Valhalla’s Shield theft deterrent/skid plates info and ordering post
Discussion in 'Valhalla’s Shield' started by Classy63, Mar 8, 2021.
Thread Status:
Not open for further replies.
  1. Apr 16, 2022 at 10:28 AM
    #3901
    BayRunner
    BayRunner I’m here, except when I’m not
    2017 Tundra Platinum
    A little reminder to periodically check your bolt torques. Going along with normal maintenance just make sure the bolts/nuts have not loosened. Had my plates on for a while now and just completed maintenance checks on all the bolts. While not loose enough for danger, the bolts definitely needed re-torqued.
    twistedcricket, Mike59 and 1lowlife like this.
  2. Apr 16, 2022 at 10:47 AM
    #3902
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    Is this something a little Blue Loctite would fix? If so, that's not a bad idea. In fact, I think I'll do that anyway just to make sure they don't vibrate loose and cause a rattle. I hate rattles!
    CoffeeAddict and ATV25 like this.
  3. Apr 16, 2022 at 11:25 AM
    #3903
    CoffeeAddict
    CoffeeAddict New Member
    2016 Tundra CrewMax
    Now I’m really irritated at myself for not doing that. I blue Loctite everything I need to stay put but somehow it never crossed my mind here. I’ll have to remember to add some when I eventually pick up the Rock Domes.
    twistedcricket and WBW[QUOTED] like this.
  4. Apr 16, 2022 at 11:30 AM
    #3904
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Glad you brought that up..
    I think I'll do that.
    I hate rattles as well..
    WBW[QUOTED] likes this.
  5. Apr 16, 2022 at 11:43 AM
    #3905
    WBW
    WBW Resident lurker
    Bruce
    I didn't think of it until @BayRunner mentioned his bolts vibrating loose. We're all in the same boat so no one pull the plug!
    1lowlife[QUOTED] likes this.
  6. Apr 16, 2022 at 11:54 AM
    #3906
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    Mine is 4WD. I will be picking my set up from Tyler’s shop once they are ready. (I’m within driving distance). I am going to order the Rock Hard domes, and I had already planned on using Loctite on mine.
    Looking at some pics of others that have ordered Valhalla shields, Tyler’s craftsmanship and finish is amazing. I have the highest confidence and expectations of his work. I’m looking forward to having these. (Though the necessity due to thieves stealing cats disgusts me).
    Classy63[OP] and CoffeeAddict like this.
  7. Apr 16, 2022 at 12:57 PM
    #3907
    BayRunner
    Blue loctite is a good idea. I normally use it, but intentionally did not with the cat plates. I used Skrewd security bolts and did not want to risk potentially stripping the head trying to remove them for future maintenance. I m know blue is not permanent but just didn’t want to take the chance.
  8. Apr 16, 2022 at 1:02 PM
    #3908
    Classy63
    Classy63 [OP] Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    I won’t say no to it. Just don’t use so much your mechanics do shady work after having to bust the bolts loose
  9. Apr 16, 2022 at 7:33 PM
    #3909
    WBW
    WBW Resident lurker
    Bruce
    Haha. If a little is good then more must be better. I just put a drop where the nut threads and bolt threads meet when fully tightened. That will prevent normal vibrations from loosening the fasteners. I really don't want to chemically weld them together.
    1lowlife and Classy63[OP] like this.
  10. Apr 17, 2022 at 1:06 PM
    #3910
    Enphrared
    Enphrared New Member
    2020 MGM Tundra Plat
    Stock
    Received my plates today! Dumb FedEx dropped them off on the other side of town and luckily that person brought them by. Now to get them on!
    gray wolf, toyofan87 and Classy63[OP] like this.
  11. Apr 17, 2022 at 1:41 PM
    #3911
    1lowlife
    DADA
    2014 MGM DC SR5
    How long did it take to install the front plate?
    I have a TRD Skid plate but I'm 2wd.
    I also have the nut plate.
    Is it something I can do in a couple of hours before I go to work at 11:00AM?
    Trying to figure things out for when I get my truck back.
    I don't want to park in my employer's parking lot even 1 day without the plates.
  12. Apr 17, 2022 at 2:26 PM
    #3912
    art64
    art64 New Member
    Depending on how the truck is set up, manual dexterity, different tools availability, strength.lol. I have the TRD skid plate also and a 4x4 truck. From my experience, loosen up the rear bolts 2ea on trd skid plate. Make it as loose as possible but don't take them off. You can probably feel the nut against the bolt by reaching into a tiny space.
    Once loose, grab the main plate and insert it between the trd plate and crossmember. Use screwdriver to pry the trd plate down a bit.
    Once the shield started to insert, hit it with a heavy mallet or wood or sledge hammer. Use floor jack to raise the plate as you jam.
    Check alignment make sure cutouts on the plate go where the bolts are on the trd plate. Once in, bolt the other end of the shield-keep bolts loose.
    If you still have time you can mount the rear cat plate. Install the L brackets to the frame first.
    If not enough time, tighten the bolts on the trd plate, but make sure the rear bolts on the shield are perfectly aligned on the crossmember. I used a screwdriver and put a prying force between the trd plate and the shield. It didn't spun the nut. Then tighten up the rear bolts.
    My truck is almost stock height fyi.
    It probably took me 3 hours. I started by myself. I took the rear trd bolts only to find out, no way to even thread the nut to the bolt. Maybe if I lifted the truck higher I can position myself better.. Help came and made it so much easier. I'm on one side and he's on the other side.
  13. Apr 17, 2022 at 5:13 PM
    #3913
    Texasturner
    Texasturner New Member
    I did very much the same but did loosen all of the TRD pro skidplate bolts to let it hang and have a large gap to slide new plate in
    art64[QUOTED] likes this.
  14. Apr 17, 2022 at 9:15 PM
    #3914
    1lowlife
    DADA
    2014 MGM DC SR5
    I've got Valhalla's nut plate and security bolts for the TRD skid plate.
    Trying to figure out if it's worth replacing the TRD Skid plate bolts with security bolts.
    A big part of me thinks if a Dallas crackhead sees a shield under the truck they are going to move on to the next Tundra.
    They are not going to try to unbolt the damn thing to steal my cats.
    Hopefully, I can work it out that I pick my truck up from the dealer on Saturday morning to give me the weekend to install.
    But being I'm in their rental/loaner, I'm sure they will want me to pick up the tundra when it's ready..
    Still waiting for the rear shield to come in @Classy63 ..
    Looking forward to the 2WD V3 when it is available.
    WBW and jgullace like this.
  15. Apr 17, 2022 at 11:08 PM
    #3915
    jgullace
    jgullace New Member
    Joshua
    2020 Tundra (Cavalry Blue)
    I wish I knew what these Dallas crackheads had going through their head. They passed 3 other new-ish tundras to drive deeper into our neighborhood to get mine. No one else in the areas been affected in almost 2 months. So no idea.
  16. Apr 17, 2022 at 11:14 PM
    #3916
    1lowlife
    DADA
    2014 MGM DC SR5
    I've got a 2.5" lift and I always park on the edge of the parking lot away from everyone else.
    I guess that presented a grand opportunity to steal mine..:mad:
    The idiots one took one, they left the driver's side with the rubber hanger hanging from the underside of the truck...:confused:
  17. Apr 17, 2022 at 11:47 PM
    #3917
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    I ordered the front and rear cat plates from you. I also have a RCI engine plate. Should I change my order? Order number is R384382799. Also, should I order the TRD Pro nut plate?
    Thanks.
  18. Apr 18, 2022 at 5:42 AM
    #3918
    GrayWolf
    GrayWolf New Member
    2018 Magnetic Gray Tundra Platinum
    PM sent.
  19. Apr 18, 2022 at 7:15 AM
    #3919
    BayRunner
    Change your order to what? I have an RCI engine skid and the cat plates install just fine.
  20. Apr 18, 2022 at 8:51 AM
    #3920
    Classy63
    Tyler
    Cypress Texas
    Spent some time yesterday test fitting the prototype for the Tacoma/4 runner, I made a lot more changes than I expected… I am going to make another prototype with all the changes and this one should be the ticket
    Thumper_6119 and Mike59 like this.
  21. Apr 18, 2022 at 9:49 AM
    #3921
    stiffler
    stiffler New Member
    2020 Platinum SSM Tundra
    So i've seen two options on this but haven't read every single post yet. Should I remove the diff cover or request spacers to lower the cat plate?
  22. Apr 18, 2022 at 11:05 AM
    #3922
    art64
    art64 New Member
    If I have to do it again, I'll replace the rear trd plate bolt with a longer one. The first time I tried it, I removed the rear bolts completely. Went in really easy with just me and floor jack. Now, threading the nut on the bolt, that was the breaking point for me. If the bolt was 1/2 inch or 1 inch longer, yes, very doable.
    I have the thick steel plates. Maybe I should have taken the front wheels off to be able to position myself better. I just put the front tires on the big 4x4 wood and worked on it.
    1lowlife likes this.
  23. Apr 18, 2022 at 4:58 PM
    #3923
    Thumper_6119
    I bought a set of these last year, and they have been a huge help in doing a lot of tasks under my truck. (Like removing the OEM skid plate before oil changes and replacing it afterwards, for example.(and I do not leave my truck on the ramps when actually changing the oil)). They were helpful when trying unfreeze the BM turnaround ball mechanism that the previous owner didn’t maintain very well.
    I am going to be using them when I install my Valhalla plates.
    (my ramps included the chocks as well).
    RhinoGear 11912ABMI RhinoRamps MAX Vehicle Ramp - Pair (16,000lb. GVW Capacity) https://www.amazon.com/dp/B0117EESNC
    That link is for Amazon, but I got mine at AdvancedAuto.
  24. Apr 18, 2022 at 5:01 PM
    #3924
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    say what now?
    Kung and AggiePhil like this.
  25. Apr 18, 2022 at 5:04 PM
    #3925
    Thumper_6119
  26. Apr 18, 2022 at 5:20 PM
    #3926
    Uhhhh....
    Dave
    Virginia
    7” BDS, 37s
  27. Apr 18, 2022 at 6:18 PM
    #3927
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    S&M toy ???
    AggiePhil likes this.
  28. Apr 18, 2022 at 8:15 PM
    #3928
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    Well, that escalated pretty damn quickly for sure.....
    ATV25 likes this.
  29. Apr 18, 2022 at 9:47 PM
    #3929
    Romad224
    Romad224 New Member
    2022 platinum blueprint
    Are there rear plates for the 2022?
  30. Apr 18, 2022 at 10:25 PM
    #3930
    1lowlife
    DADA
    2014 MGM DC SR5
    All the cat plate makers I've seen only sell one plate for the 2022s..
Thread Status:
