Window driver side
Discussion in '1st Gen Tundras (2000-2006)' started by Dsoshea1, Nov 21, 2021.
  1. Nov 21, 2021 at 9:24 PM
    Dsoshea1
    Dsoshea1 [OP] New Member
    Dustin
    Blue 2005 Tundra SR5 crew cab
    Hey everyone what are yall using to fix the chipping or peeling paint on the trim on/below the window, it looks like chrome underneath but would like to keep it black. I'll send pics in the AM cheers
  2. Nov 21, 2021 at 9:44 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    This is a replaceable part. Although quite expensive to do so. So members have painted theirs or if you're a chrome guy you can peel all the black off and polish it. There are some threads on it around here somewhere if you search hard enough.
  3. Nov 22, 2021 at 12:08 PM
    Or search at all? I found several threads just looking for 'window trim'. Here's a shortcut to the search results so OP can fish on their own.
    https://www.tundras.com/search/4602743/?q=window+trim&t=post&o=date&g=1&c[node]=2
    Note to OP: Your DC I think may use diff't part number than the AC and RC trucks. But the search result about 203 results down in that search with subject '2005 tundra double cab window trim part#' will probably have what you need.
    If not, check the one a few more results down 'window trim pieces'
    Punk1974 likes this.
  4. Apr 5, 2022 at 7:10 PM
    It used to be cheaper 10 years ago. Now the mouldings are 30-40% more today.
