  1. Apr 5, 2022 at 2:34 PM
    Nope. Shock bolt is correctly oriented for me.
    bmf4069 and Darkness like this.
  2. Apr 5, 2022 at 2:40 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  3. Apr 5, 2022 at 2:44 PM
    That’s just caked up grease over the rubber on the upper ball joint. Still no play in the joint.
  4. Apr 5, 2022 at 2:51 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Fellers. My Rockauto discount code. Enjoy.
    197617613178933481
    5N0W808, RUSTYNUTS, bmf4069 and 4 others like this.
  5. Apr 5, 2022 at 2:52 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    5N0W808, chrisb, bmf4069 and 3 others like this.
  6. Apr 5, 2022 at 3:00 PM
    I just spit up my drink reading this laughing. Nice. :D
    Darkness[QUOTED] likes this.
  7. Apr 5, 2022 at 3:02 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    All three orders from Serra shipped today. ECGS plus seal already arrived. Parts pile is about to get humongous. @bmf4069 plus other fellers. Let me know what yall do about the power steering pressure lines. I need to replace both mine.
    Think when I was looking at Serra the set was $400+ during the sale.
    chrisb, bmf4069, KK6PD and 1 other person like this.
  8. Apr 5, 2022 at 4:06 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Get the high pressure one rebuilt locally if it looks like it needs it, then buy the other two on rock auto for pennies on the doll hair
    chrisb likes this.
  9. Apr 5, 2022 at 4:14 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Got this swing case installed, only took 15 minutes or so. Tundra related bc my understanding is the 2nd gen ones fit the best gens, and thinking about ordering one. Don't mind my dirty bed, that must have got blown in at Starbucks or the Mall.
    Wouldn't mind having one on both sides, but as you can see in the picture that would block the light and outlet in this model. Also, picture of my new wrenching buddy. Finally found someone on the same wavelength to help out.
    RUSTYNUTS, oscardog86, chrisb and 8 others like this.
  10. Apr 5, 2022 at 4:15 PM
    Dang, a firecracker pop too?!
    txagg[QUOTED] likes this.
  11. Apr 5, 2022 at 4:38 PM
    Maybe for heat dissipation? Or possibly a different application that didn’t get milled completely for our builds at the factory. I bet @empty_lord knows
    RUSTYNUTS likes this.
  12. Apr 5, 2022 at 5:00 PM
    Feno
    Feno New Member
    James
    Berkshires, NY
    03 AC SR5
    bmf4069[QUOTED] and Tundra2 like this.
  13. Apr 5, 2022 at 5:22 PM
  14. Apr 5, 2022 at 5:23 PM
    Anarchist
    chrisb, alb1k, Darkness and 3 others like this.
  15. Apr 5, 2022 at 5:34 PM
    isomr3b51
    isomr3b51 New Member
    2003 4.7L V8 RWD SR5
    Following up on my post on page 1315:
    I looked at the coolant temp sensors. The coolant temp sensor connector that sends to the gauge fell apart when I removed it. Specifically, part of the connector that houses the RTD (resistance temperature detector) stayed within the sensor housing, and I had to remove it in pieces. (See pic below depicting probe without interior plastic housing.)
    I picked up a replacement probe and connector from Toyota. I snipped the old probe (see pic below).
    Then, I used a heat shrink solder butt connector to splice the wires together (see pic below).
    After a prolonged drive, the gauge appears to be operating appropriately. Thanks to @shifty` @Jack McCarthy for their opinions and advice. I was suspicious of the coolant temp sensor, but I could not understand why it would coincidentally fail at the same time as the timing belt job. Maybe, it was acting up before, and I just did not notice??? Regardless, thanks for pushing me to investigate.
    Parts replaced, all OEM:
    • Coolant temp sensor connector probe for gauge (part #: 82998-12440)
    • Coolant temp sensor connector probe for gauge housing (part #: 90980-11428)
    Hummer, des2mtn, abcinv and 5 others like this.
  16. Apr 5, 2022 at 5:38 PM
  17. Apr 5, 2022 at 5:38 PM
    Killer cuticles!
    chrisb and Darkness like this.
  18. Apr 5, 2022 at 5:38 PM
    :yes:
    Are you gonna do a parts pile? With pics?
  19. Apr 5, 2022 at 6:06 PM
    This is what I've had to do on LS swaps to mate engine and power steering pump. Take both cables into a hydraulic shop and have them mesh the two together.
  20. Apr 5, 2022 at 6:10 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Likely just there for flow or cooling reasons.
  21. Apr 5, 2022 at 6:13 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I was expecting you to notice something in the morimoto LED pic if you were on.
  22. Apr 5, 2022 at 6:37 PM
    des2mtn
    des2mtn On the scenery looking at the road
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I really can't justify spending $90 on that electrical mount the IG dude makes, so I've been homebrewing my own using stuff laying around the garage. I don't have extra steel plate, so I started thinking about using some ABS plastic or something similar for the base. I cut up an old SxS windshield and so far I think it's going to work. I'll have to see about painting it or something so it's not clear. Recycling for whirled peas at it's finest.
    My switch setup in the cab is pretty awful at the moment so it'll be nice to clean it up.
  23. Apr 5, 2022 at 6:38 PM
    artsr2002
    'Yonder
    My Dorman door check arrived today. Will rip it up and fix my stock one this weekend.
    RUSTYNUTS and txagg like this.
  24. Apr 5, 2022 at 6:38 PM
    alb1k
    Left Coast
    It's good
    Well that's gonna be cool
    des2mtn[QUOTED] and FrenchToasty like this.
  25. Apr 5, 2022 at 6:41 PM
    That’s a lot of real estate!
    des2mtn[QUOTED] likes this.
  26. Apr 5, 2022 at 6:48 PM
    What is the mount for? I'm not familiar with the mount the guy sells.
    FrenchToasty and des2mtn like this.
  27. Apr 5, 2022 at 6:51 PM
    des2mtn
    SW
    Tonto cover
    It's pretty much for mounting electrical accessories. That's what mine will be used for. This is the mount: https://www.kamdesignstudios.com/electrical-mount-v1-5
    Like Frenchy said, mine will have a lot of real estate compared to this.
  28. Apr 5, 2022 at 7:07 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    Some stuff came while I was out east house shopping so I started assembling out of boredom. The shocks may need to go on first followed by making a bastard leaf pack/ 3-leaf AAL, TC drop shackles, brake line, etc.
  29. Apr 5, 2022 at 7:29 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    You are gonna love those, they ride so nice
    5N0W808, oscardog86 and FrenchToasty like this.
  30. Apr 5, 2022 at 7:32 PM
    Siebler
    CJ
    Eastern Oregon
    Awesome great to hear! I ran 7100s on my taco way back before i did my f67s and kings and remember loving them so figure id give these a go. The eventual plan is to do a custom set-up back there but with trying to move and needing to do suspension rebuild on Sequoia and Taco too, this seemed the fast and easy route. But hey maybe ill like them and theyll stay longer!?
