Big job done, now no spark. Please help a simple man
Discussion in '1st Gen Tundras (2000-2006)' started by Certified Dipstick, Apr 6, 2022.
  1. Apr 6, 2022 at 3:20 PM
    Certified Dipstick
    Certified Dipstick [OP] New Member
    2001 3.4L Auto Base, Too long in the sun grey
    Compressor, Inverter
    First off this is my first post so if I'm doing this incorrectly, feel free to call me out or I'll probably continue doing it.
    Anyways, I performed a timing belt replacement.
    New knock sensors.
    Repaired the knock sensor wires.
    Installed a time sert in the hole the my spark plug was ejected from.
    Timing belt was not blown but heavily cracked which was discovered while replacing the knock sensor.
    Now I appear not to have any spark, I've gone over all my connections, right down to removing the intake as to catch anything sneaky hiding in the back.
    I smell fuel when cranking.
    I will be picking up a new multimeter tomorrow as well as a fuel pressure tester and a spark plug tester, as my multimeter shat itself and I want to be certain of my other beliefs.
    If anyone has advice or has run into this themselves, input would be greatly appreciated, I have become a burden to all those around me for longer than I'd like as i have no other wheels.
    Thanks!
  2. Apr 6, 2022 at 3:21 PM
    Certified Dipstick
    Oh new plugs, wires and coils too.
  3. Apr 6, 2022 at 5:10 PM
    Ericsopa
    Ericsopa Old man and the sea
    I'm not familiar at all with the 1st gen Tundras, so this is nothing more than a WAG!! But in replacing your timing belt did you disconnect a sensor (purposely or inadvertently) say on the crankshaft or a camshaft. A sensor that would indicate TDC on the compression stroke so the ECU knows when to fire the plugs? If there is such a sensor, the ECU might never fire the plugs as it wouldn't know the engine was cranking. Like I said ... a WAG.
  4. Apr 6, 2022 at 5:40 PM
    Any codes? If you recently did all that work, there are lots of possibilities. Coil packs and wiring should be retraced to ensure all is hooked up correctly. Timing could be off if anything moved during reassembly. A sensor could be unplugged or could have gotten damaged during the belt swap. If you have no codes to help you, start taking the covers off and inspect all of the work to retrace your steps. Frustrating to do a big job and it doesn’t fire up when your done.
    texasrho83 likes this.
  5. Apr 6, 2022 at 5:41 PM
    skip1980
    skip1980 New Member
    Columbia, Missouri
    Do you have a scan tool? Need you see if you are getting rpm signal. If not you probably not going ro get spark. Did you possibly not plug in crank/cam sensor? Any codes?
    KNABORES likes this.
  6. Apr 6, 2022 at 7:17 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I am of absolutely no help whatsoever with your issue but I wish you luck and welcome!
  7. Apr 6, 2022 at 7:58 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Yeah absolutely check codes and see if you have any. Code reader is almost essential these days.
  8. Apr 6, 2022 at 9:31 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Was the trigger wheel for the crank sensor reinstalled? It’s the toothed piece that goes between the crank timing gear and crank pulley. Without it it won’t spark because it has no clue where the engines at
  9. Apr 6, 2022 at 10:41 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    Make sure the fuel is getting to the injectors.
  10. Apr 6, 2022 at 11:54 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    alb1k, N84434, bmf4069 and 1 other person like this.
  11. Apr 7, 2022 at 6:16 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Yup...I agree.. My money is on disconnected crank/cam position sensor.
    alb1k likes this.
  12. Apr 7, 2022 at 9:03 AM
    Another vote for CPS here, or damaged CPS wire.
  13. Apr 7, 2022 at 9:23 AM
    Certified Dipstick
    I gotta say first, wow didn’t expect this much advise! Very appreciative of it though!
    I’m gonna give these all a shot tonight if the weather clears up and get back to you guys. For now, timing appears correct with all markers lined up and the new belt lines were lined up as well.
    I do have a OBD tool albeit a upper end simple one, it’s no solus but I should be able to check RPM with it while staying dry so that will get looked at tonight for sure.
    And unplugged sensors are not getting ruled out as I pulled the plenum and found the little guy at the back disconnected.
    I’ll keep you all posted, and thanks again!
    empty_lord and FrenchToasty like this.
  14. Apr 7, 2022 at 9:32 AM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC! Please keep us updated!
  15. Apr 7, 2022 at 9:32 AM
    Certified Dipstick
    this is a mortifying concept, but it is now on the list
  16. Apr 7, 2022 at 9:38 AM
    Certified Dipstick
    Thanks!
    And working on the mangler cery, I’ve had a couple projects I thought just needed one more uga dug that we’re instantly moved to the uh oh.
    And the DS certification presses is actually handled through the possum lodge
    bmf4069, Mogo Gogo, KNABORES and 2 others like this.
  17. Apr 7, 2022 at 2:07 PM
    The truck that everyone wants the manual transmission, but no one wants the motor.
    It’s even harder to believe some of the 2nd gens had the 4.0 v6 in them!
  18. Apr 9, 2022 at 11:07 AM
    Certified Dipstick
    Alright, plugged in the code reader and we’ve got an rpm reading, crank looks to be all hooked up. Only one camshaft has a sensor and it looks to be attached and undamaged.
  19. Apr 9, 2022 at 11:48 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    What codes of any ?
  20. Apr 9, 2022 at 12:27 PM
    Certified Dipstick
    N
    No codes, there was a misfire code that I cleared that happens when the spark plug ejected and the knock sensor codes
  21. Apr 9, 2022 at 12:30 PM
    Certified Dipstick
    Alright timing covers all disassembled, and timing marks look good.
    Jack McCarthy and bmf4069 like this.
  22. Apr 10, 2022 at 10:55 PM
    empty_lord
    05 rollover special
    Oh.. this is a v6.
    Hmmm is the igniter plugged in? How about the ground bolt on the intake plenum.
    Yota303 likes this.
  23. Apr 11, 2022 at 2:29 PM
    Certified Dipstick
    the igniter is the bad boy on the RF wheel well, correct? and yeah the ground on the plenum sadly wasn't missed
  24. Apr 11, 2022 at 2:31 PM
    Certified Dipstick
    yeah this thing puts out something like 190 horse. but hey, until now it did it everyday, all day!
  25. Apr 11, 2022 at 2:33 PM
    Certified Dipstick
    Thank for the welcome! When I get this resolved I wont leave you all high and dry. Hopefully someone can learn from my experience
    Blueknights75[QUOTED] likes this.
  26. Apr 11, 2022 at 2:36 PM
    empty_lord
    05 rollover special
    Next question. Any aftermarket alarm? Have you tried disconnecting the battery, turn the key to on, and reconnect the battery then start? Sometimes alarms will kill spark but not fuel
  27. Apr 11, 2022 at 2:37 PM
    Certified Dipstick
    Big update, I do have spark but no start, I had a friend checking while I cranked and turns out he's blind. We tried it with me spotting and holy hellfire we've got voltage, so I've been chasing this the wrong way. I've got a fuel pressure gauge on the way.
    Blueknights75 likes this.
  28. Apr 11, 2022 at 2:39 PM
    Certified Dipstick
    Sorry didn't see you reply as I posted just now, did disconnect battery overnight. No aftermarket alarm.
    I will try again with the pattern you mentioned.
  29. Apr 11, 2022 at 3:49 PM
    skip1980
    skip1980 New Member
    Columbia, Missouri
    If you think it's fuel problem take intake of throttle body and have a buddy spray brake clean as you crank it. If it starts and runs on the brake clean then it's fuel issue. We used to drive vehicles in on brake clean at the dealership when you had a vehicle with a fuel pump out.:D Alot easier then pushing it!
    bmf4069 and Sirfive like this.
  30. Apr 11, 2022 at 4:14 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Carb cleaner to test for intake leaks?
