Weird things about the 2022 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by EvilSteve, Mar 7, 2022.
  1. Mar 7, 2022 at 8:30 AM
    EvilSteve
    EvilSteve [OP] New Member
    2022 Lunar Rock Tundra Limited
    Here are a few things I’ve discovered while owning the truck that I find weird. What are yours?
    • The back window has an up/down switch that isn’t automatic. My wife’s 4Runner back window is automatic.
    • The multimedia system lets you select the colour of your truck when it’s displaying it in the camera view. Lunar Rock isn’t an option.
    Hoping that I’m missing how this works and someone can tell me that I’m just wrong! :D
  2. Mar 7, 2022 at 8:53 AM
    Baldwin
    Baldwin New Member
    When using android auto, the screen flips between day and night mode immediately if I go under a bridge or somewhere dark.
    CMCaleb90 likes this.
  3. Mar 7, 2022 at 8:54 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    My truck does this all the time.
    Demar002 and PlatinumPro like this.
  4. Mar 7, 2022 at 8:54 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Thats interesting. My Kenwood AA head unit switches when you turn on the headlights.
    Demar002 likes this.
  5. Mar 7, 2022 at 9:02 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    the back window on my 2015 Tundra isn't automatic either. Did they add it to the newer 2.5 gens?
  6. Mar 7, 2022 at 9:04 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Not mine...
  7. Mar 7, 2022 at 9:18 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Nope
  8. Mar 7, 2022 at 12:07 PM
    Demar002
    Demar002 New Member
    Frank
    2022 Toyota Tundra
    When I go to park my truck sometimes the engine shuts off but is in auto/shut off mode. I have to hit the button to shut the truck off. Sometimes the engine RMP goes to 0 Like it is going shut off but revs back up. If I reverse into my parking spot and put it never does either. it just stays running with no change in RPM or attempt to go in auto/shut off mode
    Supertech1 and EvilSteve[OP] like this.
  9. Mar 7, 2022 at 12:17 PM
    EvilSteve
    I think when in Apple CarPlay or Android Auto, it bases the day/night mode off the phone. Other vehicles have light sensors in them that turn lights on in dark environments which switches back and forth. When neither of those things are happening, sometimes it’ll assume it’s night time when someone turns their lights on.
    Oh yeah, I’ve seen that as well. If you put the truck in park, and it’s able to, it’ll shut the engine off, but it seems like there’s some combination of things that stops it doing that in my experience. I wonder if the truck won’t do auto stop if it’s in reverse? I haven’t tested that.
  10. Mar 7, 2022 at 12:23 PM
    EvilSteve
    I thought of another one thanks to person who posted in the new owners thread.
    • If you have a bicycle in the back hanging over the tailgate, sometimes the truck will realise there’s something there and disable all the sensors. It’s weird because you’d think it’d just disable one of them but it disables everything. When you’re driving around, you acknowledge the sensor warning but it just keeps popping up. Sometimes it’ll not realise that there’s a fixed object back there and beep at you constantly that there’s something behind you even though it never gets any closer, it’ll also engage emergency braking.
  11. Mar 7, 2022 at 12:37 PM
    Rwaters
    Rwaters New Member
    2022 Tundra TRD SR5 Crewmax
    I don’t like that it does that in park. It was weird the first time it did it to me. Like you said, sometimes it stays off and other times it shuts off and right back on.
    Dmon187 likes this.
  12. Mar 7, 2022 at 12:53 PM
    Baldwin
    Baldwin New Member
    That would makes sense that it is using the phone's sensor. The rest of my truck doesn't seem to switch to night mode or turn the auto headlights on right away.
  13. Mar 7, 2022 at 12:55 PM
    Baldwin
    Baldwin New Member
    I second this. Mine has done it a few times. Not a problem for me by any means, but it is a quirky thing to have happen.
  14. Mar 7, 2022 at 12:59 PM
    Baldwin
    Baldwin New Member
    Also not sure if it belongs in here, but I find the spring loaded cup holder tabs to be very annoying. They work, but they take an unnatural movement to get it in. Feels like I have to tilt the drink on the right angle and wedge it in there. Hard to describe. Maybe others notice it too...or maybe it's just me LOL.
    EvilSteve[OP] likes this.
  15. Mar 7, 2022 at 4:47 PM
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    2022 Tundra Limted TRD
    There's a setting to shut this off.
  16. Mar 7, 2022 at 5:59 PM
    xc_tc
    xc_tc New Member
    The stop/start system only works in D. If you put it in R or even S, it won’t work…
    Brazak likes this.
  17. Mar 7, 2022 at 6:52 PM
    pursuit2550
    pursuit2550 New Member
    Just wait for the auto back window switch. Toyota will have a big release commercial like they did for the power seats on the tacoma. Only took them since 1995.
  18. Mar 7, 2022 at 8:40 PM
    Wheelboss7177
    Wheelboss7177 New Member
    My 2019 4runner wasn't automatic up and down and I know a few other guys that didn't have it. Which can be an unwelcome surprise when it's cracked in the summer time and fills with mosquitoes.
  19. Apr 12, 2022 at 10:17 PM
    SDT
    SDT New Member
    B
    2022 Limited Tundra Mesquite
    TRD running boards/skid plate
    You push the button up to lower the rear view window, and pull it down to raise it..drives me nuts
    Donas and EvilSteve[OP] like this.
  20. Apr 13, 2022 at 2:50 AM
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    Intuitively backwards, yes, but I think there's some federal safety law that no power window can close by pushing on the button - in case someone has their head in the opening and the button gets accidentally leaned on.
  21. Apr 13, 2022 at 3:29 AM
    Supertech1
    Supertech1 New Member
    This is annoying to me. Either the truck wasn’t doing this initially, or I did t notice it, but now it’s almost every time I park. Wife said I was pushing down on brake too hard. I think I’ll keep the AC on defrost setting and see if that prevents the park shutoff.
    Seems like this auto start/stop would shorten life of starter?
    Toyota1234 likes this.
  22. Apr 13, 2022 at 4:10 AM
    Baldwin
    Baldwin New Member
    I could see dogs doing this all the time. Makes sense to have it standardized.
  23. Apr 13, 2022 at 5:04 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Why would they have switched it for 22? I'm pretty sure in mine you push it forwards/down to open the window and pull it back/up to close it.
  24. Apr 13, 2022 at 5:05 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Why not just switch ASS off just before you park?
  25. Apr 13, 2022 at 5:22 AM
    Supertech1
    Most logical solution…thanks. I’m still learning the buttons and features. I’ll turn off ASS when I start the truck, no issue then.
  26. Apr 13, 2022 at 5:51 AM
    YankeeRon
    YankeeRon New Member
    Ron
    East Windsor, CT
    2021 SR Long Bed
    Cat Security shield, rear headliner molding, BlackVue dash cam, DS grab handle, rear under seat storage, door edge molding, cal trend seat covers, sway bars, hard bed cover, rubber bed mat, intermittent wipers
    Not exactly on point as mines a 2021, but every time I go by a gun store my truck automatically steers into their parking lot. Weird….
  27. Apr 13, 2022 at 6:14 AM
    Kung
    KG, VA
    That feature exists on the 2.5 Gen trucks as well. o_O
  28. Apr 13, 2022 at 6:16 AM
    scape
    scape New Member
    2017 1794 Tundra...Waiting on a 22 1794
    My 17 won't drive past a gas station without pulling in. Looking forward to the 22 arriving.
    joseph_womack, sn_85 and 22PlatWCP like this.
  29. Apr 13, 2022 at 7:44 AM
    JamesAZ
    JamesAZ New Member
    Big difference between a cold and warm start when it comes to wear and tear on the starter.
    Plus, vehicles with the auto start crap have a special type of starter and other components to handle the system turning off and on constantly.
    I wouldn’t worry about wear and tear.
    Cpl_Punishment likes this.
  30. Apr 13, 2022 at 9:52 AM
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    But the more it cycles the more wear there is. So yes it will get worn out faster the more you use it.
    Breathing Borla likes this.
