A little help on the specs
Discussion in 'General Tundra Discussion' started by VirginiaTundra, Apr 2, 2022.
  1. Apr 2, 2022 at 10:30 AM
    VirginiaTundra
    VirginiaTundra [OP] New Member
    2006 Access Cab V8
    Hey I’m a new tundra owner and am having some trouble finding exact specs. I own the 06 access cab 4wd v8 and it came from the previous owner with 275/65R18’s and am having trouble finding first of all the actual accurate weight (not weight capacity) of this model, and also what psi i should be looking at to inflate these tires for mostly regular road use. all i can find in my manuals is the psi for 265 or 245 tires. any help/ knowledge is appreciated. thanks
  2. Apr 2, 2022 at 10:52 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
  3. Apr 2, 2022 at 11:20 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
  4. Apr 2, 2022 at 7:37 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    This method here will help 100% finding the correct tire pressure with out guessing whether its "Over sized tires" or "Needing to tow" for towing make sure you have what you tow hooked up is the only difference. :)
    https://youtu.be/a2ST54xnhuI
    Saltyhero13 likes this.
