Yikes need help
Discussion in '1st Gen Tundras (2000-2006)' started by Bluetoyotaguy, Apr 15, 2022.
  1. Apr 15, 2022 at 6:38 PM
    Bluetoyotaguy
    Bluetoyotaguy [OP] New Member
    Hello, an issue has been found with my lift I need to get some aftermarket control arms to restore some normal geometry for my lift need some suggestions ASAP!!! Not super expensive but not cheap here are some pictures of my current issue my ball joint are getting stuck under the spring of my strut. Any other fixes or solutions are greatly appreciated!upload_2022-4-15_21-37-10.jpg
  2. Apr 15, 2022 at 6:39 PM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    Holy shit. What size lift do you have?
  3. Apr 15, 2022 at 6:41 PM
    Quite the angle of the dangle isn’t it?!
  4. Apr 15, 2022 at 6:41 PM
    Bluetoyotaguy
    Well long story short it’s only a 2.5” rough country puck and the struts are new but supposed to be like one.
  5. Apr 15, 2022 at 7:39 PM
    Beefnbread
    Beefnbread Electric Soup
    Oregon
    2000 SR5 Tundra 4x4
    Never seen that before.
    Well here are some UCA brands:
    *Camburg
    *JBA
    *Total Chaos
    *Freedom Offroad
    *SPC
    I have Protune ones. They’re the cheapest and work fine, but I don’t think it’s socially acceptable around these parts.
  6. Apr 15, 2022 at 7:42 PM
    Bluetoyotaguy
    Thanks! Will look into them
    Beefnbread likes this.
  7. Apr 15, 2022 at 7:43 PM
    easleycrawler
    Travis
    Do you have a pic looking inside the wheel well from outside, looking at the uca?
  8. Apr 15, 2022 at 7:45 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    TBH something is kinda fishy because I’ve seen in person people running 3 inch lifts with stock arms.
    easleycrawler and FrenchToasty like this.
  9. Apr 15, 2022 at 7:45 PM
    We need pics, like lots of pics…….
    bmf4069, Darkness and easleycrawler like this.
  10. Apr 15, 2022 at 7:57 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I think he lifted his front end with a jack and the spindles got hung up in the coils.
  11. Apr 15, 2022 at 8:00 PM
    This is, what, the 3rd Rough Country lift disaster I've seen on a 1st Gen Tundra in less than 12 6 3 months?
    Why do people keep buying this Rough Country garbage?
    bmf4069 and Rodtheviking like this.
  12. Apr 15, 2022 at 8:00 PM
    Bluetoyotaguy
    The weird thing is that when the truck is driving and say I’m stopped at a red light or stop sign it’s fine but as soon as I hit a bump or park in my driveway which is on a slant and you need to go over a curb to get on it the upper ball joint gets stuck on the strut
  13. Apr 15, 2022 at 8:00 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    Possible, yeah, but I’ve had the same lift and stock arm on my truck before and never encountered this before. Even when you jack it up, when the UCA starts sagging down, it would still maintain good clearance.
  14. Apr 15, 2022 at 8:02 PM
    Bluetoyotaguy
    I’m not sure how the issue became but is my only solution to buy upper control arms?
  15. Apr 15, 2022 at 8:02 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    Send us some pictures please :popcorn:
    Jack McCarthy likes this.
  16. Apr 15, 2022 at 8:02 PM
    I think you just need to sell the truck at this point.
  17. Apr 15, 2022 at 8:03 PM
    No, we need more pictures. Don’t jump to conclusions.
  18. Apr 15, 2022 at 8:03 PM
    Bluetoyotaguy
    Shifty How in the hell does that have anything to do with buying new upper control arms?
  19. Apr 15, 2022 at 8:05 PM
    Bluetoyotaguy
    I will post more pictures tomorrow when I have sunlight and can really get a good look at everything.
    easleycrawler and Beefnbread like this.
  20. Apr 15, 2022 at 8:12 PM
    Bluetoyotaguy
    Does anybody know if wheel spacers could cause this issue to occur? I don’t see how it could but just asking.
  21. Apr 15, 2022 at 8:12 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Is that with your truck on the ground, or up on jack stands?
    No it isn't from wheel spacers
  22. Apr 15, 2022 at 8:14 PM
    Bluetoyotaguy
    My truck is currently sitting on the ground not up on jackstands.
  23. Apr 15, 2022 at 8:16 PM
    Bluetoyotaguy
    Shifty it has nothing to do with the rough country kit it’s either a bad alignment or A stock suspension component is bad and needs to be addressed and replaced or fixed
  24. Apr 15, 2022 at 8:16 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    What kind of coilovers do you have?
  25. Apr 15, 2022 at 8:16 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Well then, you've got serious trouble. We need more pics, not much else will help.
    I ran 4" of lift with stock upper arms for several months, the arms aren't going to fit that. Something else is wrong. How long ago did you install that kit?
  26. Apr 15, 2022 at 8:18 PM
    Bluetoyotaguy
    They are Supposed to be the OEM replacement they were bought at auto zone and they are by a brand called duralast.
  27. Apr 15, 2022 at 8:18 PM
    dlowry81
    dlowry81 New Member
    Doug
    2004 Tundra Doublecab
    I bought a truck just a few months ago with same lift and noticed same problem when I did the brakes. I bought new smaller tires and yanked the lift off. It was tearing up ball joints, outer tie rods, and the sway bar links. Lifts look nice, but not worth the wear.
  28. Apr 15, 2022 at 8:18 PM
    Did you swap the passenger and drivers side?
  29. Apr 15, 2022 at 8:18 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    You mean you have a puck on top and your struts are supposed to give lift too? If yes,, then ditch the pucks.
    ColoradoTJ and Jack McCarthy like this.
  30. Apr 15, 2022 at 8:19 PM
    Bluetoyotaguy
    It was installed about a month and a half ago by supposedly a reputable shop but however I will take it back in Tuesday and have the issue addressed and if it is unable to be fixed which it should be able to then I will go from there.
