2010 tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by GLS67, Apr 9, 2022.
  1. Apr 9, 2022 at 1:57 PM
    GLS67
    GLS67 [OP] New Member
    Guernard
    Tundra sr5
    None
    Hey everyone so I’m new at all this. Hope I can find answers on a issue I’m having with my truck.
    Prostar 190 likes this.
  2. Apr 9, 2022 at 2:18 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Hell yea brother
    Ricos likes this.
  3. Apr 9, 2022 at 2:31 PM
    So what's the issue?
  4. Apr 9, 2022 at 2:55 PM
    GLS67
    Guernard
    Tundra sr5
    None
    My truck has 122,000 and I’m on my 5 set of tires. Been to 2 different Toyota garages and several other garages they all say I’m with in specs and my tires are wearing out on the outside edges and I can not figure out why. Im to the point of replacing the entire front end. There has not been any upgrades either and I have had bought this truck new
  5. Apr 9, 2022 at 2:58 PM
    “J”
    “J” New Member
    NC
    2021 Tundra SR Barcelona Red
    Try body shop that has a frame machine and have them check the dimensions.
  6. Apr 9, 2022 at 4:29 PM
    Pics would help. Tire rotation is key on these trucks. The outer edges do wear faster on the Tundras.
  7. Apr 10, 2022 at 7:27 AM
    GLS67
    Guernard
    Tundra sr5
    None
    Ok but I’m wearing out a set of 70,000 mile tires from 25,000 to 30,000 miles. I would not be saying anything if they wore out at 50 to 60 thousand miles. I’ve rotated my tires of course the only thing I have not done is take the tire off the rim and flip the tire which outside of the tire would be the inside. Sorry no pictures of tires just put a new set on.
  8. Apr 10, 2022 at 8:22 AM
    YouFallWeHaul
    YouFallWeHaul New Member
    2010 Marine Blue DC 4x4
    I have a 2010 also, same issue. New tires are about half way worn down on the front outside edges at 7k miles. yes, rotating will help, but even if I have the tires flipped on the wheels at the next rotation, I should struggle to get 30k out of them.
    I did also have my alignment done at the new tire installation, and checked recently. Shop said it is "in spec" of 0.1 degree positive camber.
    To the best of my knowledge, the primary reason for running positive camber is to have the tires match the crown of the road, so the inside edges dont wear as much. I'm thinking of asking them to move to a few tenths of a degree negative camber on the next alignment. This would slightly change the cornering balance but I think not substantially (it should be no worse than adding a rear sway bar in terms of making the truck tail-happier).
  9. Apr 10, 2022 at 8:58 AM
    snivilous
    SW UT
    Post the alignment document
  10. Apr 10, 2022 at 4:16 PM
    Notarobot
    Notarobot Jagged lines!
    2013 CM
    You take your turns too fast. Wears the outer fronts quicker.
  11. Apr 13, 2022 at 6:17 AM
    YouFallWeHaul
    Most of my driving is on windy, hilly, two-lane paved state highways. Lots of corners at 50ish mph. So, yes. But, I (and it seems the OP @GLS67) am wondering if there is a mechanical solution that can mitigate this issue.
    @snivilous apologies but I don't have the alignment doc, they showed it to me when I had it checked and the front camber was +0.1 degree.
    Has anyone tried a non-stock alignment, for any reason? I'm curious of the results. I have done this with cars, more for performance/autocross reasons, with decent results.
  12. Apr 13, 2022 at 6:36 AM
    Brazak
    Brazak New Member
    2022 Tundra Limited
    My 2010 had that problem. The shop that installed the leveling kit and new oversized wheels/tires said alignment was spot on. After the first set of tires wore out very quickly, I took it to a second shop for checking and they said the first shop maxed out the camber adjustments but it wasn't enough and had to modify the install. After that, I didn't have the wear problems. So sometimes a second opinion is good to have.
  13. Apr 13, 2022 at 6:42 AM
    YouFallWeHaul
    @Brazak do you know what they modified about the install? Was it changing control arms, or some other component? Or just re-adjusting the alignment?
    FWIW I have 5100s on the lowest setting, no other suspension mods - so suspension geometry should be near-stock.
  14. Apr 13, 2022 at 6:45 AM
    Brazak
    Brazak New Member
    2022 Tundra Limited
    I really don't recall. That happened in 2009/2010 when I first bought the truck. Just that the second shop fixed the first shops problem and that I was happy with the cost. Sorry..
  15. Apr 13, 2022 at 6:48 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    I got a 2010 and will keep my eyes and ears open for this issue. So far I haven't experienced anything like this.
  16. Apr 14, 2022 at 11:29 AM
    GLS67
    Guernard
    Tundra sr5
    None
    . Sorry everyone just trying to get this figured out not what I wanted or how I wanted it but this is what I got. Anyways the last alignment I did I wanted them to bring the top of the tire in well I see they did not do as I asked them so now I’ll take it elsewhere here asap since I did put new tires on so I’ll keep everyone informed on what happens
