Gear ratio
Discussion in '2nd Gen Tundras (2007-2013)' started by EagleClaw972, Apr 2, 2022.
  1. Apr 2, 2022 at 10:51 AM
    EagleClaw972
    EagleClaw972 [OP] New Member
    2008 Tundra Crewmax
    Straight Pipe, A/T on stock 20s, towing mirrors, kickers pro comp subs and amp
    Does anyone know the gear ratio on an 08 tundra crewmax 5.7 2wd. Not sure if it has a tow package since idk what a tow package is
  2. Apr 2, 2022 at 10:59 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    If it does have the tow package, there will be a Tow/Haul button in the center console forward of the floor shifter. I can't recall where the T/H button is for the column shift trucks. The T/H equipped trucks all have a 4.30 rear ratio. Also, on the door jamb there's an informational sticker that will have the code for the rear ratio, grab a pic of that and post it here and someone can sort it for you.
    EagleClaw972[OP] likes this.
  3. Apr 2, 2022 at 11:01 AM
    EagleClaw972
    2008 Tundra Crewmax
    Im assuming it does have a tow package lol
  4. Apr 2, 2022 at 11:02 AM
    EagleClaw972
    2008 Tundra Crewmax
  5. Apr 2, 2022 at 11:03 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yep, there should be a receiver hitch under the bumper too, unless someone remover it...
  6. Apr 2, 2022 at 11:04 AM
    EagleClaw972
    2008 Tundra Crewmax
    It does. I just thought someone may gave put it on there. So it has a 4.30 ratio. Thanks...
  7. Apr 2, 2022 at 11:05 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    A/TM: B02A is the ratio, 4.30; AB60E is the transmission.
  8. Apr 2, 2022 at 11:07 AM
    EagleClaw972
    2008 Tundra Crewmax
    You’re the bomb bro thanks greatly appreciate it
