305/70r17?
Discussion in 'Wheels & Tires' started by airgunner, Jul 31, 2019.
  1. Feb 18, 2022 at 7:27 AM
    RCwyoming
    RCwyoming New Member
    RC
    2019 Tundra 4X4 CM MGM
    I have 285/65R18 on my truck. They stick out the sides so I get to wash my truck a lot. I like them but I tend to float on the snow so I also haul around 200 lbs of wood stove pellets.
  2. Apr 12, 2022 at 9:56 PM
    pvmike
    pvmike Home Depot flexing
    Los Angeles
    2014 Platinum Super White
    TRD Pro suspension, supercharger, 5.29 gears, Auburn LSD
    Just got these installed. 305/70/17 Toyo AT3 on 17x8.5 Titan 7s, +5 offset. Pro suspension with a +1 shackle, so a 2 inch lift up front and .625 inch lift in back. BMC and some liner chopping.
  3. Apr 13, 2022 at 6:01 AM
    RepeatPete
    RepeatPete New Member
    Pete
    2008 Tundra SR5
    How do you like those Titan7’s? I was just revisiting them yesterday after thinking about ways to lighten up my truck a little.
  4. Apr 13, 2022 at 8:43 AM
    pvmike
    Los Angeles
    I bought them specifically because of their light weight. I replaced 20 inch Method NVs on 305/55/20 KO2s. Those wheels were 37 lbs and the tires were 61 lbs, so 98 lbs total per corner. The Titan 7s are 19.5 lbs and the AT3s are 63 lbs, so about 83 lbs total. However, the overall diameter of the wheels and tires went up about an inch, from 33 to 34 inches.
    I wondered how it would feel going up an inch in size but losing 15 lbs per corner. It's a little lighter on its feet, not as big of a difference as I had hoped. But I've driven a supercharged Tundra that was not regeared sitting on 18 inch Method NVs and 35s, and I swear it felt like such a slug. It was almost as if the supercharger and 35s cancelled each other out. So yes, the lighter wheels did make a noticeable difference, enough to counteract the size increase.
    RepeatPete[QUOTED] likes this.
  5. Apr 13, 2022 at 6:16 PM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Looks great! Going with same size and probably same tire as you- ready for BMC... Im 0 offset wheels- approximately how much space from actual metal bumper do you have after you chopped? Wondering if I ned to add bumper shims as well.
  6. Apr 14, 2022 at 9:45 AM
    pvmike
    Los Angeles
    I barely chopped plastic at the bottom but it still rubs at full lock. I'm sure the bumper spacers will help. It's a big tire, only 1/2 inch smaller in diameter than a 35 (most are 34.5), so it's close to the body mount as well even after the BMC.
  7. Apr 14, 2022 at 6:23 PM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    Thanks. Guess when its time Ill shim bumper and do a BMC- liner is already pushed in. I'm on 295/70/17 now (33s); do you notice an increase in "gear hinting" with the increased diameter? I have Method 701s which are heavier than the wheels you are running.
    Pillslinger likes this.
  8. Apr 14, 2022 at 7:03 PM
    pvmike
    Los Angeles
    No but I've got 5.29 gears. That made a big difference.
  9. Apr 14, 2022 at 7:32 PM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    I went from stock 33s to the 305/70 17. Ive been on them about a year now. I have one gradual rise on my commute home at 45mph where I notice the 'gear hunting' issue I've never thought it was bothersome and I experience this everyday. It's just an adjustment and being in tune with the truck at new intervals.
  10. Apr 15, 2022 at 8:24 PM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    pvmike likes this.
  11. May 22, 2022 at 7:36 PM
    pvmike
    Los Angeles
    About a 1000 miles on these so far. Not bad, but I like the KO2s better on the freeway. Love the look though!
    equin, Pillslinger and Toe404 like this.
  12. Mar 14, 2025 at 4:10 PM
    xx3xil3xx
    xx3xil3xx New Member
    Aj
    2018 tundra sr5
    Stock
    305/70/17 at3s with raceline rouge +35...no rubbing...will clear 35s too..only 2 inch upront and stock in rear..
    pvmike, UTAHRTK and LD_15 like this.
