What Annoys You About Your Truck?
Discussion in '1st Gen Tundras (2000-2006)' started by tundrainsc, Apr 3, 2022.
  1. Apr 3, 2022 at 5:16 AM
    tundrainsc
    tundrainsc [OP] Happy Tundra 1st Gen
    06 Limited 4.7 2WD
    I really like my 06 double cab limited. But I can never read the time or temperature while driving in daytime. The lights are so dim and daylight eliminates visibility of the reading. Don't know how to fix this. Certainly not problem enough to pull the dash.
  2. Apr 3, 2022 at 6:22 AM
    At high RPM, mine sounds rough. Kinda raspy. I'm guessing it's the hairline cracks in the exhaust manifolds that was common.
    Jack McCarthy likes this.
  3. Apr 3, 2022 at 6:37 AM
    Mr Badwrench
    Mr Badwrench New Member
    If we're talking about 1st gens... my stupid gauge cluster is a mess. My fuel gauge wanders all over the place. My parking brake indicator will not shut off in cold weather. My oil pressure gauge goes to zero at stop lights. My speedometer is 5 mph slow, it's gotten me pulled over. The little light indicating which gear I am in is burned out in the "drive" position.
    My truck runs great, but I'd never guess that looking at my gauge cluster.
  4. Apr 3, 2022 at 6:40 AM
    “J”
    “J” New Member
    NC
    2021 Tundra SR Barcelona Red
    Sounds like it’s time for a replacement cluster lol
    Mr Badwrench[QUOTED] likes this.
  5. Apr 3, 2022 at 6:51 AM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Ergonomics aren't quite right. The steering wheel needs to move forward and back as well as tilt. That would fix the ergo's for me. When my legs are comfortable, the wheel is too far away and when I get the reach to the wheel right, my legs are too crunched. Maybe I will evolve longer arms.
  6. Apr 3, 2022 at 6:52 AM
    Schcoman
    Schcoman From behind the Redwood Curtain
    Humboldt Co. CA
    2000 Access Cab 4.7L V8 4x4 SR5
    None
    The placement of the starter! Why, on God's green earth did they put it under the intake manifold? Some form of Draconian torture wished upon by Toyota on it's owners? $1200 I hope I hope I don't have to spend again for a long long time (prior owner put a NAPA starter in it, bad bad bad! OEM only folks!!).
  7. Apr 3, 2022 at 6:54 AM
    Mr Badwrench
    Someone told this to me one time, and I literally thought he was lying until I looked it up. What the hell toyota!?
  8. Apr 3, 2022 at 6:54 AM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    Yeah I agree, the HVAC control display in sequoia limited is impossible to see in daylight. Poor design that makes you wonder how toyota didn't catch that.
    My tundra suffers terrible episodes of the dreaded dash rattle. I've "fixed" it a couple times just for it to return. It's infrequent enough that I don't put more effort into fixing it, but when it does happen it's very annoying.
  9. Apr 3, 2022 at 7:13 AM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    Starter replacement is an ancient Japanese samurai warrior tradition. Replacement teaches skill, patience and determination, only the most deserving will accomplish this feat. It's a great achievement that will bring honor to your name. Congratulations.
    Seriously I think it's a Toyota thing. I've had a few different Toyotas that had difficult starter locations.
  10. Apr 3, 2022 at 7:23 AM
    Mr Badwrench
    :rofl::rofl::rofl:
    It all makes sense now.
    bmc02[QUOTED], bmf4069 and Schcoman like this.
  11. Apr 3, 2022 at 7:25 AM
    Purely from a maintenance perspective....
    After seeing the rear axle stuff @bmf4069 has dealt with, I might list that as one. SAIP in the later models. Honestly, the cumbersome process to rehab valve cover gaskets is a pain in the ass, the fact you have a couple places FIPG is require seems dumb to me. difficulty of starter replacement seems stupid.
    From a wear/tear perspective, the window rattle at partial-open state and access cab rear window road noise are probably the two big ones for me, but I've had the rear xtra cab rear window noise in other trucks, I know it's related to seals sandwiching over time. Still annoying.
    Everything else I generally like, I think. I'd prefer my cluster had white numbers for the speed etc. The fact I need to sand things to get them white seems ignorant.
    bmf4069 likes this.
  12. Apr 3, 2022 at 7:44 AM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    For me is not having a cabin air filter. Also the fact that our trucks use a timing belt instead of a timing chain, not that you wouldn’t have issues with timing chains but would have been better.
  13. Apr 3, 2022 at 8:11 AM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    Nissan Titan and Armada also has the starter located under the intake manifold
    bmc02[QUOTED] likes this.
  14. Apr 3, 2022 at 8:17 AM
    Rust, rust and more rust. Did I mention rust?
    bmf4069 likes this.
  15. Apr 3, 2022 at 8:39 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    35s don't fit.
  16. Apr 3, 2022 at 8:50 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    My truck refuses to be the flaming pile of shit 1st & 3rd geners say it is.
    1stgentundradriver likes this.
  17. Apr 3, 2022 at 8:55 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    I wish there were more aftermarket parts for the 1st gens. Seems like more and more companies are forgetting about us or the market isn't there (lies).
    daveeasa, Casper421 and artsr2002 like this.
  18. Apr 3, 2022 at 8:56 AM
    Anything involving more than an oil change. Nothing on this damn truck is simple.
    Jack McCarthy and Darkness like this.
  19. Apr 3, 2022 at 10:07 AM
    That was the one thing I didn’t like when I bought mine new. I think the upside is that it lasts longer if it’s underneath the intake manifold rather than mounted to the bottom of the block. Less road salt/water getting to it than if it were underneath. Only downside is having to replace it and that could be a nightmare if you can only work in your driveway and it’s 5 degrees out with a -10 degree windchill!
    Schcoman[QUOTED] likes this.
  20. Apr 3, 2022 at 11:50 AM
    Beefnbread
    Beefnbread Electric Soup
    Oregon
    2000 SR5 Tundra 4x4
    Slow retracting seat belts of course. cleaned mine, sanded down the guide, and used liquid silicone. To this day it still burdens me.
  21. Apr 3, 2022 at 12:43 PM
    Also much less heat in the valley, which is what really kills starters. Still on my original.
  22. Apr 3, 2022 at 1:52 PM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    Most annoying thing are the cheap screws and bolts all over that rust. Why on earth save on pennies. Rust on screws holding down windshield wiper fluid, differential drain plug, screw on top of differential, ......
    Next annoying thing, no protection for the ABS sensors. It takes just a few metal covers. If you go off-road you can break them off and the Christmas lights come on.
  23. Apr 3, 2022 at 5:21 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    You haven’t worked on many vehicles have you lol? This are one of simplest trucks to work on.
    I really don’t have any major complaints other than what comes with any vehicle this age. She’s been a solid rig, at least for me.
  24. Apr 3, 2022 at 5:26 PM
    I was tempted to reply with, "Found the guy who's never owned a BMW!"
    flyfisher and Jack McCarthy like this.
  25. Apr 3, 2022 at 5:29 PM
    SouthPaw
    2000 Limited 4x4 AC
    Exactly, my BIL found that out the hard way with a BMW recently. I warned him, and he still ignored me, even after I worked there 3-4 years.
    The best way to I can describe it, if every other car manufacturer can make an engine and transmission bolt together using eight bolts, BMW will figure out a way to make eighteen bolts fit in the same spot lol.
    bmf4069 and shifty`[QUOTED] like this.
  26. Apr 3, 2022 at 5:34 PM
    If your a contortionist and can fix a BMW, you can pretty much fix anything.
  27. Apr 3, 2022 at 5:35 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    The damn dash squeak. Backer rod didn't completely solve it and has started to pop out from the dash.
    bmc02 likes this.
  28. Apr 3, 2022 at 5:39 PM
    AND make sure you had to replace three or four other things. Gotta replace the alternator? Cool, but you better remember to get the alternator bracket seal, else you'll have an oil leak just from changing your alternator. Because that makes sense, right? If I didn't know any better, I'd swear it was engineered job security.
  29. Apr 3, 2022 at 5:39 PM
    If you can get to all those pink plastic phallic things that hold in the top of the dash and grease them you can get rid of it. You can actually get to one of them on the far right of the dash by taking off the panel holding the glove box light when you open the glove box. Wiggle the dash at that point and you can see/hear it squeaking.
    SharkDog and artsr2002[QUOTED] like this.
  30. Apr 3, 2022 at 7:07 PM
    My BMW did have a trap door in the trunk to access the fuel pump and associated lines. Made road side repair of said lines (pinholes after 22 years) rather easy. Also had a pre-VANOS motor. So simple and reliable.
