Bilstein shocks worth it ?
Discussion in 'Suspension' started by Scpringle, Jun 19, 2017.
  1. Jun 19, 2017 at 5:05 PM
    Scpringle
    Scpringle [OP] New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    These are all for 16 TRD that have 100 miles supposedly have a chance to buy them they are saying make an offer. Would this make much difference to my 2015 double cab SR model. I have the TRD sway bar. How much are they worth ?he doesn't know the model number
  2. Jun 19, 2017 at 5:11 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    They look like the stock TRD off road shocks. They might be a better ride than the stock non-TRD shocks. I wouldn't spend very much for them.
    You'll still need to put your springs on them
    Scpringle[OP] likes this.
  3. Jun 19, 2017 at 7:31 PM
    Scpringle
    Jackson MS
    THanks @Bprose I wonder if better shocks with standard springs are worth the upgrade for a 2WD asphalt queen ? I figure $200-$ 300 for installation .
  4. Jun 19, 2017 at 8:07 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2013 Tundra SR5 CM TRD 5.7 4X4
    IMO it's worth it, especially if you can get them for a cheap price. Your suspension should be slightly stiffer and more responsive. There are lots of guys on here including myself that have upgraded shocks with the stock springs so unless you were looking to lower the truck or turn it into a prerunner the stock springs are perfectly fine for a street application. If you can install them yourself, which is actually pretty easy to do, that would save some cash. All you would need is to have the springs installed on the struts, a pretty simple job that most shops would do for probably less than $50.
  5. Jun 19, 2017 at 8:14 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    That's a 4600 make from bilstein for Tundra specs, commonly used on the TRD model. They are great if you're going from the black shocks which are the intro models. These do good for a level kit. Provided that they have a low amount of miles on em. However, the lower shaft doesn't like hard impacts so if you try to get Air McNair with em you're gonna break em! But yes, for a roadie they're great. BTW, you are spot on for installation bud.
    Law323 and Scpringle[OP] like this.
  6. Jun 19, 2017 at 9:02 PM
    Scpringle
    Jackson MS
    how much to pay for them ? I think $100 max...
  7. Jun 20, 2017 at 6:23 AM
    duece292
    Greg
    Green Bay, WI
    They look pretty clean and if they truly only have 100 miles on them, I'd say $100 is a fair offer. Maybe $125 max. For not much more you could have them brand new with a warranty.
  8. Jun 20, 2017 at 6:58 AM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    I'd move on em @ $100.
    Bprose likes this.
  9. Jun 20, 2017 at 11:38 AM
    Scpringle
    Jackson MS
    got them for $75 ! @Hattori so will this level the front end ?
  10. Jun 20, 2017 at 12:12 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    .....My man
    It will once you put a level kit of some sort on it. There are a ton of level kits you choose from in the 2.5 to 3in range, Pro Comp, Revtek, Fabtech, RCX, etc. For instance the EXP65225 kit is a 2.5 level system and the EXP65225K Nitro kit which is a 3/1
  11. Jun 20, 2017 at 12:45 PM
    ToyotaTundraMike
    ToyotaTundraMike Not A New Member
    2015 Tundra
    I know this probably isn't what you wanted to hear but...
    The shocks alone won't level the front end because they aren't adjustable like the Bilstein 5100's.
    Might should have just saved up a little more for those if you wanted to level the truck as well. All these are gonna do is provide a slightly better ride than what you currently have, not sure how noticeable it will be.
    Idk if it's really worth paying someone to install them unless you buy some sort of leveling kit to go with it, and at that point you would have spent less $$ and had a better ride/functionality by going with the 5100's.
    At least you got a good deal on em!
  12. Jun 20, 2017 at 1:22 PM
    Scpringle
    Jackson MS
    @ToyotaTundraMike I was not looking to level it , just curious if it would do that . I might do it at the same time and get more bang for my buck on install cost. @Hattori I don't want to lift it too much as I am going to keep stock size tires on it . Thanks again guys .
  13. Jun 20, 2017 at 1:50 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    @Scpringle : IF YOU DECIDE TO; lmk as i think i have a level kit that you can have:thumbsup:
  14. Jun 20, 2017 at 3:09 PM
    Scpringle
    Jackson MS
    1496115363821.jpgi it sits fairly level as it is (not the best pic to show that) and it just going to make the tires look smaller with more space in the wheel well is my thought. Every time I look at it I think its fine as it is .
  15. Jun 20, 2017 at 3:17 PM
    Scpringle
    Jackson MS
    Thanks @Hattori , what part of Nashville are you in ? I just moved from sylvan park after 24 years ! I lost a bet.... And had to move .
    Hattori likes this.
  16. Jun 20, 2017 at 3:22 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    So here's the scoop, we used to stay in Nashville East. Hermitage to be exact. When I was doing my forum avatar I got the logistics wrong so I'm actually in Dallas right now but we're moving back to Nashville in 2018-2019. Probably Ashland City or Mt. Juliet. We need land!
    Scpringle[QUOTED][OP] likes this.
