Stock Rake lift/Leveled front!! Which one?
Discussion in '1st Gen Tundras (2000-2006)' started by Beefnbread, Apr 13, 2022.
Stock Rake or Leveled Front
  1. Stock Rake Lift
    16 vote(s)
    51.6%
  2. Leveled Front
    14 vote(s)
    45.2%
  3. ....Rear Squat!!!
    1 vote(s)
    3.2%
  1. Apr 13, 2022 at 9:59 PM
    Beefnbread
    Beefnbread [OP] Electric Soup
    Oregon
    2000 SR5 Tundra 4x4
    Just kind of bored and wanted to hear some opinions.
    I’ve tried out a bunch of different lift heights on my truck. Started out with 3 inch and hated the squat. Switched to 2 inch and thought it looked great, but later down the road I told myself i’d lift the front and back more.
    2 inches in front was great for me since it created equal height from the front and rear. Not too high in front and not too low in the rear. I rolled with that for quite a while.
    Decided to upgrade to coilover lift instead of leveling spacers, so I ended up getting 2.5 inches of lift from the coilovers I got. Figured while I was at it, I’d put an AAL in the rear to make up for the extra half inch.
    That was great until I thought there was too much rake. I thought about it for a while.
    Now, recently, I threw on an extra 1 inch leveling spacer to even things out. I really dig it now. Just a little taller in the rear for when you load it up with gravel!!!
    This is what I got from ground to fender with 285/75r16s
    Front: 38 1/4
    Rear: 40
    Am I the only one that thinks the rear of the bed on these trucks tilt downwards way more than other trucks? I feel like having 1st gen tundras with the nose high looks funny
    Anyways, here’s the question.
    What do you prefer? A stock rake lift or a leveled front? There’s also rear squat too
    Not really looking for advice at all, but just want to know what the community feels on it. Feel free to post pictures.
    Photos from various sources. Sorry if I post anyone’s truck on here.
  2. Apr 14, 2022 at 12:25 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    I like leveled, I have air bags for when I tow.
    Luckydog, Toyotoholic and bmf4069 like this.
  3. Apr 14, 2022 at 4:24 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    It's funny you bring this up. I think about it whenever I see a truck with a "leveling" kit. Not so much on First Gen Tundras... more on later Tundras, and particularly on GM trucks.
    Certainly a lot of this is subjective, but there are some universal design principles that apply. One being that positive rake (front lower than rear) -- whether it's physically measurable or done with design features that give the rear the appearance of being higher than the front -- gives a vehicle a more aggressive stance. Negative rake (front higher than rear) gives a vehicle a more passive stance. Personally, I think a sagging rear end makes any vehicle look kinda dumpy -- like something is broken or worn out.
    Aerindel, Beefnbread[OP] and bmf4069 like this.
  4. Apr 14, 2022 at 4:26 AM
    Lifted level for sure.
    tundratoofun, Darkness and 2006Tundra like this.
  5. Apr 14, 2022 at 5:52 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I like this one
    Darkness likes this.
  6. Apr 14, 2022 at 5:57 AM
    REESE77
    REESE77 New Member
    Reese
    03' 4x4 v8
    That is Seanpistol's truck. he has a great build thread on one of the other forums.
    Darkness and Toyotoholic[QUOTED] like this.
  7. Apr 14, 2022 at 9:30 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I think leveled looks fine. Really, once you start messing with suspension the stance of your truck becomes a little unstable in terms of level front to back or even side to side. My suspension while slightly taller than stock is soft enough that if I am not parked on flat ground the front end will be higher or lower than the rear. Mine has been stock, had the squat rake, perfectly level, and now is about an inch higher in the rear. Depending on where I park it is still all of the above.
    Toyotoholic, bmf4069 and tundratoofun like this.
  8. Apr 14, 2022 at 10:51 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    My buddy calls my Stock 2006 DC 'The Ant Eater'. :p
    But I like it that way.
    bmf4069 and Darkness like this.
  9. Apr 14, 2022 at 1:52 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    Hey bmf.
    I think I read on your iron man build that you were going to put an AAL, but didn’t get around to it or something. Are you going to lift the front more to level it out again?
  10. Apr 14, 2022 at 1:56 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    I prefer rake. If you just drive and cruise it, level is nice but as soon as you haul or tow something you are nose up....and I am not a fan of nose up
    HBTundra, Aerindel and alb1k like this.
  11. Apr 14, 2022 at 2:06 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    That's how mine is, except at +2 in the back, never squats. What color is that?
  12. Apr 14, 2022 at 2:38 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yeah, but being nose up while you haul is the exception not the norm. I'd rather have the stance I like most of the time and squat a bit when I haul weight than have the stance I don't want most of the time just to be balanced when hauling weight.
  13. Apr 14, 2022 at 2:48 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    Dark, what size tires are you running? Can’t tell if they are 33s or 35s
  14. Apr 14, 2022 at 2:50 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    33s but if anybody else asks, they're 35s :anonymous:
  15. Apr 14, 2022 at 2:54 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    Hah nice. Guessing you have 2.5 inch lift in front, right
  16. Apr 14, 2022 at 2:56 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I can't be sure anymore. I've changed it so many times I don't have a real baseline to gauge from anymore. I think its around 2-2.5 up front and around 1-1.5 in the rear. Its slightly tall in the rear and I'm waiting to make another change and see what the outcome is. If my front end doesn't have to go up then I may lower the rear 3/4 of an inch to get back to level.
    des2mtn likes this.
  17. Apr 14, 2022 at 8:26 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 SR5 Tundra TRD Off Road
    So, when are we banning the guy who voted for the Carolina Squat?
    Aerindel, abcinv, Casper421 and 2 others like this.
  18. Apr 14, 2022 at 9:21 PM
    Yes. My plan is to put the AAL in, then raise the coilovers to match and get a good level, then get another alignment.
  19. Apr 14, 2022 at 9:23 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Can I put that in my signature line? . . .:rofl:
    Classic.
    Riverdale21[QUOTED] and bmf4069 like this.
  20. Apr 14, 2022 at 9:24 PM
    This. 100% but even more so for me. I never tow. In fact, I removed my receiver to install my new springs and just sold it to @Sirfive. If you're not towing, then level is fine. And if you do tow, just squat when you tow. Level is the perfect choice.
    805Tundra and Darkness[QUOTED] like this.
  21. Apr 14, 2022 at 11:31 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    Leveled with the caveat of more tire than wheel, and 6 lugs, so 6, 12, or 18,… spokes.
    bmf4069 likes this.
  22. Apr 14, 2022 at 11:39 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I like a little rake. Because I tow.
  23. Apr 17, 2022 at 5:01 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    You guys think I should raise the front 1/2?
    More levelness?
    See the Black Tundra back there?
    HBTundra likes this.
