Dash gear Indicator and cruise control
Discussion in '2nd Gen Tundras (2007-2013)' started by MonteSTL, Apr 8, 2022.
  1. Apr 8, 2022 at 11:59 PM
    MonteSTL
    MonteSTL [OP] New Member
    Monte
    2007 Tundra SR5 black
    stock
    Evening all, maybe you could give some insight to my issues. Doubt they are all connected but you never know…
    1.a week ago my right rear blinker went out. Went to store got a two pack popped new one in and dead still. Used a test light and no power going to the socket.
    2. Tonight I noticed my cruise control won’t light up or work.
    3. While seeing if there was something to the dash lights and cruise control, I noticed that my D drive gear indicator light is off while in drive, but when I shift to park, both the P / park and D/ drive lights were both green for a second or two and then the D turns off.
    any help would be greatly appreciated.
  2. Apr 9, 2022 at 12:12 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Do any of the other blinkers work? If one doesn't have power most likely none of them do. Unless you have a broken wire on just the RR blinker circuit.
    Anytime you loose power checking all the fuses should be the first step. In this case especially the ones in the interior fuse box under the dash.
    I would definitely check the 7.5A LH-IG fuse as it powers the flasher relay/blinkers. Your other problems might also be tied to this fuse as well.
    Here is the location in the interior fuse box.
