Front Locker Feedback
Discussion in '1st Gen Tundras (2000-2006)' started by Slp82, Apr 11, 2022.
  1. Apr 11, 2022 at 2:38 PM
    Slp82
    Slp82 [OP] New Member
    2005 Tundra RC 4.7 4x4; Toytec Boss 2.0 kit; SPC upper control arms; addicted offroad front bumper & 9k winch, Brute Force sliders & rear bumper, skid row skid plates, 285/75r16 Cooper AT3, Detroit trutrac in rear.
    2014 Tundra 4x4 5.7L DC; Bilstein 6112s @ 1.9"; 35x12.50 Nitto Ridge Grapplers on 20x9 wheels with +25 backspacing; DV8 front & rear bumpers, Engo 12k winch (SOLD) 2005 Tundra RC 4.7 4x4 w/3" spacer, addicted offroad tube winch bumper w/9k Engo, homemade sliders, skid row skid plate, 285/75r16 Cooper AT3, Detroit trutrac in rear.
    I am looking for only responses from guys who have had front lockers on vehicles with automatic hubs.
    I have a 2005 Tundra that is currently my daily driver. It is not driven much as I have only put 75k miles on it in the last 10 years.
    It has the following mods:
    - Toytec Boss 2.0 lift kit (3/2", shocks front and rear, softer bump stops, add a leaf)
    - SPC upper control arms
    - Skid row 1/4" steel skid plates on front diff, oil pan, transmission and transfer case
    - Addicted off-road high clearance front winch bumper w/9k winch
    - Brute Force Fabrication Sliders
    - Brute Force Fabrication high clearance rear bumper with bed panels chopped for better departure angles
    - Detroit Trutrac rear end
    - 285/75R16 Cooper AT3s
    Pretty much all I do is rock crawl in the hill country of Texas. I know I need 35s which I am going to work on soon, but right now with my current setup, and my tires aired down to 20 Psi, I need more traction from my front end.
    I am seriously considering putting a Spartan "lunch box" locker in my front end. I have researched this over the years even back when I had a Tacoma, and I get mixed reviews from people which tells me some are making assumptions while some are speaking from experience. I am only looking for people who have direct experience please as I need a definitive answer on this.
    So when you are in 2wd, driving on pavement, with automatic hubs, and have a locker in the front differential, will it at all fight you during steering around corners or will it be like it is not there?
    Also if there is any other options (limited slips, specifically helical gear styles like the Trutrac), please let me know as well. I have not researched this topic in many years and there might be some new tech out that wasn't years ago.
    Thank you in advance for any help on this matter.
  2. Apr 11, 2022 at 2:52 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Slp82[OP] likes this.
  3. Apr 11, 2022 at 2:58 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Where are these ‘automatic hubs’ coming from.
    does the ADD disengage the pinion, 1 axle, or both?
  4. Apr 11, 2022 at 3:14 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    It disengages the passenger side axle stub
    the driver side still spins the spiders
    DarkMint and Sirfive[QUOTED] like this.
  5. Apr 11, 2022 at 3:18 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    So in 2wd, you might have a little extra rotational mass, maybe resistance, but it wouldn’t bind and click?
  6. Apr 11, 2022 at 5:26 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    When in 2wd, it'll drive like it always has. You won't be able to tell there's a locker/limited slip in it. The only time an automatic mechanical locker, like a Detroit, or limited slip engages is when power is being applied. In 2wd, there's no power is being applied, so it shouldn't lock up.
  7. Apr 11, 2022 at 7:14 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    As long as one side axle is disengaged and the driveshaft isn't turning with power it'll be fine.
    In 2wd (manual t-case) with both hubs locked on my taco it is engaged and makes the steering way heavy.
  8. Apr 13, 2022 at 2:41 PM
    Slp82
    That was actually a really good thread and that video from that company shines a lot of light on the situation. I live in south Texas so other than the once every 50 year freeze, I don't have to worry about snow or ice. I think I will just buy the lunch box spartan and install it. If I don't like it, I'll simply take it out.
    BubbaW[QUOTED] likes this.
