2016 1794 Delayed Engine Turnover
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cwalker417, Apr 6, 2022.
  1. Apr 6, 2022 at 9:56 AM
    Cwalker417
    Cwalker417 [OP] New Member
    Lately I have been having this intermittent delayed turnover when I go to crank the engine. It doesn't only happen in the morning or when its cold or anything like that, it seems pretty random but happens usually every day at some point. Truck has 110k miles and never changed fuel filter, fuel pump or plugs, fyi (never had an issue until now) Also had battery tested and everything seems good. Below is the link to the sound. Anyone have any idea whats going on here? Thanks
    https://youtu.be/J8gOGoQuGcQ
  2. Apr 6, 2022 at 10:20 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    FF engine? Might need an ethanol reading reset.
  3. Apr 6, 2022 at 10:37 AM
    Cwalker417
    No, not a Flex Fuel engine, standard 5.7 v8
  4. Apr 6, 2022 at 10:38 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    When you say battery tested, just a voltage check or was it load tested? Terminals at the battery tight?
  5. Apr 6, 2022 at 10:48 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    spark plugs are past due, get those changed. When was battery replaced? if original, replace it. If it has been replace, check the size. Ive seen people put new batteries in that are too small. Last time air filter changed, is it clean?
    Im going to bet on battery/ground. Could also be starter/soleniod or fuel pump starting to go but I would check the other things first.
  6. Apr 6, 2022 at 10:52 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Aren't plugs technically 120k by the book?
    *just checked and yes. I can agree that plugs could be a factor, but IMHO, I'd imagine it to be more consistent with other drivability concerns if it were plugs. But, they are cheap enough and he is close enough to at least do them early and see if it helps. Doesnt hurt, thats for sure.
  7. Apr 6, 2022 at 10:55 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Can you just 100% confirm engine code?
    FE or FBE
    Thanks
    AgileTundra and Toyotoholic like this.
  8. Apr 6, 2022 at 12:26 PM
    Cwalker417
    It's not throwing any check engine light codes
  9. Apr 6, 2022 at 12:28 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Engine code, not faults.
    I know you said not FFV, I'd just like to reconfirm.
    AgileTundra likes this.
  10. Apr 6, 2022 at 12:31 PM
    Cwalker417
    I may be mistaken. Looked in my Manual and it seems like it's an FFV. The code on sticker under hood is 3UR-FBE
    14burrito likes this.
  11. Apr 6, 2022 at 1:08 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    And that's why I wanted to know. First step, IMO, would be reset ethanol reading.
    AZBoatHauler and Toyotoholic like this.
  12. Apr 6, 2022 at 1:31 PM
    Cwalker417
    How do I go about doing that. Watched a video about a TSB related to this issue regarding cold starts and the fuel pump. Could this be it?
  13. Apr 6, 2022 at 8:27 PM
    Cwalker417
    After reading many threads, it appears that more than likely I have the TSB issue. My question is, does getting the ecu flashed or reset typically fix the problem? And if temporarily for how long? Im really not in a position to be paying 1k for a fuel pump replacement right now. How much have you guys out of warranty been paying for the ECU/Pump?
  14. Apr 6, 2022 at 8:33 PM
    Toxicbanana
    Toxicbanana New Member
    2021 Tundra Crewmax
    Try turning it on but wait 10 seconds then try to crank it over, See if that causes any change in its starting behavior.
  15. Apr 7, 2022 at 11:31 AM
    Cwalker417
    I tried turning on for 10 seconds and then cranking at it cranked right up first thing in morning but still doing some delayed rough crank middle of day.
  16. Apr 7, 2022 at 11:37 AM
    Toxicbanana
    2021 Tundra Crewmax
    And just to clarify, the middle of the day also had a 10-second delay before trying to start the engine?
  17. Apr 7, 2022 at 11:38 AM
    Cwalker417
    Yes, in morning it cranked no delay, mid morning small delay, then just mid day longer delay. I turned ignition to on for 10 secs before turning over each time
  18. Dec 29, 2024 at 7:00 AM
    Cwalker417
    In case anyone is checking this thread researching the same issue with their truck, I wanted to provide an update. Took the truck to my local independent Toyota shop and he originally diagnosed it as a fuel pump that needed to be replaced, since this was the most obvious thing being that my truck has the Flex Fuel engine. We got the fuel pump replaced and the truck still had the same issues. He then pulled all the injectors and realized I had a couple leaking injectors causing the rough start. Long story short, I swapped out all 8 injectors and have not had an issue since. My mechanic was very surprised this was the problem because these trucks usually don't have issues with the injectors, and actually refunded me the labor on the fuel pump install for incorrectly diagnosing it. Since then, I've also swapped all 8 spark plugs and also ended up doing the timing chains & water pump. Truck has 166k and running strong.
    Tunrod likes this.
  19. Dec 29, 2024 at 9:32 AM
    AZBoatHauler
    So.Arizona
  20. Dec 29, 2024 at 11:03 AM
    Cwalker417
    And your point? Obviously, I mentioned this to him. He pulled the injectors and sent me a picture of them, showing a couple of them leaking on a napkin. He even showed me what you're talking about on Tech stream. If what you're saying is true then I would still have issues after changing the injectors, which I did not. Not a fly by night shop, 20 year Toyota independent mechanic, if what you're suggesting is that I got taken advantage of, you're wrong.
  21. Dec 29, 2024 at 2:13 PM
    AZBoatHauler
    So.Arizona
    I guess my point was if a different and much less costly remedy is out there for 99.9% of these scenarios- I’d recommend anyone looking here try that first. Hate seeing people spending money on a solution that doesn’t fix the problem like you initially experienced.
    :hattip:
  22. Dec 29, 2024 at 2:47 PM
    Cwalker417
    LOL doubtful its 99.9%. Most people with issues with their trucks don't even come to online forums to post about them. Were talking about two different issues here, same symptoms, different diagnosis.
  23. Dec 29, 2024 at 8:58 PM
    lr172
    lr172 New Member
    07 DC
    When i just heard the video , i went straight to a leak down of pressure in the fuel system. It normally stays pressurized for a long time. However, there is a check valve in the pump and if this leakes or one of the injectors leak, the system losses pressure. Many other makers run the pump for a few seconds, to re pressurize the system, but toyota doesn’t do that. Therefore it takes many seconds of cracking to fill it back up. The turn the key on fo 10 sec trick only works with the makers that run the pump at key, on, but not toyota.
    while the ethanol %age problem creates long cranking and rough starts, you cannot attribute ALL crank no start issues back to that. There are other causes and this is a good example of one. They replaced the correct parts and problems disappeared. Obviously not an alcohol issue. Kudos to the ops mechanic. He gets it and went to the correct sources and even picked the most likely firt.
    Cwalker417[OP] likes this.
