home, shoving that truck into my Camry and doing a little over $20k in damage, frame inclusive. The other time, some lady made an illegal right on red about 4 miles from my house and tagged the front passenger corner of that same Camry, which I'd just taken out of the shop from the prior celebrity incident.
    Parking-lot wise, I had someone back into my 535, scuffing the bumper about 6 miles from the house, and I had the Tundra for a few months when some jackass backed into my bumper while I was donating stuff to charity, I was away maybe 5 minutes tops, it's the main reason I don't have a color-matched bumper anymore.
    Well, you're one hell of a salesperson, your 1st day here and you already have me spending $500 on my truck. At half price, considering the looks and you can actually stand on it, and get 95% usage of the bed, I went ahead and got the Access Cab version from the same vendor, leaving only one left for AC, and I think they have two or three of the DC model you linked. https://www.ebay.com/itm/203779589508
    But since I can't find anyone that has pre-loaded 5100s in stock, I guess I'll buy it and sell my TonnoPro for half what I got it for. When I got the TonnoPro, all the BAK models I found were $800 on sale at best, so this is a hell of a score IMHO.
    I didn't realize there was a 2" difference in the bed dimensions between the RCRB/AC trucks and the DC trucks. For some reason I thought it was an inch or less. BAK is saying their 6'2" product is for DC and the 6'4" is for AC/RCRB
    NUDRAT and abcinv like this.
  27. Apr 18, 2022 at 1:14 PM
    tb1982
    tb1982 New Member
    NW Oregon
    These seemed like such a good deal since used ones are the same price or more so I thought I’d share. I wasn’t totally sure about the difference between AC and DC either so I called and talked to someone at Real truck. Partly to make sure it was legit and second to make sure that it fit since it says you can’t return it otherwise. I was close to buying a G2 that would’ve been in the high $800 range so I was pretty happy to come across this one before I got one of those.
    shifty`[QUOTED] likes this.
  28. Apr 18, 2022 at 1:15 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Was there a rcrb 1gt?
  29. Apr 18, 2022 at 1:22 PM
    no RCSB, only RCLB
    chrisb and Sirfive[QUOTED] like this.
  30. Apr 18, 2022 at 1:25 PM
    RB, SB, Regular Bed, Short Bed, whatever bed.
