At a loss
Discussion in '1st Gen Tundras (2000-2006)' started by Johnnys kingcab, Mar 29, 2022.
  1. Mar 29, 2022 at 10:26 AM
    Johnnys kingcab
    Johnnys kingcab [OP] New Member
    2001 tundra
    Hey gang, new member here! My 01 tundra is having some issues, went into limp mode last week, threw a code for the magnet clutch, put in a new motor and clutch, while I was in there, I replaced the tps sensor. Truck runs with a fluctuating idle, now the code for the accelerator position sensor is showing, replaced that! Truck is still in limp mode ! And it’s still showing the code for the accelerator position sensor! Any help would be greatly appreciated! I also tried to clear the code with the reader and by disconnecting the battery- still there
  2. Mar 29, 2022 at 10:30 AM
    On that battery disconnect, you pulled the negative cable for no less than 10mins? I'd probably reco 30 minutes myself, but ...
    Has the code set itself again? If so, what is it?
  3. Mar 29, 2022 at 11:04 AM
    Johnnys kingcab
    2001 tundra
    30 minutes!!! Wow, thanks Shifty, I’m on it…
  4. Mar 29, 2022 at 11:34 AM
    Johnnys kingcab
    2001 tundra
    Ok, 30 minutes later, no change. The code is P0120 Throttle/Petal position sensor A Circuit
  5. Mar 29, 2022 at 1:26 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Could try cleaning the tps? Heck, clean the whole throttle body.
    Beefnbread likes this.
  6. Mar 29, 2022 at 2:11 PM
    Johnnys kingcab
    2001 tundra
    I cleaned the entire thing, looks brand new! I hoping it’s not the ECM
  7. Mar 29, 2022 at 2:13 PM
    Johnnys kingcab
    2001 tundra
    I also tried to get the ECM to “relearn” how to idle, no difference
  8. Mar 29, 2022 at 3:13 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
  9. Apr 2, 2022 at 12:20 PM
    Johnnys kingcab
    2001 tundra
    Tried that several times, in the process of taking the throttle body off and removing all sensors… again, just to make sure I didn’t screw something up! @shifty` I unhooked the battery for 3 days, still same :( I’ll keep y’all updated, anymore knowledge y’all want to release, I’m all ears… or eyes I guess
  10. Apr 2, 2022 at 2:56 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    What brand TPS did you use? Aftermarket ones can be crap.
    Got the old one to throw back on?
