I Accidentally Used Toyota ATF WS for power steering...
Discussion in '2nd Gen Tundras (2007-2013)' started by AstroDude, Apr 5, 2022.
  1. Apr 5, 2022 at 9:58 PM
    AstroDude
    AstroDude [OP] New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    So I was going to buy some more Toyota ATF WS fluid for my power steering and I thought, "let me make sure this product has Dexron in it."
    Well, I found out that Toyota ATF WS DOES NOT have Dexron in it. I have only driven the Tundra three miles since I installed the new steering rack and ps pump.
    This weekend I'm going to flush all the ATF WS in the system and replace it with Mobile1 Syn ATF.
    My question is....do you think I ruined my steering rack and ps pump by driving 3 miles with the wrong fluid?
  2. Apr 5, 2022 at 10:05 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    ruined it, no.. would i get it out of there? yes.. that WS stuff is fairly low viscosity and may start to seep out of seals.
    2mchfun, JuanTon21 and AstroDude[OP] like this.
  3. Apr 5, 2022 at 10:06 PM
    No, probably not.
  4. Apr 5, 2022 at 10:07 PM
    18" TRD Off Road Wheels
  5. Apr 5, 2022 at 10:07 PM
    AstroDude
    Eddie
    I'm a new Tundra owner and I sometimes learn the hard way and the easy way. Thanks dudes, I'll let y'all know how it goes.
    The steering felt a little tight and not as smooth. I guess that's why.
  6. Apr 5, 2022 at 10:09 PM
    empty_lord
    05 rollover special
    its happened at work before. i've yet to have a truck come in that removing the WS and putting the proper stuff in hasn't fixed.
    2mchfun, GODZILLA and AstroDude[OP] like this.
  7. Apr 5, 2022 at 10:13 PM
    AstroDude
    Eddie
    That's good to hear, thank you!
  8. Apr 6, 2022 at 5:25 AM
    Mr Badwrench
    Mr Badwrench New Member
    It's just detergent hydraulic oil. I wouldn't worry about. Flush it out if you're concerned.
    AstroDude[OP] likes this.
