2017 aftermarket heated seats
Discussion in 'General Tundra Discussion' started by gregsalmon, Apr 6, 2022.
  1. Apr 6, 2022 at 4:42 PM
    gregsalmon
    gregsalmon [OP] New Member
    greg
    2017 tundra
    non yet
    i have a 2017 Tundra from Doxon Toyota in Washington State. It has aftermarket heated seats, had them when I bought it. The seats got hot and burned some holes in the back rest. I called Doxon, they didnt know anything about how to disable them. Any ideas on this? Dont want to unhook something else by accident.
  2. Apr 6, 2022 at 5:01 PM
    Rocko9999
    Rocko9999 New Member
    Unbolt the seat and look under the seat at the wiring. Should be obvious where they tapped into oem wiring or ran a new wire for the heating element. Once you find it just unplug or snip and secure wiring appropriately.
    1lowlife likes this.
  3. Apr 6, 2022 at 5:19 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Don't undo any yellow plugs
  4. Apr 6, 2022 at 8:09 PM
    gregsalmon
    greg
    2017 tundra
    non yet
    Thanks! I saw the yellow plug. Its still not apparent to me which one to unplug. I was surprised that the dealershiop wasnt interested from a liability standpoint. I am sure this is not the only seat like this....
  5. Apr 6, 2022 at 8:11 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Post a pic
  6. Apr 6, 2022 at 8:14 PM
    Look for 2 of the same plastic plugs, usually white. 1 should be coming from the bottom of the seat and the other should be coming from upper seat back.
  7. Apr 6, 2022 at 9:40 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    The yellow plug is the air bags..
    ANY yellow plug or cable in your truck is to the air bags.
    I would disconnect the battery before unplugging any of them.
    Where the power switch for your seat heaters?
    Do you have 2 knob dual zone climate control or the three knob manual?
    What trim model is your tundra? SR5, Limited, Platinum, 1794?
    If they are aftermarket, they have to have an aftermarket on/off or off/lo/hi switch.
    They will also probably have wires running to them in the seat that are not connected to any of the 3 OEM plugs under the seats.
    Here are my switches to my aftermarket seat heaters..
    8FCE5971-E516-486C-905D-027100B9B88A_zps_c66a01b962d16c1a1ccb4cc71cd50159ca50715f.jpg
  8. Apr 7, 2022 at 4:44 PM
    gregsalmon
    greg
    2017 tundra
    non yet
    I have a three position rocker switch on the side panel of the seat. I THINk I can see where to cut, makes me nervous though.
    pics to follow
  9. Apr 7, 2022 at 4:45 PM
    Why cut? There has to be plugs.
