4x4 knob removal
Discussion in '2.5 Gen Tundras (2014-2021)' started by BamatundraSC, Apr 10, 2022.
  1. Apr 10, 2022 at 8:08 AM
    BamatundraSC
    BamatundraSC [OP] New Member
    Greer, SC
    2021 SR5 CM
    TRD Pro grille, color matched hood bulge, TRD Pro headlights, color matched front bumper end caps, Rough Country two inch loaded front struts, Matte black SCS Ray10’s, Cooper Rugged Trek 275/70/18, Rough Country tri fold hard bed cover, Dirty deeds 12” exhaust
    I’m trying to install the AJT Design black knob with out having to take the whole dash out. I’ve watched the AJT video and can get the top tab loose pretty easy. I can’t get that bottom one to release. To anyone who’s done it, how’d you get the bottom tab to let go?
  2. Apr 10, 2022 at 8:16 AM
    I used the "L" shaped ones.
    BamatundraSC[OP] and Taco-Spike like this.
  3. Apr 10, 2022 at 8:20 AM
    Taco-Spike
    Two Trucks
    they are handy
    2mchfun and BamatundraSC[OP] like this.
  4. Apr 10, 2022 at 8:24 AM
    BamatundraSC
    Greer, SC
    2021 SR5 CM
    Excellent! Good ole Harbor Freight. Those guys have a tool for everything.
    I’ve mashed so much with my index finger that it’s sore to the touch.
  5. Apr 10, 2022 at 9:00 AM
    And they are on sale today, $0.99.
  6. Apr 10, 2022 at 9:25 AM
    BamatundraSC
    Greer, SC
    2021 SR5 CM
    Bonus! The wife’s out running errands so I sent her the link to go grab them for me.
  7. Apr 10, 2022 at 10:22 AM
    TBS
    TBS New Member
    2021 SR5 CrewMax 4x4 Barcelona Red
    E50 extinguisher, Valhalla Plates, ESP Storage, Chrome Delete, Pwr Tailgate Lock,
    I had the same problem. My fingers would not reach the bottom one. I also had to use a pic to reach it.
    A note of caution.
    DO NOT LOOSE THE PLASTIC BALL BEARINGS!
    Most YouTube videos do not mention them but I know one did. (Honestly do not remember which one)
    Here are screen shots of them. I have a '21 so they still had grease on them and did not fall out but your situation may vary.
    Wish you luck on getting disconnected.
  8. Apr 10, 2022 at 11:28 AM
    :hattip:
    Taco-Spike likes this.
  9. Apr 11, 2022 at 6:59 PM
    BamatundraSC
    Greer, SC
    2021 SR5 CM
    Good to know! Mine is also a 21, but had you not mentioned to be on the lookout, I sure would’ve lost them.
  10. Apr 11, 2022 at 7:03 PM
    Taco-Spike
    Two Trucks
    You get it out?
  11. Apr 11, 2022 at 7:06 PM
    BamatundraSC
    Greer, SC
    2021 SR5 CM
    Not yet. I got busy Sunday afternoon and haven’t had a chance. I might try tomorrow if I get time.
    Taco-Spike[QUOTED] likes this.
  12. Apr 16, 2022 at 5:04 PM
    BamatundraSC
    Greer, SC
    2021 SR5 CM
    Finally had time to get that knob out. That pick set from Harbor Freight has already paid for itself.
    1UP and Jim LE 1301 like this.
  13. Apr 16, 2022 at 5:05 PM
    :woot:
  14. Nov 5, 2024 at 11:53 AM
    John18
    John18 New Member
    Michigan
    2018 Toyota Tundra Limited
    - 2in Mammoth front leveling kit - 2019 TRD pro grill, 218 altitude black, OEM - 218 altitude black color matched hood bulge, OEM - Bumpershellz front bumper chrome delete - Ceramic 18% front window tint - Black badge covers - Black handle covers
    I fiddled around with the picks, trying to get the knob off for an hour with no success. Finally got fed up and drilled a hole so I could get a pick easily underneath to reach the bottom tab. Probably not the best way of doing it, but got the knob out shortly after and all of the dash pieces went back with no issue.
    1UP, Echo5Golf and KNABORES like this.
  15. Nov 5, 2024 at 1:25 PM
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    I had a hard time also but used the picks and boom. Also had a hard time taking off the chrome ring. Just take your time
  16. Nov 5, 2024 at 2:30 PM
    GLaDOS
    GLaDOS Engineer
    Central Oregon
    2014 Tundra SR5 Double Cab
    I also struggled to remove the 4x4 knob from the center console when I tried following the AJT video. Instead, I had an easier time by first pushing the bottom tab in (upward) with my index finger and then lightly pulling the knob toward me with my other hand. That allowed the bottom of the knob to slip past the cutout while the top of it tilted backward into the center console. This then made it significantly easier to push the top tab in (downward) because there’s more hand space above than below the knob within the center console. Once again, I lightly pulled outward on the knob with my other hand to get the top of the knob past the cutout and free to be unplugged.
    I had a similar pick set mentioned above and found it mostly useless since I couldn’t tell whether or not the tab on the knob was being pressed in. Instead, doing the opposite of the AJT video was easier. Granted, it still hurt my hand.
    Like others, I also had trouble with removing the chrome ring. I found that a set of precision flathead screwdrivers made quick work of the gray tabs by carefully prying the tab out (toward the center of the knob) and then sticking a larger precision flathead into the open gap to prevent it from recessing back into the locking position. This allowed me to unseat the other gray tab without much hassle.
  17. Apr 18, 2025 at 7:44 AM
    TacoFam23
    TacoFam23 New Member
    Jordan
    22' Taco, 20' Tundra, 85' Landcruiser
    AJT interiors Chrome delete on exterior trim
    I put mine back together and had no tension while twisting from 2wd to 4wd and it was super loose. I realized that those plastic ball bearings fell out and so di two springs. Anyone know how or where to put those back in?
  18. Apr 18, 2025 at 7:54 AM
    Echo5Golf
    Echo5Golf New Member
    Phil
    Tundra Hunter
    After pics please…!
  19. Apr 18, 2025 at 9:22 AM
    lerbud1
    lerbud1 New Member
    Larry
    Waco, TX
    2021 Tundra SR5
    Post #7 shows them in a picture and where they are located.
  20. Apr 18, 2025 at 10:28 AM
    TacoFam23
    Jordan
    Are the springs supposed to go under those plastic ball bearings?
  21. Apr 18, 2025 at 10:58 AM
    lerbud1
    lerbud1 New Member
    Larry
    Waco, TX
    2021 Tundra SR5
    I would assume so. I have a 21 and was worried about the bearings falling out when I did mine. I dont recall seeing any springs so I think they go under the bearings.........
  22. Jul 12, 2025 at 5:56 PM
    eb5hb
    eb5hb New Member
    Eric
    2016 Tundra TRD
    So I just replaced the ring for the chrome delete and now my 4L doesn’t work, it worked like 2 weeks ago. I assume I have something misaligned, about to pull back apart, just figured I’d preemptively ask. I’m on a 2016 tundra. TIA
