275/65/20 or 275/60/20 on 3rd Gen
Discussion in '3rd Gen Tundras (2022+)' started by Jack Straw, Apr 2, 2022.
  1. Apr 2, 2022 at 1:10 PM
    Jack Straw
    Jack Straw [OP] New Member
    Hi. Is anyone running 275/65/20 or 275/60/20 on their 2022's? Would love to hear your feedback and see some photos is you have them!
    Also wondering, going from a stock 32" tire up to a 34" tire, will there be a lot of MPG loss?
    Alexlg2006 likes this.
  2. Apr 2, 2022 at 1:13 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    X42069 likes this.
  3. Apr 2, 2022 at 1:16 PM
    Jack Straw
    Thanks... I've looked through all 20 of those pages, at least twice and all the other random wheel/ tire threads and haven't found much of anything on those sizes. Hoping to expedite my search a little here...
  4. Apr 2, 2022 at 1:51 PM
    frichco228
    Frank
    Virginia
    34 inch tires on 3rd gen are no issue, with a level and the right offset wheels, 35x1250 fit.
  5. Apr 2, 2022 at 1:57 PM
    frichco228
    Frank
    Virginia
    and in the earlier link I sent, check post 13 for a truck, stock, running 295/60/20, so yes, either of those sizes you listed will work as well.
    Alexlg2006 and Jack Straw[OP] like this.
  6. Apr 2, 2022 at 2:41 PM
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    2022 Tundra Limted TRD
    275/65/20
    Lots of room.
    Just posted a couple others in the wheel and tire thread.
  7. Apr 2, 2022 at 3:26 PM
    Jack Straw
    Beautiful
    dekeman[QUOTED] likes this.
  8. Apr 2, 2022 at 7:35 PM
    tropro
    tropro New Member
    Troy
    MN
    2022 Blueprint Platinum
    I have 275 65 20 stock rims. Love em. Haven't driven enought to know how gas gas milage will be but will not have much to compare to as the stock tires came off at 97 miles. :)IMG_20220320_163517.jpg
  9. Apr 2, 2022 at 7:49 PM
    Cholland5583
    Cholland5583 New Member
    275/60/20 KO2s. Plenty of room to go up to 285.
  10. Apr 3, 2022 at 6:00 AM
    presnrob
    presnrob New Member
    Rob
    2020 Cement Tundra Limited
    You didn’t lift/level your TRD Sport? I’m getting mine this week and trying to decide what I can fit without touching the suspension…haven’t seen too many Sport’s with larger tires yet. I’d like to go with 285/60/20.
  11. Apr 3, 2022 at 7:16 AM
    Cholland5583
    No lift. I’m going to put a leveling kit on it eventually. I see no problem with 285s
    presnrob[QUOTED] likes this.
  12. Apr 3, 2022 at 9:13 PM
    Joe T
    Joe T New Member
    I believe you can only get the 275/65/20 in an E 125 rated tire which is on the upper end of heavy duty LT tires. Would be 60-70 lbs each.
    I think most 275/60/20 are around 35-45 each and have a lighter load rating.
    I have had both on different trucks. I would go with the 60 on the halfton as it is rated more appropriately.
    There are some other non E larger tire options in 17s and 18s if you want to change wheels.
    presnrob likes this.
  13. Apr 3, 2022 at 10:22 PM
    Jack Straw
    I do want to change to 18s, but can't justify spending the money on that right now.
    I have a limited TRD double cab and plan on putting a highrise topper on, will be building a sleeping platform with pull out shelves to hold my gear and plan on toting around my 340lb dual sport bike on the trailer hitch rack at times... Still trying to fully understand the tire load ratings, but do you think I could get away with a D or will need the E?
  14. Apr 4, 2022 at 3:39 AM
    Joe T
    Joe T New Member
    On the 18s the 295/70/18 terra grappler I believe comes in an standard P rating and its light for its size. I think its 116 and thats the top end until you get to 121 E or D.
    I would buy what you want and sell the factory’s before you put too many miles on them.
    I don’t think you need an E. I set up our f150s at work with standard 108-116 tires to keep the mpg up. You just need to match the rear GAWR and always air up when loaded.
    I wouldn’t run an E on a halfton unless I was rock crawling because they are thicker and more puncture resistant. I seem to pick up less nails with E tires as well but am on jobsites often. I have before but not worth the decreased mpg and ride.
    Black widow TRD likes this.
  15. Apr 4, 2022 at 3:46 AM
    Joe T
    Joe T New Member
    I think the general grabber comes in a 275/70/18 as well that is a 116 p tire. I think its 33.3” and not to heavy.
    I would run that and adjust your rear air suspension up or check into changing the springs. Leave the rest stock unless you have a special need to lift it.
  16. Apr 5, 2022 at 7:58 PM
    Jack Straw
    Your truck looks great. Do you by chance have anymore photos to share with the 34s on it? Also what kind of tire?
  17. Apr 5, 2022 at 8:33 PM
    tropro
    tropro New Member
    Troy
    MN
    I appreciate the comment! Typically, I have more pics of my vehicles than I do my kids. LOL! I haven't had a chance to take many yet. Here's one from the back and a close up of the tire. It's hard to tell on my sloped driveway but it sits pretty level with no lift. The tires are BF Goodrich KO 2's.
  18. Apr 6, 2022 at 8:15 AM
    Krusher22plat
    Krusher22plat New Member
    22plat
    This is actually not really true as a few examples of the 275/65-20’s exist well under 60 pounds and LT. I originally was going with the Pirellis that are OEM for the Rivian but could not get a firm delivery date. So went with a Firestone xt which is about 52 and have not noticed much difference in gas mileage. Really like how they look, they are quiet and notice no change in responsiveness.
    just972 and HeyMcFly like this.
  19. Apr 6, 2022 at 8:26 AM
    Jack Straw
    Are you referring to the Prilli scorpion all terrain plus? I've been looking at those as well. Do you know much about them? It seems that the tread wears somewhat fast from what I've read.
    I'm between the Prilli and the Cooper Discovery at3 xlt. I understand that the Cooper is 60lbs and rated E, but from everything I've read it seems like a really good tire. Maybe I'll look into the Firestone XT.
  20. Apr 6, 2022 at 8:52 AM
    tropro
    tropro New Member
    Troy
    MN
    Nice looking tire. I considered those but they were on back order with the local Discount Tire. Ended up going with KO 2's and they are an E rated and weigh 57 lbs. 20 pounds more than stock but haven't driven enought to notice gas mileage. Pretty sure it will be a little less though from past experiences. The Cooper was a consideration as well but I believe the are closer the 67 lbs? I could be mistaked but that's what I recall.
  21. Apr 6, 2022 at 9:41 AM
    Joe T
    Joe T New Member
    Yeah I see. Quick look on Discount says there is the terra grappler and recon grappler Nittos in that size at 48lbs and SL rating.
  22. Apr 6, 2022 at 10:19 AM
    tropro
    tropro New Member
    Troy
    MN
    I had a set of Falken Wildpeaks AT's on my 16 CM. I think they were SL rated. I had great luck with these tires. Super smooth and quiet. I got a great deal on the KO's so thought I would give them a try.
  23. Jun 21, 2022 at 2:33 PM
    benca1
    benca1 New Member
    2023 TRD Offroad SR5 Crewmax 4x4
    295/60/20 Wildpeaks 20” limited wheels TRD running boards TRD exhaust OEM bed mat OEM bedcover OEM all weather Mats 4Knines rear seat cover
    you ran a 275/65/20 or a 275/60/20 ko2?
  24. Jun 21, 2022 at 5:23 PM
    Supes1903
    Supes1903 New Member
    2022 Tundra Platinum
    275/65/20 Toyo AT3’s on stock rims. Definitely a bit more room to work with.
    Jorts and benca1 like this.
  25. Jun 22, 2022 at 1:27 PM
    Troa
    Troa I blue it again.......
    Nomad
    2022 Blueprint Limited
    Not true. I have 275/65r20s in a P-rated tire. Pics and details in the build thread in my sig below.
    No rubbing, no fender liner adjustments, no suspension mods. I'm getting the exact same MPG on the computer now as I did before the swap, which theoretically means I actually IMPROVED mileage because I'm traveling 5% farther per revolution. I also did the swap before 1k miles though so there was still break in going on.
    I get 20+ on the highway and 16-17 around town
    KClav likes this.
  26. Jun 22, 2022 at 1:31 PM
    Troa
    Nomad
    I have the Pirelli AT+. They're AWESOME so far (About 1500 miles). Super quiet, great traction, severe snow rated, 50k mile tread warranty. Drive almost exactly like the stock tires
  27. Jun 23, 2022 at 12:03 PM
    Loonaroq22
    Loonaroq22 New Member
    22 Tundra TRD sport
    20220623_104220.jpg 20220623_101157.jpg 20220622_201741.jpg Just installed 35x12.5/20 bfg at ko2 on my stock sport suspension. Lift and wheel spacers are getting installed today. Tires cleared the uca and they rub very slightly at full lock on the carpeted inner liner, which will be addressed today.
    Alexlg2006 and Yaboy like this.
  28. Jul 1, 2022 at 9:08 PM
    JC4x4TRD
    JC4x4TRD New Member
    2022 Tundra TRD Sport
    1.75” level with 275/65/20 Cooper Rugged Trek
    What mileage are you guys seeing with your 275/65/20 tires? Just had some Cooper Rugged Trek tires installed at 50 miles and curious about the mileage people are seeing.
  29. Jul 2, 2022 at 8:24 AM
    Supes1903
    I’ll be honest, most of my driving is freeway/highway at 70-80. 3000 miles in and I mostly see it sitting around 15 MPG. I also drive in Sport mode 95% of the time.
  30. Jul 2, 2022 at 12:03 PM
    bcj001
    bcj001 New Member
    Brad
    Oregon
    22' Tundra Limited
    In my own digging, I found the metric sizes were much more $$ than the "standard"... Installed 35.11.5r20 Nitto Recon Grappler which were ~$380 tire at discount tire... the metric equivalents were almost $50 tire more if I remember right (just looked at Discount Tire website, the prices have gone up... ) I will say the 35x11.5R20 on the stock TRD wheels fit with NO lift/ level, with mudflaps (no rubbing at all)... I have a front spacer level kit in the shop but decided not to use it since it isnt' needed. I was running KO2's on my last rig and they got really loud after about 20K miles.... Loving these Recon Grapplers so far...
    KClav, Pacer164, aj350925 and 4 others like this.
