safe undercoating that will not damage wiring hardness floor plugs etc
Discussion in '2.5 Gen Tundras (2014-2021)' started by CanTundra, Apr 9, 2022.
  1. Apr 9, 2022 at 4:17 PM
    CanTundra
    CanTundra [OP] New Member
    2021 Tundra TRD Off Road
    I am looking for some feed back from guys that know the brand they used and has had product on truck for 3-4 year to report back how well the rubbers etc are doing.
    I am thinking to go with the blaster brand of product on my 2021
  2. Apr 9, 2022 at 4:24 PM
    FluidFilm is what the rust belt guys are using with good results.
    panicman, Fallingblock, alb1k and 3 others like this.
  3. Apr 9, 2022 at 4:27 PM
    Any of the "forever" coatings I've seen were rubberized stuff that sealed in moisture and destroyed the vehicle. Look at fluid film, wool wax, etc. that get reapplied once or twice a year.
    panicman, Brownsfanhere and Tundra234 like this.
  4. Apr 9, 2022 at 5:33 PM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    Have had Woolwax on an '05 T4R for 18 months. Have not seen any issues.
    Spyker and Brownsfanhere like this.
  5. Apr 9, 2022 at 5:39 PM
    Brownsfanhere
    Brownsfanhere New Member
    2015 Crew Max
    Krown with good results. Just drips for weeks is the only downfall. So no garage parking or driveway parking for a month in my experience. The blaster brand is surface shield or something. Couldn’t find that anywhere. Been with known for a couple of years. I approve of the product but mention above the drawbacks.
  6. Apr 9, 2022 at 6:00 PM
    bmw345
    bmw345 New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    In New England. Using NH Oil once a year in the fall. Undercarriage still looks new! 4 yr old 2018.
  7. Apr 9, 2022 at 6:51 PM
    CanTundra
    Yup I am aware of the brands and what they can do to help with metal more concerned about plastics,rubber caps wiring loom etc under side
    alb1k likes this.
  8. Apr 9, 2022 at 7:57 PM
    ZPMAN
    ZPMAN 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
    coldcanuk and TILLY like this.
  9. Apr 9, 2022 at 8:05 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I use this also, after three New England winters, still looks like brand new underneath. 6 cans every 2-3 years and you're all set. Great stuff. :thumbsup:
    Terndrerrr likes this.
  10. Apr 9, 2022 at 8:07 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    I’m two winters in with Amsoil Heavy Duty Metal Protector. Highly recommended. No problems eating into rubber or plastics underneath.
  11. Apr 9, 2022 at 8:18 PM
    MeetJoe
    MeetJoe New Member
    Maryland
    2021 CrewMax SX
    OEM TRD Pro Led Headlights OEM LED Fog lights iHacker Harness OEM Tube Step OEM trifold hard tonneau OEM Driverside Grab Handle and Pillar OEM Exhaust tip Wireless CarPlay CarLinkit 3.0 Snack Crumbs
    Check out CRC Marine heavy duty corrosion inhibitor. I don’t have 3-4 years of exposure but super pleased with how it held up through this past winter.
    Product description:
    A long term, flexible corrosion inhibitor that protects & preserves metal surfaces, electrical connections, engine components & fasteners, subject to salt spray and high humidity. Also provides effective protection for steering & throttle linkages.
    APPLICATIONS
    Electrical connections (connections must be made first), engine components, equipment storage, fasteners, motors, salt spray protection, shaft, spindles, steering & throttle linkages
  12. Apr 9, 2022 at 8:28 PM
    Fallingblock
    Fallingblock New Member
    Southern MD
    2017 SR5 DC Tundra
    This
  13. Apr 9, 2022 at 8:29 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I'm not saying it's the best, but fluid film is carnauba wax based. I like it. Certainly won't hurt wires or plastic.
  14. Apr 9, 2022 at 8:31 PM
    Fluid Film does say that it can cause rubber to swell if it's not an oil resistant rubber, but there's no product that isn't going to have some kind of similar warning or disclaimer. It shouldn't hurt anything plastic though, as it is lanolin based.
  15. Apr 9, 2022 at 8:32 PM
    alb1k
    Left Coast
    It's good
    Lanolin - thanks brother
    GODZILLA[QUOTED] likes this.
  16. Apr 9, 2022 at 8:48 PM
    You're welcome?
    Edit: Ah, I didn't see you post until after mine. Idk, might have carnauba in it too?
  17. Apr 9, 2022 at 9:06 PM
    FortyNorth
    FortyNorth New Member
    Northern ON
    2014 Tundra Super White SR5
    Northern Ontario- Fluid Film. There might be “better” for much more $ but I don’t see the value unless you’re a collector or something maybe. My truck is going on 9 yo with nothing other than very minor surface rust on the frame/diff (I skipped a couple years), nothing started anywhere on the body panels. No drilling holes or pulling plugs, just surface spraying. I am in no way careful of collateral damage while spraying on plastic, rubber, brake lines etc. No problems, whatsoever. I think it’s only certain non oil resistant rubbers that would be an issue (which wouldn’t make sense for auto parts come to think about it). It has a low flame point so burns off anything quickly when you start her up for a bit. Just like pumpkin spice- smells like Fall!
    Tundra Dude 45 likes this.
  18. Apr 9, 2022 at 9:49 PM
    alb1k
    Left Coast
    It's good
    I would have to look, but as soon as you posted, Lanolin rang true.
  19. Apr 10, 2022 at 6:03 AM
    tiogajoe
    tiogajoe New Member
    Joe
    little marsh Pa.
    2020 DC TRD Limited
    Stock
    x2 Krown
  20. Apr 10, 2022 at 6:16 AM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Like sheep’s wool?
  21. Apr 10, 2022 at 6:25 AM
    Yes. Similar to Wool wax. Both are lanolin based.
  22. Apr 10, 2022 at 6:33 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Amsoil has been good. Make sure you apply on the street or a parking lot…overspray on your driveway/garage floor isnt cool.
  23. Apr 10, 2022 at 6:38 AM
    Tundra Dude 45
    Tundra Dude 45 New Member
    Eric
    2019 SR 4.6L DC 4X4
    8” BAMuffler, TRD airflow accelerator, front window tint/windshield sun stripe, debadged tailgate 4x4 emblem, trimmed mud flaps, antenna removed stainless screw added, TRD rear sway bar, AFE high flow air filter.
    Bought my truck new in 8/19 I’ve used Fluid Film since new for the first 2 winters, everything looks great underneath and last year I used the PB blaster brand and I like it better. I’m in northern Ohio salt city.
  24. Apr 10, 2022 at 6:43 AM
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    FluidFilm FTMFW :thumbsup:
  25. Apr 10, 2022 at 8:34 AM
    Mahoganyman
    Mahoganyman New Member
    Western NY
    2018 Crewmax
    Carwell,
    If you can get it where you are.
  26. Apr 10, 2022 at 9:37 AM
    alb1k
    Left Coast
    It's good
    There was a video review/test that had pb blaster on top. I don't think you can go wrong with that, or pretty much anything listed here. I think the only rubber that would swell with most is foam rubber.
