Post Your Built AR (Or AK, Or Whatever)
Discussion in 'Guns & Hunting' started by Backslider, Jun 9, 2017.
  1. Jun 9, 2017 at 9:39 PM
    Backslider
    Backslider [OP] Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    I've built a few ARs, a 10/22 from the ground up, and done some in depth work on a few CZ 75s and variants. I'm pretty stoked to have picked up this Aero Precision Desert Mad Dragon builders set for only $299. It's good to have FFL friends. =D
    I'm planning on using black furniture and a black 18" rifle-length barrel (prob .223 wylde) and a Magpul PRS3 stock and grip on this build.
    This is my built 10/22 on a KIDD reciever, KIDD bolt and charging handle, KIDD trigger, GMB match grade bull barrel, and Magpul Hunter X22 stock (I love Magpul stuff).
    Here's another Aero Precision AR I build off a limited edition Freedom Lower. That Cookie Cutter comp is the best part. If you have the means, I highly recommend picking one up.
    And here's a sub $600 AR I build off an Anderson lower, PSA upper, eBay hand guard, AP LPK, Hogue stock and grip.. This one is good for carrying around the desert and not caring if it gets banged up a little:
    Anyone else out there build? What projects do you have going right now?
  2. Jun 9, 2017 at 9:45 PM
    Backslider
    Tooele, UT
    I didn't build this one but did refinish the stock. This was a Waffen Werks AK74 that came with "B grade" furniture. I put some aftermarket black furniture on it but it wasn't long before I wanted to restore it to it's previous comm block glory.
    After some citristrip, light sanding and some very hot water I refinished with a color that reminded me of commies.
    Noodle, MakMurph and ColoradoTJ like this.
  3. Jun 9, 2017 at 9:50 PM
    Backslider
    Tooele, UT
    I am fond of milsurp firearms. I have my C&R and I'm not afraid to use it. Here are a couple of CZ82s I stripped, prepped, and coated.
    Before:
    Afta!
  4. Jun 9, 2017 at 10:22 PM
    I have heard nothing but good things about CZ's.
    Your AK....glad you went back to the old glory. Very sharp looking weapon.
    You take pride in your weapons...anyone can see that.
    zcarpenter92 and Backslider[OP] like this.
  5. Jun 10, 2017 at 7:24 AM
    Backslider
    Tooele, UT
    They really are pretty great. The new p10c has one of the most amazing triggers I have ever felt.
    I'm saving my nickels and dimes right now to get a Shadow 2. If you come across one definitely manhandle it a little.
  6. Jun 10, 2017 at 7:38 AM
    I will see if there is a CZ to rent the next time at the indoor range. You have sparked my interests.
    Backslider[OP] likes this.
  7. Jun 10, 2017 at 1:39 PM
    Backslider
    Tooele, UT
    Have a few LPKs sitting around so figured I'd get started. Dont have a buffer tube and I'm not going to use a basic fire control group, so I stopped here.
    I need to set my bench back up. :(
    Ordered all other parts this morning (sans optics). Getting a Velocity 3lb single stage flat trigger... Now I get to spend the next few days in anticipation. :(
    dandailey likes this.
  8. Jun 14, 2017 at 9:34 AM
    74TundraPilot
    74TundraPilot New Member
    Phoenix area
    '14 Sunset Bronze 1794
    Love Aero's ARs. Quality parts all the way. Built 2 with 300 black and one 18" SPR 556 in multicam. Was going to buy that builder set you have for AR10 in 6.5 but they are getting a little too proud with their prices.
    My AK47 for fun...
  9. Jun 14, 2017 at 9:38 AM
    SlickRick2013Tundra
    SlickRick2013Tundra #10
    Rick
    Mandeville, LA
    13 TRD CM MGM 4x4
    Toytech Boss 3in Lift kit Iron Cross side step TRD Sway Bar TRD Cold Air Intake Blacked out Badges Blacked out front and rear bumpers
    Have always wanted to build my own but was never taught or have the money until now...is there anything I need to know before I start buying parts? Or what is the best route to start?
  10. Jun 14, 2017 at 10:02 AM
    74TundraPilot
    Phoenix area
    There is a TON of videos on building these on Youtube. Start there, and use whatever search engine to find parts at discounted prices. Check out Primary Arms website, as they have kits and parts on sale all of the time.
    SlickRick2013Tundra likes this.
  11. Jun 14, 2017 at 7:42 PM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    1: Remington 700p .300 winmag
    2: Custom built .300 blk ar
    3: Custom built 5.56 ar
    4: Enhanced m1a74bdc0df3190c49e1072db4395fc892f_6705d3ac7d3a33679bc710852ce1380b6dc4972e.jpga0e11430ab3505009f6cf7457fab2ec7_cab8efb8c4b8f367ea5cabccb1cc021b53a61cc7.jpg3a639db32f30117ab4ad56868f3217c3_88acf102bba46b84522e13b5cf618ef80bb2a4c8.jpga48e94490d52c9ff541b8126749f1467_5fca41d76417391e7c5e1ec499076d88d16ec159.jpg
  12. Jun 14, 2017 at 7:56 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Aero Precision upper , rail and lower. Magpul furniture. Pig on the end.
  13. Jun 14, 2017 at 8:15 PM
    JimBeam
    JimBeam Moderator Staff Member
    2015 Limited
    I suck at taking pics with the iPad so if it's blurry...yeahhhhhh
    Anyways, built the left rifle, PSA lower and rail, BCM upper, barrel, BCG and charging handle, magpul grip, stock, and sling
    Left is a police trade in bushmaster with magpul stuff all over it
    Both fantastic rifles, but 2 different uses...Bushy is the go to "work" gun and rides in the truck usually...BCM is essentially a range toy that gets brought out when I take others shooting
    aperezsh and SlickRick2013Tundra like this.
  14. Jun 15, 2017 at 1:06 AM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    Besides the overall badassery of your weapons it looks like You got your own basement/gunvault?
    lionix[QUOTED] likes this.
  15. Jun 15, 2017 at 4:22 AM
    lionix
    Yar
  16. Jun 15, 2017 at 6:40 PM
    Backslider
    Tooele, UT
    Trigger, comp, buffer kit, gas tube, and charging handle arrived today. Barrel and BCG should be here tomorrow.
    Can't find my multitool after the move. It in some lonely box in th basement somewhere. :(
  17. Jun 15, 2017 at 6:42 PM
    Noodle
    Noodle That Guy
    Files creek
    2016 Tundra Limited TRD DC Inferno
    I'm digging that Bulgarian, that's a sweet fucking rifle.
  18. Jun 15, 2017 at 7:08 PM
    dandailey
    Dan D
    Newport News Va.
    Looks great!
  19. Jun 17, 2017 at 4:48 PM
    Backslider
    Tooele, UT
    Found my multitool and got some packages. Everything is done sans optics. Probably going to pair it with a Nikon P-223 with Magpul BUIS.
    SlickRick2013Tundra and aperezsh like this.
  20. Jun 17, 2017 at 4:49 PM
    Backslider
    Tooele, UT
    Oh and the buttstock probably isn't going to stay there long, but I had it and decided to put it to use.
  21. Jun 17, 2017 at 5:50 PM
    74TundraPilot
    Phoenix area
    I would suggest a look at the Primary Arms 4-14 ACSS scope. Really good glass for the money and the most useful scope I've ever had on a 556 platform, more so than my ACOGs even.
  22. Jun 17, 2017 at 6:17 PM
    KB Voodoo
    KB Voodoo New Member
    Chad
    2017 Tundra Pro Crewmax, Cement
    Many KB Voodoo Fabrications accessories!!
  23. Jun 17, 2017 at 7:05 PM
    Backslider
    Tooele, UT
    Nice - I was not aware of this particular scope until your post. I've used a Primary Arms RDS on an AR pistol before and it greatly exceeded my expectations. The reticle on this scope looks amazing. I am highly considering it now - thank you for the recommendation.
  24. Jun 22, 2017 at 7:08 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    These are my two AR builds. Iv built more but sold them off.
    The one on the left is a 14.5 colt upper with a Vortex Strikefire II red dot and a free float m-lok rail.
    The one on the right is a full Aero Precision build with a Ballistics Advantage 223 wylde barrel M4E1 upper and 15in M-lok rail. The scope is a Leupold 1.25-4 Mark AR MOD-1 Firedot sitting in a Burris PEPR mount. CMC triggers in both. Best AR trigger in my opinion.
  25. Jun 26, 2017 at 5:24 PM
    Backslider
    Tooele, UT
    Fin.
    @74TundraPilot , thanks for the recommend on the scope. I haven't had a chance to zero it yet but the glass is crystal clear and the reticle is amazing.
    JH5370, aperezsh and KB Voodoo like this.
