DD SS3 Fogs Won’t Work / Help
Discussion in '2.5 Gen Tundras (2014-2021)' started by charliebison, Apr 15, 2022.
  1. Apr 15, 2022 at 9:24 PM
    charliebison
    charliebison [OP] New Member
    Just installed DD SS3 Pro Fogs and they won’t turn on. Tested connection with factory fogs and Rigid fogs, and they both work. Any idea what may be going on? Am I missing something? Thanks.
  2. Apr 15, 2022 at 9:32 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Try flipping the wires, your polarity may be reversed
    HulkSmurf14 likes this.
  3. Apr 15, 2022 at 9:33 PM
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    ^ if that doesn’t work bench test the lights by touching positive to the positive terminal on your battery and the negative wire to negative on your battery.
  4. Apr 15, 2022 at 9:36 PM
    charliebison
    Tried that.
  5. Apr 15, 2022 at 9:37 PM
    charliebison
    Got it. That won’t send too strong a current to the lights?
  6. Apr 15, 2022 at 9:38 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Use a 9v battery to test the lights.
    TheBeast and texasrho83 like this.
  7. Apr 17, 2022 at 5:09 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Only if you touch the wires together. Volts = current * resistance. The resistance in the circuit is the light assembly. Volts are the about the same either way. If the current were high enough to be a problem straight off the battery, it would be high enough to melt the factory harness.
    Actually you can buy kits that use the plugs for your low/high beams to trigger relays, that then pass current over larger wires that run a shorter distance from the battery to power the low or high beams. Gains a few tenths of a volt to brighten the output a bit.
