Hood cable snapped and is tired up holding his shut
Discussion in '2nd Gen Tundras (2007-2013)' started by Amac17, Apr 14, 2022.
  1. Apr 14, 2022 at 1:57 PM
    Amac17
    Amac17 [OP] New Member
    2009 Tundra
    So my hood latch cable snapped and I can't open my hood at all I've tried taking the latch off, I've tried drilling the holes... The cable is tightly wrapped around something holding the hood down... Brought it to a few mechanics and nothing... Anyone????
  2. Apr 14, 2022 at 3:11 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Do you know how deep it snapped? any chance you can reach it through the fender?
  3. Apr 14, 2022 at 3:13 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    You drilled holes and took it to a few mechanics and nothing? :spam:
    Darkness likes this.
  4. Apr 14, 2022 at 3:28 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Sawzall will fix anything
    :sawzall:
    BlueCrushSC16 and alb1k like this.
  5. Apr 14, 2022 at 3:30 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  6. Apr 14, 2022 at 3:32 PM
    timsp8
    NY
    Should be able to see the latch through the grill. A mechanic should be able to get it open. What or where did you drill?
  7. Apr 15, 2022 at 1:20 PM
    Amac17
    2009 Tundra
    We haven't been able to get the hood opened we took the latch bolts off it just wouldn't budge. I'm going to try to fit my hand up there either the grill or fender to try to get at it. We can't see where exactly it's stuck but I'm going to go try and see if I can see where. No this is not spam btw... Thanks for the helpful answer tho. Anymore ideas are greatly appreciated.
  8. Apr 17, 2022 at 12:16 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    I would order up a replacement used grill for your truck, then use that as a guide to destruct the one you have now so you can get this fixed.
  9. Apr 17, 2022 at 12:34 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    A 90 degree pick usually can be snuck in from the bottom and pull on the release lever of the latch. You may have to bend the little metal protectors around the latch though
  10. Apr 17, 2022 at 1:06 AM
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    I think this is what its gonna take. Cut the center of the grill out to get some better access. Then Id try drilling out the mounting bolts (in white) and if that didnt work id try drilling out these rivits (in red)
    Definitely gonna hafta sacrifice a grill to get to em
