Advice on selecting an AAL kit.
Discussion in 'Suspension' started by Ebeast, Mar 11, 2021.
  1. Mar 11, 2021 at 12:48 PM
    Ebeast
    Ebeast [OP] New Member
    2021 Super White Tundra SR5
    Lift Front: Eibach Pro Stage 2 coilovers set at 2.5 Rear: Eibach Shocks. Deavers 3 leaf progressive pack added to stock leafs 1.5 Tires: Falken Wildpeaks AT3 295/70R18 Bed Rack: KB Voodoo High rise bars. RTT: Tuffstuff overland Ranger Tent
    Hello everyone. I am looking for some advice on AAL kits from people that are running them. I've searched and searched and everyone opinion varies with really no great information that I'm particularly looking for. I have a few kits in mind, but as always I question everything before making a decision lol. Any help is greatly appreciated!
    Lets start with what I drive and what I'm going to be doing in the "wild".
    The Truck: 2021 SR5 CM 4x4 stock (Soon to be 2.5 inch front lift and 34inch tires)
    What I Majority will be doing: I haul a travel trailer camper that is about 4k lbs and will be doing some light off-roading(no real rock crawling) with a RTT and extra camping gear.
    The kits I have in mind so far, but open to suggestions too.
    Icon 1.5 expansion pack: Toytec Progressive 3 Leaf Add-A-Leaf Pack: Deaver 3 Leaf Overload Replacement: Here
    Note: I have also, seen where you just add in a single leaf in the stock leaf pack, but I cant really find much information on that for Tundra's. all the information I can find is for Tacoma's.
    With that I'm really looking at a 1.5 inch lift in the rear to not sag while towing and when I'm not towing and doing the light off-roading I usually have a 140lb RTT with a little extra weight for gear. I've seen a lot of people to say stay clear from blocks. I've seen people with shackles but it seems not ideal for towing, so I've mostly settled on AAL Kits.
    Now the end goal would be to get a full leaf pack replacement, but is way later down the road (unless you know of a decent one for less than $500).
    Thank you for reading my book of a post and for your future advice!
  2. Mar 11, 2021 at 1:06 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome
    Ebeast[OP] likes this.
  3. Mar 11, 2021 at 7:09 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    If you are looking to lift 1.5-2 inches in the rear, I wouldn't over think this. Just slap a add a leaf in the rear and your done. (50 bucks). I'm running an add a leaf, blocks and shackles! lol, no issues.
    Ebeast[QUOTED][OP] likes this.
  4. Mar 11, 2021 at 7:16 PM
    Classy63
    Classy63 Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    I have the toytec leaf pack thingy you posted above, it was a bit rough for the first few days, but it smoothed out. So the toytec add a leaf pack are Deaver leafs.
    What I like about the toytec is you don’t have to modify your current stock leaf springs, just take the u bolts out, lift the rear until the axle drops off the leafs, bolt the leaf pack to the stock leafs, install the longer center pin, chop off about a half inch off the top once it is all tight, and back together it goes.
    What I did to make it easier, I used a big C clamp to pull the leafs back together once I had the new center pin in. That way you can use a hammer and tap each leaf to line it back up for the pin. I also unbolted the front of the leaf springs and used a ratchet strap to pull the leaf pack back
    I don’t pull a big trailer but I have 1500-2000+ pounds in my bed at least once a week, I can tell you it made a difference hauling. But at the end of the day, I still want bags for when I get around that 2000 pound mark
  5. Mar 11, 2021 at 7:18 PM
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    Out of all those three you are viewing at, I high would suggest you stay away from the Deaver F85 AAL especially if you are going to be towing. I have the Deaver AAL and because it replaces the overload spring... you towing and/or run an RTT it will sag and get that leafspring negative really quick. I only have it for offroad use and to get a little bit of a more nicer ride from stock.
    Out of all the three I would IMO go with the toytec AAL just because you still use the overload spring from it's description. Or you can just save all the way up for some Deaver U748 leafpacks instead and do it once right.
  6. Mar 11, 2021 at 8:39 PM
    Ebeast
    Thank you so much! Ah okay there is not much description on their site that say they are Deaver, unless I’m blind. Lol I appreciate the tips for installation too.
  7. Mar 11, 2021 at 8:43 PM
    Ebeast
    Perfect! Thank you so much for your help! Also I would love to get a full leaf replacement right now, but I’ve got a couple of trips coming up real quick and not enough time to save and get it. So I’ve got to skimp somewhere unfortunately.
  8. Mar 11, 2021 at 10:30 PM
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    I have a wheelers single add a leaf. Have about an inch of lift and I kept the overload.
    Ebeast[OP] and clarkritchie like this.
  9. Mar 11, 2021 at 11:02 PM
    TheBeast
    TheBeast The Beach
    the Icon has good reviews too.
  10. Mar 12, 2021 at 7:10 AM
    Ebeast
    Love the truck. what the lift specs you got? is it this one here ? do you use your factory ubolts for this?
    19crewmaxTRD[QUOTED] likes this.
  11. Mar 12, 2021 at 7:44 AM
    19crewmaxTRD
    Seth
    Yep that’s the leaf I used. I did have to get new u bolts. In the front is 5100s on the top setting with 1 shim. So around 2 3/4 lift. The tires are 285/75r18 so like a 34.5x11.5
  12. Mar 12, 2021 at 10:15 AM
    Ebeast
    Nice! okay ill take a look at that one too. did you have to do a differential drop kit on yours?
  13. Mar 12, 2021 at 10:24 AM
    Rebel Tundra Man
    Rebel Tundra Man New Member
    Tyler
    Western Kentucky
    2016 Black Limited CM
    4" RCX Lift, 20x10 Fuel Coupler's, 35x12.50x20 Nitto Ridge Grappler's, Color Match Front End, LED Bulbs, RCX Tube Steps, Green LED Underglow
    I am running a rough country 4" lift in the front. This is the part I dont know what I have exactly, but I ordered my lift from a local shop that a good buddy of mine owns. When I ordered the lift I told him I wanted rough country to include a leaf instead of the blocks because I did not want blocks in the rear. However he told me I could just have a set of extra leafs, because he has a large amount of them laying around from other truck model lift kits he has purchased and just installed the lift blocks on. The leaf's are universal. The extra leaf did give me about 1.5" of lift. I haul a tandem trailer that weighs about 2500lb and my tractor that I haul on it weighs about 8-9000lb. I did not see any benefit to the extra leaf being installed for hauling. I did end up adding air bags and on board air for the setup. That was an extra $700 the ride with hauling extra weight is great now, and I also use the bags to finish up the lift in the rear to make it set level.
  14. Mar 12, 2021 at 10:30 AM
    19crewmaxTRD
    Seth
    I did do a diff drop also, its a mixed bag people saying you need it or don’t. I ran one on my last truck so I figured I’d do the same on this one.
  15. Mar 15, 2021 at 11:50 AM
    Ebeast
    Thanks everyone for the advice! i ended up going with the toytec progessive 3pack kit.
    jeremyd likes this.
  16. Mar 15, 2021 at 1:49 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Post a follow up how it rides when there done getting installed.
  17. Apr 9, 2022 at 7:09 AM
    clarkritchie
    clarkritchie New Member
    Hey @Ebeast - What is your feedback? I am also eyeing the AAL.
  18. Apr 9, 2022 at 7:19 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I've used an AAL in the stock pack and it was perfectly fine. I didn't tow much except for a few trips with a UHaul. The lift was around 1.5" from an advertised 2" with the kit I bought.
    That being said, I think you'd get all you need from an RAS setup.
  19. Apr 9, 2022 at 7:23 AM
    clarkritchie
    I've had AALs before -- one was good, one was stiff as hell. Dumb Q but are new shocks required?
  20. Apr 11, 2022 at 7:11 PM
    Ebeast
    I apologize for not getting back to everyone sooner.
    the ride seems good, but not buttery smooth if that is what you are hoping. I would say it’s a little bit stiffer but that’s okay with me. I did it for the lift / better payload capabilities; which feels really solid now. I did leave in my overload spring.
    For the lift it gave about 1.5 inch lift but I’d say it settled down to 1.25 as advised. I highly recommended the 3 leaf over the single.
    seemed simple to installed as I did it with a buddy of mine and we decided to do both at the same time. BIG NO NO without the proper support. Finally got it back lined up though after many of hours of struggle. So doing one at a time would be way better.
    Let me know if anyone has any other questions. I’d be happy to answer!
    clarkritchie[QUOTED] likes this.
