Best Battery
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jalzate44, Jan 14, 2022.
  1. Jan 15, 2022 at 6:58 PM
    #61
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    And a likely a few weeks delivery.
    I might be the Guinea pig. I just swapped in the Odyssey this past week. Apparently it’s the same people, same assembly line, same factory as Northstar. Just different color packaging.
  2. Jan 15, 2022 at 7:00 PM
    #62
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Nevertheless, I think I'll get another Northstar while the stock is out there.
  3. Jan 15, 2022 at 7:02 PM
    #63
    mountainpete
    Check the build date if you can. Sounds like they stopped making them last summer.
  4. Jan 16, 2022 at 1:18 PM
    #64
    AZTundra
    Paul
    Phoenix, AZ
    So I trimmed down the GM diode and went to install it, but everything I've read says it replaces the stock 7.5 amp fuse labeled ALT-S. My stock fuse is a 5 amp. Anyone have the 5 amp? Am I still okay to swap with the GM diode? Thanks.
    HulkSmurf14 likes this.
  5. Jan 16, 2022 at 1:41 PM
    #65
    mountainpete
    My original fuse in ALT-S was 5 amp. Just checked and confirmed.
    HulkSmurf14 and AZTundra[QUOTED] like this.
  6. Jan 16, 2022 at 1:46 PM
    #66
    AZTundra
    Paul
    Phoenix, AZ
    Thanks, I'll go ahead and swap them. The discrepancy had me stumped.
    OhEmmBee and HulkSmurf14 like this.
  7. Jan 16, 2022 at 2:47 PM
    #67
    Gunship Guy
    Gunship Guy New Member
    Rick
    Thank you for the reminder. Fell into the trap of thinking batteries have been sealed for decades. Just finished topping off each cell. In August it will be 7 years old. Replacement is on the horizon whether it shows signs of failing or not.
    Thanks again man, sometimes it takes someone pointing out the obvious to turn on the light.
  8. Jan 16, 2022 at 6:08 PM
    #68
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    You're good man. Not much difference between 5 and 7.5A.. I realize it's 50% but really, you're good and will have no issues.
    AZTundra[QUOTED] likes this.
  9. Jan 17, 2022 at 8:53 AM
    #69
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    Fun fact, did the GM diod on my 08 tundra. You have a 50/50 shot on the “arrow direction”.
    Get it wrong battery light comes on. Get it right 14.3volts to my scangauge and no dash lights.
  10. Mar 6, 2022 at 10:09 PM
    #70
    Legend33
    Legend33 New Member
    Middlesex Massachusetts
    I'm planning on doing this as well swapping out the fuse for the GM diode. To those that swapped out to the diode, do you guys remember which direction the "arrow" pointed? Is it pointed toward front of the truck?
    Thanks
  11. Mar 6, 2022 at 10:20 PM
    #71
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
  12. Mar 7, 2022 at 6:27 AM
    #72
    mountainpete
    Arrow to the front of the truck.
    Legend33[QUOTED] and HulkSmurf14 like this.
  13. Mar 7, 2022 at 7:09 AM
    #73
    eagleguy
    eagleguy New Member
    Everstart at Walmart! Interstate batteries are NOT made the way they used to be.
    Cost and warranty are tops!
    TXBrit likes this.
  14. Mar 7, 2022 at 7:30 AM
    #74
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I've started buying DeKa batteries.
    AGSport and HulkSmurf14 like this.
  15. Apr 6, 2022 at 7:01 AM
    #75
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    We use Deka on both our Toyota's as well as my previous Tundra. Seem to provide reliable service for several years.
    hagrid[QUOTED] likes this.
  16. Apr 6, 2022 at 7:04 AM
    #76
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
    Just upgraded my 2 year old OEM Battery in my 2020 with a brand new Northstar AGM 27F! Paid $370 after taxes and stuff with a 10% off cupon thru batteries plus!
  17. Apr 6, 2022 at 7:52 AM
    #77
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    Interstate, get it from Costco for the best price & warranty!
    RitcheyRch likes this.
  18. Apr 6, 2022 at 7:54 AM
    #78
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Wonder if it's NOS considering they're not made anymore?
    Got mine for $360 shipped
    Moe2o4[QUOTED] likes this.
  19. Apr 6, 2022 at 7:57 AM
    #79
    Moe2o4
    Moe2o4 New Member
    Corey
    What's not made anymore?
  20. Apr 6, 2022 at 7:58 AM
    #80
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Northstar
  21. Apr 6, 2022 at 7:59 AM
    #81
    Moe2o4
    Moe2o4 New Member
    Corey
    For real that quit making batteries...... That's disappointing......
  22. Apr 6, 2022 at 8:03 AM
    #82
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Odyssey makes their replacement now since the companies merged. Do you have the GM diode or the HKB?
  23. Apr 6, 2022 at 8:04 AM
    #83
    Moe2o4
    Moe2o4 New Member
    Corey
    That's a good question, where do you see which one you got? Is it on the label?
  24. Apr 6, 2022 at 8:16 AM
    #84
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The diode looks like a fuse - you replace the Alt-S fuse in your underhood panel with it to boost the stock charge to your AGM since it won't get fully charged otherwise. HKB is the more expensive option that has a built-in fuse but is only made in Australia
    Y0TA PR0, pdiddy and Moe2o4[QUOTED] like this.
  25. Apr 6, 2022 at 8:19 AM
    #85
    Moe2o4
    Moe2o4 New Member
    Corey
    Looks like I need to pick up one of those fuses and swap mine out. I did not know this, where do I get one of those fuses?!
  26. Apr 6, 2022 at 8:22 AM
    #86
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
  27. Apr 6, 2022 at 8:24 AM
    #87
    Moe2o4
    Moe2o4 New Member
    Corey
  28. Apr 6, 2022 at 8:27 AM
    #88
    Rodtheviking
    Vancouver, WA
    Sequoia
    Bingo
    Make sure you get the "arrow" facing the same direction as in the picture.
    Amd you have to trim it a bit, cut off the little side tab for it to fit.
    Moe2o4 likes this.
  29. Apr 6, 2022 at 8:29 AM
    #89
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If you have a OBD plug in with the app it should show you the voltage.
    Mine shows 14.2
    Moe2o4 likes this.
  30. Apr 6, 2022 at 8:30 AM
    #90
    Moe2o4
    Moe2o4 New Member
    Corey
    I'm running a Ultraguage in my truck! I believe when its running it sits about 13.8-14 or so. I'll check it out when I go out to pickup lunch shortly!
