  1. Mar 31, 2022 at 8:28 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
  2. Mar 31, 2022 at 9:24 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    You guys are quicker than me. Is that a wife and a girl on the side song?
  3. Mar 31, 2022 at 9:33 PM
    alb1k
    Left Coast
    It's good
    I've had this MAC 12V tester for a while, a hand-me-down. Never worked. So I ordered a fancy new bulb. Nope. It's just wires and a bulb, so, it's on. Take it apart and check everything for resistance with a meter. Bulbs work, spring needs cleaning, cable/wire is good. The damn solder that contacts a tiny plate in the do-not-unassemble plastic is bad. Break the plastic to get to the solder joint; clean, solder and tape/heatshrink the shit out of it, assemble. Daddy has a working test light, red led. Winning.
    NUDRAT[OP], KK6PD, txagg and 2 others like this.
  4. Mar 31, 2022 at 10:01 PM
    alb1k
    Left Coast
    It's good
    So this happened today.
  5. Mar 31, 2022 at 10:04 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I’m going the soft topper route on the 95. All the others have caps already
  6. Mar 31, 2022 at 10:11 PM
    alb1k
    Left Coast
    It's good
    @shifty` ?
  7. Mar 31, 2022 at 10:11 PM
    NickB_01TRD
    KY
    Cowl clips?
    KNABORES likes this.
  8. Mar 31, 2022 at 10:15 PM
    alb1k
    Left Coast
    It's good
    Has to be windshield or close, right?
  9. Mar 31, 2022 at 10:19 PM
    NickB_01TRD
    KY
    Have you replaced your cowl clips before? Only 1 or 2 cause the leak the others don't really matter.
    https://www.tundras.com/threads/definitive-2000-2006-cab-area-rain-water-leak-thread.70464/
    There's some good links in here.
    Edit: Is it the water from your AC not draining? Check the drain tube under the hood.
  10. Mar 31, 2022 at 10:25 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Love my Tundra.
  11. Mar 31, 2022 at 10:27 PM
    NickB_01TRD
    KY
    90080-18055
    Part number for clips
    Pull the wipers off and then remove the cowl. The clips on the passenger side leak when they get old. 1 or 2 of them leak into the cab when the seals go bad. The other ones dont really matter. They are the clips that cowl screws into.
    There should be info in the thread I linked.
    5N0W808[QUOTED] and alb1k like this.
  12. Mar 31, 2022 at 10:29 PM
    NickB_01TRD
    KY
    Mine only did it when it rained hard. Have you been using your AC? Check the drain tube make sure it isn't clogged either. That wouldn't cost you anything to fix. Just gotta find something to shove in there and clear the blockage.
    5N0W808[QUOTED] likes this.
  13. Mar 31, 2022 at 10:34 PM
    Not in this case. Mr. Five is leaving to come meet me. He should be here in the morning, and I live in Amarillo. Hence the song, Amarillo by morning.
  14. Mar 31, 2022 at 10:35 PM
    NickB_01TRD
    KY
    If defrost is on then AC will run too. (Assuming it works). If you AC does work easy check would be to run it for a bit and see if you see water dripping from the drain hose under the hood.
  15. Apr 1, 2022 at 4:44 AM
    This. New clips and or silicone should solve. I just used silicone to seal my old existing ones.
  16. Apr 1, 2022 at 4:57 AM
    The other posts are spot on. Highly unlikely that you need to take your dash apart.
  17. Apr 1, 2022 at 5:03 AM
    We'll take a look at it today.
    Darkness likes this.
  18. Apr 1, 2022 at 5:19 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Welcome to April in PA...
  19. Apr 1, 2022 at 5:22 AM
    It will be 83 here today, which should mean more bikinis than yesterday.
  20. Apr 1, 2022 at 5:29 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Yeah, I got to drive Kelly's car today instead of the 911 for some similar bullshit.
    I swear to the dark lord.
    If you don't stop posting like this without pics, I'll finish that voodoo doll of you.
    alb1k, Darkness, FirstGenVol and 3 others like this.
  21. Apr 1, 2022 at 5:31 AM
    I’m sure I have pics somewhere, but definitely need to be shared on the private chat!
    If I’m on a roof today, I’ll see what level of creep I can be and snap one or two
  22. Apr 1, 2022 at 5:34 AM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Sounds like you are going to have to pump those numbers up.
  23. Apr 1, 2022 at 5:35 AM
    The bikini barometer
    Darkness and txagg[QUOTED] like this.
  24. Apr 1, 2022 at 5:39 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    It was 65 here yesterday, then 20 the day before.
  25. Apr 1, 2022 at 5:40 AM
    Yeah we got snow on Tuesday, and last Friday it was 94!
  26. Apr 1, 2022 at 7:36 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  27. Apr 1, 2022 at 7:49 AM
    Speaking of resurrections ...
    Looking for input. I need to bring my wife's shoes on the "new" Highlander back to life. It's currently running the super-shitty factory 'platinum clad' 20in OEM 'premium' wheels, Toyota's p/n is "75265" or 4260D0E030, which are 20x8 with a 30mm offset (not sure what the backspace is, all I've got is the offset from literature).
    Anyway, these clad wheels suck balls, you curb check them once and the platinum cladding peels away revealing some kind of plasticky substrate underneath, and that's not flying, because my wife is brutal with curbs and this city requires regular parallel parking. at $649/ea for a bare rim, and $400 for decent used minus shipping, I'm looking at $2k for a new set. So I'm looking aftermarket at this point.
    Bonus if we can re-use the existing tires. Anyone have suggestions? Here's a pic of the car. I can get a side shot to allow for photoshopping if interesting.
    NUDRAT[OP] likes this.
  28. Apr 1, 2022 at 7:51 AM
    Oh and I really like the way this one Interstate Toyota did with 22" Niche Wheels looks awesome. But those low-pro tires wouldn't fly in ATL, they've get dented fast.
    Budget is $1,600 or less, ideally.
  29. Apr 1, 2022 at 8:00 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    An 8" wheel with +30 offset should be roughly 5.7" offset, that's deep. If its -30 then 3.2"
    Not much I dislike more than shitty flakey chrome on wheels. My mom had a 98 vette and the chrome on her wheels would flake off looking like the foil on chewing gum wrappers if you've ever found yourself bored enough to scrape it off with a fingernail. Awful stuff where you need durability.
  30. Apr 1, 2022 at 8:01 AM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    Wife's and curbs! Our Camry xse has (had...) Beautiful factory 18" wheels. Wife rashed the shit out of one first month or two we owned it. So I bought a "take off" replacement on eBay. Next summer scraped up 2 more. I said F it, you are stuck with ugly wheels now. Haha.
    I had a set of continental tires several years ago that had a wheel protector lip of sorts on it. Pretty sweet concept, but haven't seen it on anything since then.
    Darkness and chrisb like this.
