06 Quad Cab Rear-end Replacement
Discussion in '1st Gen Tundras (2000-2006)' started by sparsons, Mar 31, 2022.
  1. Mar 31, 2022 at 10:13 AM
    sparsons
    sparsons [OP] New Member
    2006 Tundra Quad Cab 4x2 V8
    I need to replace the rear axle with the 3.92 ratio. The truck currently has the limited slip differential (locking) but I can't find a decent used one. Can I put a 3.92 ratio without locking on this truck? I've found a couple of these available. Thank you to anyone who can answer this. Toyota refuses to answer this question because it's not exactly the same part.
  2. Mar 31, 2022 at 1:06 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I'm no expert, but I don't see why you couldn't go from a LSD axle to non LSD. The access and regular cab rear axles are narrower I think, but as long as it's off a double cab it should be just fine.
  3. Mar 31, 2022 at 8:35 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Direct swap, except MAYBE the pinion flange. That can change if 2wd/4wd and if RC, AC or DC.
    I put a 04 4x4 DC 4.10 w/LSD pumpkin into my 05 2wd AC that was open diff and 3.91. I did swap my pinion flange, did a solid pinion spacer and new pinion seal.
